I was wandering if I have down loaded bookkeeper 08 to my desktop and now I have a lab top if I can use the same disk I used for the desktop on my labtop
  • 4,338 Answers
Usually the license is for one computer. Check with the company and see if you can get a multi-user license.
Or if you are only going to use it on your laptop, remove it from your desktop, then it will be legal to put it on your laptop.
Joe
Please remember to rate Techs who assist you for free :)
Posted on Oct 09, 2008
My dyson Max 08-21663b WHEN FULLY CHARGED I TURN IT ON AND IT RUNS FOR 5 SECONDS AND GOES OFF AND DOES THE SAME THING REPEATELY I BELIEVE ITS MY BATTERY PACK WHICH IS A 6 CELL CAN YOOU ADVISE ME?
Yes the battery pack would be the most likely culprit here. Go on eBay and buy the correct battery cells and build one using the old one as a guide. This method will save you about 50% over trying to buy a make up replacement if available. This is an easy job, just take your time, buy batteries with solder tabs.
Jan 11, 2017 | Computers & Internet
I've got yuyun_cantix icon on my desktop. Could you ,please help me with this problem? Thanks.
not a real description of the problem
try this
right click on the icon and in the drop down box--- delete ---
the program will still be on the computer
if however you wish to remove the problem entirely--go control panel-- go programs -highlight yunyun line-- click uninstall and then when finished go to the icon on the desk top and follow the first instruction
Jan 09, 2017 | Icon Computers & Internet
Will not start up
hi , Reuben
I would suggest you try safe mode.
Safe mode is a troubleshooting option for Windows that starts your computer in a limited state. Only the basic files and drivers necessary to run Windows are started. The words "Safe Mode" appear in the corners of the display to identify which Windows mode you are using. If an existing problem does not reappear when you start in safe mode, you can eliminate the default settings and basic device drivers as possible causes.
If you don't know the cause of the problem, you can use the process of elimination to help you find the problem. Try starting all of the programs you commonly use, including the programs in your Startup folder, one by one, to see if a program might be the cause of the problem.
Follow the steps to boot the computer in safe mode with networking:
1. Restart your computer if it is powered on.
2. Tap the F8 key after your computer initially powers on.
3. Once you see the Advanced Boot Options menu you can stop tapping.
4. Use the up/down arrow keys to highlight your selection.
5. Select Safe Mode with Networking and press Enter.
6. You should see drivers loading, and then please wait.
7. You should then be at the Welcome Screen.
8. Logon to your computer using an account with Administrator privileges.
May 27, 2015 | Computers & Internet
How can i download falsh player on to 2011 imac desk top threw Linux ubentu browser ?
Ok, there are a number of issues with you spelling so I am going to assume you meant the Ubuntu OS. If that is the case the Flash Player install is done by the following:
If you are using the more modern versions of Ubuntu, simply install the Adobe Flash application from Ubuntu Software Centre.
If you are using a version that does not support the Software Centre, try:
Go to the Adobe website.
  • Click on "Download the Latest Player," and choose ".deb for Ubuntu" from the drop down list.
  • Choose "Save File" from the pop up window.
  • Open a terminal window.
    The terminal window will be found under Applications -> Utilities.
  • Change to the directory where your downloaded file was saved.
    cd Download
  • Install the libcurl3 library: sudo apt-get install libcurl3
  • Install the Flash Player: sudo dpkg --install install_flash_player_<version>_linux.deb
    Replace <version> with the latest version number.
  • Restart Firefox.
  • Check that Flash Player was installed.
  • Jul 08, 2014 | Computers & Internet
    Screeen is upside down
    If you have a Windows OS, press and hold the ALT and CTRL (control) keys and then press the Up arrow. (If that doesn't work, try holding the Alt and CTRL keys and pressing the left (or right) arrow key twice.) If that fails, right click on the desktop (Windows+D will minimize all programs), anywhere with no running programs or icons. Then select the Screen Resolution option. Look for the line Orientation; use the drop down menu to select the correct orientation. Click Apply and then confirm the setting change if a confirmation window pops up. (This works in Windows 7 and 8.) For older Windows versions on laptops, you may need to select Graphics Properties (or a similar line) and then repeat this. The Windows screen rotation option is dependent on your video card. With some models, you'll need to open the graphics card properties to undo the rotation. You should see a line for the graphics adapter when you right click on the Display.
