Question about Canon imageCLASS MF4150 All-In-One Laser Printer
MF4150 and USB Sharing switch
MF4150 connected to Vista computer directly. All devices recognized and working
Connected a 2-port USB auto sharing switch ( Aluratek AUS0202 ) to computer.
Connected printer to switch.
As soon as I manually swich to the port that has the printer connected, Vista new hardware beeps and an Unrecognized USB devices message pops up. Device manager reports an Unknown device under USB.
Printer is not recognized.
Any ideas? I need to share this printer between 2 computers and it won;t work on my D-link printer server.
babb
  • 104 Answers
SOURCE: Connecting printer to SBS (Small Business Server)
You can physically connect the printers to the server and share it from there or leave the printers connected to your computer and have the server connect to them via a Local Port which routes to your computer!! To do the Create the local ports you'll need to 1.) share the printers on your pc 2.) Go to the server and go to printers in control panel 3.)Click on Add a new printer then next 4.)Select Local Printer connected to this computer; De-select Automatically Detect Printer 5.)Select Create new port and select Local Port 6.)In the enter a port name, enter the full network path to the printer i.e. \\your-pc-name\printer-share-name click ok 7.) Select the drivers for that specific printer(if its not there click on have disk then browse to the drivers to install them) 8.) Continue through the installation until finish) 9.) Repeat steps for additional printers Keep in mind that your computer still needs to be on! You can check to see if your printer support a network card to make them fully network printer you can add them to the server this way and only the server would need to be on! Or you can also get a print server(Device that makes regular printers into network printers). Now when it comes to the scanning, i don't know of any way to share a scanner with just windows alone, but there are third party software that allows you to do that Check out http://www.remote-scan.com/ There are also printers that sorta do the scanners sharing by automatically scanning and putting files in a designated area on the network! Hope this was helpful regards, babb
Posted on May 03, 2007
  • 163 Answers
SOURCE: hp laser 1020 printer does not sharing
change window with xp
Posted on Sep 12, 2007
pagebor
  • 2785 Answers
SOURCE: Uknown device Error - Canon PIXMA M180 All-In-One
just unistall the usb printing support from the device driver then you you restart then you put the printer cd in the rom and try, post your comment
Posted on May 17, 2008
KyoDoc
  • 38 Answers
SOURCE: when printing to IP address a pop up asks for user id and pass
I can definately help with your ID code problem, and maybe with your vista problem.
The ID problem is very simple. Normally when this happens, the copier is set up to use ID codes for copying. When you install the driver, it connects to the machine and collects these type of settings, and configures the driver to the same state as the copier. You have two options to solve this problem. you can either turn off the ID codes in the driver completely, but then your copier must be set to allow print jobs without ID codes, or you can configure the driver with your code, and set it so that it does not ask you again.
both of the options are done by going to the printer driver properties. Click on the "device setting" tab at the top.
If you want to disable the ID codes completely, simply untick the "job accounting" box. click on "Apply" and then on "OK"
If you know your code and you want to configure the driver with your ID code and set it to never ask you for the code again do the following:
Make sure that the "Job accounting" box is ticked. Click on the "settings" button to the right of "job accounting". In the window that appears tick "Allow password setting". Enter your ID code and password (If you have a password), and untick "Confirm ID/password when printing". If you like you can click on the "verify" button. This will check that the ID and password that you've entered is valid or not. This is very handy feature if you are unsure if you've entered the correct info. When you're done with the afore mentioned settings, click on "ok", "Apply" (If active), and then on "OK"
Now for your vista problem. I'm not too sure of the exact problem that you're experiencing, but from what I can make out from your description it sounds like its a driver issue. I would say go to the canon software site and download the x64 driver for your product. The URL for the site is : http://software.canon-europe.com. once you are on the site all you need to do is specify your model, the operating system (In your case Windows Vista) and the language that you want the software to be in. The site will supply you with a list of different software that you can download, make sure that you download the Vista x64 driver. The site will clearly state that the driver is compatible with x64.
