Question about The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac
Math Word Problem
When there is not enough rain, Friendly Farms needs to supplement with irrigation. The profit when there is sufficient rain during the maximum growth period is $4000 per acre. If it does not rain during this period, the profit is only $1600 per acre. Using this information, what profit per acre, on average, can Friendly Farms expect to make? What math strategy do I use to solve this problem?
First, you need to get the probability of the two events - not enough rain and enough rain.
The probability of not enough rain is 1 less the probability of enough rain.
Supposing that the probability of not enough rain is 0.70, then the probability of enough rain is 0.30.
Therefore to get the profit per acre, you multiply these probabilities with their profits per acre. Hence,
$4000 * 0.30 + $1600 * 0.70 = $2,320 is the average profit per acre.
The above method uses the mathematics principle of the weighted expected returns.
I hope this helps.
Posted on May 10, 2009
What are the benefits of using rain water harvesting?
There are many benefits of rainwater harvesting, and some of them are listed below:
1. The rainwater can be used for irrigation.
2.Reduces water bills.
3. After filtering can be used for drinking.
4. Increases ground water level.
5. Easy maintenance.
There are lot more advantages for which you can refer Regenwassertonne.
Mar 17, 2017 | The Kitchen Appliances - Others
Installing an irrigation system of a well with a 2 horse pump and two 110 gallon water tanks..had a partial irrigation system installed and running since october of last year and it was working fine..now...
Shut off everything.
shut off tank.
open hose bib directly supplied by well.
do math.
use stopwatch and 5 gal bucket and google to find out your GPM.
compare it with prior year or well driller info.
also talk to your neighbor and find out his new GPM
Jan 14, 2018 | Plumbing
Orbitz irrigation timers
Intermatic sprinkler timers, 12 hour on-off is possible plus day skipper option, and rain gauge connection etc::
http://waterheatertimer.org/How-to-wire-Intermatic-sprinkler-timers.html
More sprinkler timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html#sprinkler
Link above includes sprinkler timers on market today
Jun 03, 2013 | Electrical Supplies
Moby math
Don't know about Moby math - I prefer Aftermath by the Rolling Stones.
Apr 22, 2013 | Cameras
How to wire hunter rain clik rain sensor to r8816p101c
1) There are different rain clik model numbers shown in manual
Open 24 volt Rain clik manual:
http://www.hunterindustries.com/resources/pdfs/instructions/domestic/lit358w.pdf
http://waterheatertimer.org/pdf/Hunter-rain-clik-instruction-manual.pdf
2) The rain sensor has two wires.
And two additional wires are needed to run from rain sensor to sprinkler timer. For example, buy thermostat wire from local hardware store if wire is not supplied.
3) The rain sensor has a terminal block where wires are connected. .
Open manual above to identify markings on your terminal block.
For example Figure 1 shows SRC model, and with this model number, the rain sensor wires connect to terminals RS and C, and then two wires going to timer connect to terminals RS and and 1.
4) R8816P101C is 208-240Volt 24-hour irrigation timer.
Timer has two separate terminals for attaching rain sensor.
5) Timer power connections have 4 terminals. Do not connect rain sensor to power terminals.
Connect wires from sensor to the two sensor terminals.
6) Timer slide-switch must be set to ON position for rain sensor operation.
Sensor sends continuous 24Volts to irrigation timer.
When it rains, the rain sensor stops sending 24Volts to timer. Timer responds by not turning on power to irrigation pump.
To by-pass rain sensor, move timer slide-switch to off position.
7) Open following link for Intermatic replacement parts:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
8) Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | Intermatic R8816P101C -...
Need rain train instructions- Having trouble getting it to travel
Here is a tip about how to get parts for your traveling lawn sprinkler and also a great article about how traveling lawn sprinklers work.
Traveling Lawn Sprinklers
heatman101
May 11, 2011 | Nelson Sprinkler: Traveling Tractor
As more water is pumped put of the ground, what will happen to the water table? how will this affect the wells?
We lived and raised our children in South Dakota. When the big farms started irrigating our 30 foot bored well water level dropped. When we brought this up we were told to dig a deeper well. We could not afford it. 300 foot wells were expensive. We learned how to recycle bath and laundry water. We got our kids raised up.
Feb 02, 2010 | Educational Insights Hows and Whys Of...
Mathematical Calculation
Following formula we can use.
S=P(1+RT)
WHERE S =INVEST AMOUNT+PROFIT
P=INVEST AMOUNT
R= RATE OF RETURN
T=TIME IN YEARS
EX : (300+x) = x(1+(5.4/100)*1)
(300+x)*100 = 105.4x
x=30000/5.4
x=5555. 4
Jan 05, 2008 | The Learning Company Achieve! Math &...
The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac Logo
227 people viewed this question
Top The Learning Company Computers & Internet Experts
k24674
Stitch85
Level 1 Expert
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