    For Macintosh OS, make sure that the System Preferences is closed. Then open it by pressing Option/alt + CMD . Select the line Display. Find the button labeled Rotation: Standard then choose the correct screen orientation.
    I hope this helps.
    Jun 01, 2014 | Computers & Internet
    Toshiba Satellite A665 S6067 laptop wont recognize my SeaGate FreeAgent Go 500 Gb. device
    I had a similar problem and I had to "Delete Volume" when in DIsk Management. I then had a choice to "Create Simple Volume" which I did, and then a wizard created the correct partitions and assigned a drive letter to my external drive. Everything was them OK.
    Mar 21, 2014 | Computers & Internet
    Burning movies on the computer , playback fine on two computeers , will not play on ONN portable player used DVD-R
    Burning dvd\'s is always a crapshoot when you have multiple machines. Computer drives are more tolerant on playback - the problem lies with your other, independent playback units. That is why in your main viewing area it is important that you have a few units so that if disk does not play in one machine, it will play on another. Has to do with the individual differences and calibrations of the machines involved. Store bought dvd\'s have less problems because their laser reflectivity is always higher than disks you burn, and therefore, easier to read properly. Price of the unit has no reflection on ability to properly read the disk. Sometimes and often, a cheaper machine will work better with copies - you never know.
    Feb 19, 2014 | Computers & Internet
    How do i reset my computer to an earlier date?
    Most computers have a RTC or "real time clock" in the BIOS. BIOS (or "Basic Input Output System") controls how data gets into and out from the processor (via keyboard, disk, etc.). Be careful making changes. The BIOS is normally only accessable when the computer is powered on or reset, and then only while performing the POST (or "Power On Self Test"). At this time your screen may display text describing memory, drives, controllers, etc. Some machine have a "silent boot" enabled which displays a manufacturer's graphic or logo instead of this data. It is during this time the the BIOS may be accessed. Depending on the manufacturer of your computer, a key (Delete, Escape, F1 or some other) or key combination (ALT + F1, ALT + S, or some other) will be needed. It is required to press the key or key combination prior to the Operating System loading message(s). This can be done be repeatedly pressing the key (or key combination) once every second (or two) during the POST. Holding the key(s) down the entire time - or pressing them too often will result in an error, and require starting over again.
    Once the BIOS screen is presented, you will have to scroll the entire page(s) to find the clock. Most BIOS brands have more than just a single page of settings. Using the the up, down, left, right, PgUp, PgDn & Enter keys - navigate to the clock hours and minutes and adjust as needed. Make sure that you SAVE changes before exiting the BIOS screen. Upon exit, the computer will reboot with your settings.
    Your Operating System may also provide a way for you to change the system time (and date) as well. Try clicking on the time / date to see if it will bring up a dialog box that allows you to make the change.
    I hope this helps and good luck! If my answer was helpful, please rate it "4 thumbs up" Thanks!
    Jul 27, 2011 | Computers & Internet
    Using bluetooth on Vista with Itunes
    Apple update to Itunes 9-there's a bluetooth link on it
    Sep 20, 2009 | Toshiba Tecra 8100 Notebook
    I can't get my computer to accept my user password to logon to my computer; password is correct and is being typed correctly. I get that wrong username or password message. In addition to this, my...
    Please download the ERD Winternal Image from http://www.mininova.org/tor/857048 and burn it in a CD.
    Thenboot your PC from the CD. Select your Windows Media Edition for whichyou have forgot password. Without asking for any password you will getinto Windows. Then goto control panel->User Accounts->Select theUsername[for which u want to change password]. Then use change passwordoption to change password. Then Reboot the PC and remove the CD. Nowyour windows password will be reset.
    Thanks.
    Mar 08, 2009 | Computers & Internet
    Computers & Internet Logo
    149 people viewed this question
    Brian Sullivan
    Brian Sullivan
    David Payne
    David Payne