Hope all this info is helpful. Have fun, and don't forget to rate me.
Posted on Jun 08, 2008
  • 235 Answers
SOURCE: USB device not recognized
try to connect your printer to other computer if still same result have your printer check to see what is the problem with the printer
Posted on Nov 21, 2009
Testimonial: "Should have thought of that. Thanks."
I have a Trendnet TK-209 KVM switch. My keyboard and mouse (MS wireless) that worked well for a year stopped working through the switch. they work well if connected directly to each computer.
I can confirm the same problem happened with me just now. I have TrendNet USB/KVM TK-207 and was flawlessly working with Logitech K260 Wireless Mouse and Keyboard Combo, but today on both computers all I can see is the error:
USB Device not recognized - The last USB device you connected to this computer malfunctioned and Windows does not recognize it.
I unplugged the usb wireless adapter and connected it directly to the PC - it worked like a charm again. I have tried to connect the wireless adapter to the mouse port hoping that the keyboard USB port is causing problems, but all I got was the same error. I have tried to conect a normal USB keyboard, but again the same error I get for both - the mouse and keyboard, so it is more than obvious now that the USB ports of my KVN Switch are malfunctioning. I will try to leave it for a while if it got hot somehow as it was connected for more than 6 months working perfectly fine, but if not, I am heading to the store for support/replacement.
May 02, 2011 | Trendware TK-207K 2-port USB KVM Switch
I want drivers to use my phone as a modem on win vista.
Click on the link below to download the Software for your Phone to access internet on PC
Download Link 1
Download Link 2
Ways to connect or access internet below :
When you connected your Diamond to your PC, what did it get recognized as?
What does it show up as in your PC's Device Manager?
On your device, do you have Internet Sharing or Wireless Modem? If it is Wireless Modem, after you connect your device to your PC, you Start Wireless Modem and that should install the Modem Drivers.
If you have Internet Sharing, what is the message you get on the device after tap connect (Check USB, Disconnected, etc.)?
Try updating active sync software to the latest, at least 4.5 I'd think. Not sure if there's a newer version out.
Also,
Connect your phone to your pc by using the USB cable provided with your phone. On your phone you should go to Window Icon at top left corner of screen, then go to Programs on the drop down menu. From there choose Internet Sharing. Once you tap Internet Sharing you will be prompted at the bottom left of the screen to Connect. Tap Connect and then you will see your pc recognize the connection on the bottom right of computer screen. It will install the drivers and then from there you are good to go. Hope this helps!
Thank you for contacting FixYa
Nov 24, 2010 | HTC Touch Diamond Smartphone
My ml 1610 printer says its not connected to my computer even though the cord is pluged into the usb port
Check the hardware and software settings first
1) Check the Hardware Connection -
a) Power connection to Printer
b) USB Connection from Printer to Computer
2) Checked the Drivers Software
a) XP/Vista = Open the device manager
Click Start - right click on My Computer
Click on Manage
Click on Device Manager
Click on (+) Ports COM & LPT and Check Printer is listed or not
or
Check for Printer Name (Samsung ML1610) is it listed under device manager
if YES - Check by printing the test Page
if NO - Install the Printer Drivers and then print the Test page
Jan 21, 2010 | Samsung ML 1610 Laser Printer
I already have 2 PCs that are both internet sharing using a non-router 5-port hub (one with WinXPPro that's connected directly to the internet, and another with Win98SE that's connected using a proxy). Now...
You can't share your connection on the PS2 to other devices. Connecting the PS2 into your hub should share the connection to all three devices as normal.
Jul 13, 2009 | Sony PlayStation 2 (PS2) Console
Printer sharing wirh USB hub
I would connect the printer to the main computer, network the 2 computers and enable printer sharing. The only draw back to this is that the main computer will have to be on in order for the other to print. Vista makes this easy to do.
Jan 31, 2009 | D-Link DES-1008D 8-Port Ethernet Switch...
Printer is not working
The Pixma MP210 does not support a wireless connection. It has a USB port. Some wireless routers do have USB ports and can thus share the printer. Similarly, there are print server options that can be connected to the USB port. However, these will not work with the scanner functions of the all-in-one. Also you would need to confirm that the print server you choose is compatible with the Pixma MP210.
The fastest way to print right now is to connect the USB cord to the laptop. Wait for the drivers to be installed and then send the file to the printer. Moving the cable will let both computers use the scanner features of the all-in-one. A manual USB A/B switch might allow you to share the printer with fewer chances for a damaged USB cable. However, these usually don't support the scanner. Scanning requires bi-directional communication between the printer and the computer. A bad USB cable can turn an all-in-one into a single function printer with a direct USB connection.
Once the MP210 driver is on both systems and they are connected to the same network, you may be able to set up the desktop as a print server for the laptop. This will depend on the OS on both systems. Something like the Windows Homegroup easily allows printer sharing when enabled for systems with Windows 7 and newer on a private network. Both systems need to join the same homegroup. One system starts the homegroup. Then you have to type in the password on the second computer. This works even with one system connected to the wireless network and the other connected to a wired port on the router.
On Vista and XP, you could enable printer sharing as well in the Network and Sharing center. See https://www.wikihow.com/Share-a-Printer for the steps With Windows OS versions, the scanner functions will only be available on the computer with the direct USB connection.
I hope this helps. Please add a comment with the OS versions on both the desktop and the laptop if you need more specific advice.
Dec 22, 2017 | Canon PIXMA MP210 InkJet Printer
Use two computers with one printer
Printer Sharing (This is good for Windows 2000, XP and Vista)
Sharing will be very easy if your network is working.
You need to consider the computer where the printer connected as the "Host" and the other computer that wants to print to that printer as the "Client".
Before you do such sharing, you need to acquire each computer's IP address.
You can do it by accessing MSDOS Prompt and typing in ipconfig/all. Write down your IP addresses and the share name on a paper.
For your Host:
Install the driver, make sure that you can print on direct bi-directional connection (such as USB).
Go to Control Panel >Printers and Faxes* >Sharing >Share this printer >Type in your share name, good example is PRINTER (this is case sensitive).
For your Client:
Install the driver, make sure that you can print, same with the Host.
Go to Control Panel >Printers and Faxes* >Properties >Ports >Add Port >Add local port type in \\ (the IP Addressof the Host) \ (share name), click OK.
ex. \\192.168.1.3\PRINTER (watch your backslash, no spaces)
*Term used is "Printers" for Windows Vista and Windows 2000
Oct 23, 2008 | NetGear FS105 5x10/100 Mbps Networking...
Problem with KVM switch and Vista
Your problem has nothing to do with the Operating System (Vista), it has something to do with the brand of your computer. I have similar problem before, I have Vista (Dell), but the time I connected another Vista (Sony Vaio), everything worked correctly.
This is what you need to do:
1. You have to make sure that you are using a standard USB keyboard and mouse.
2. Connect first the keyboard and mouse directly to the Vista computer to see if the USB ports of your computer are working properly.
3. You may power cycle the KVM switch by disconnecting it from the computers (including the keyboard and mouse) and leave it disconnected for 2 minutes.
4. Reconnect everything after two minutes and then reboot the computers.
5. Try using different USB keyboard if problem exist after power cycling the KVM switch.
Sep 16, 2008 | IOGear GCS632U 2-port KVM Switch
CAn't print on one PC
Are you sure it is not recognizing the switch?  Just a thought, but maybe the other computer has not loaded the usb drivers for the printer.  Have you connected the printer directly to the computer to see if you can isolate the problem?
Oct 11, 2007 | Aluratek AUS0202 - 2-Port USB 2.0...
Canon imageCLASS  MF4150 All-In-One Laser Printer Logo
114 people viewed this question
old marine
old marine
