I tried all of the above. Even uninstalled/reinstalled, deleted, etc. I am about to give up and buy a new one, but I still have some of the very expensive cartridges. Any help will be appreciated.I tried all of the above. Even uninstalled/reinstalled, deleted, etc. I am about to give up and buy a new one, but I still have some of the very expensive cartridges. Any help will be appreciated.
You can't post conmments that contain an email address.
Norton changed your firewall settings to block that port. Open norton and look for Settings then manage firewall, then program rules...look for your printer someplace on that list and use the dropdown list to change it...if that doesn't work let me know...
********If u have installed the drivers from the old printer cd (used for windows xp ) ..on to ur vista os ,,,then we
have some real problem and could take time but can be fixed *****
If u have not installed any ofprinter drivers …then u should be able to
print (cannot scan ) , jus as connect the usb cable to the pc and ur firewall
or comp settings may be blocking the communication . *********replay to me and I
will help further********
You need to go to Control Panel add/remove programs and remove all Printer programs. Then disconnect the USB cable, install the printer software until a message comes up that says plug in your printer. If no message comes up, complete the software installation and then plug in the USB cable. The computer should find the printer at this time.
My dell photo aio 922 says there a communication problem and i try to print i do everything it tells me to do for exaple recconect the usb restart computer and try and take the printer plug out but still i am haveing the same problem
Remove the right ink cartridge (color). You will get an error saying the cartridge is empty, but ignore that. Hit cancel on your printer. Print your job...when your print screen comes up, under preferences check the box for print colors in black and white. Your printer should print just fine without the color cartridge. Ignore the flashing red light.
Not sure if this is the correct way around, but it worked. Go to Start --> All programs --> Dell Printers --> Dell Photo AIO Printer 922 --> Dell All-in-one center
From here, you can determine and change your scan settings as needed; then click "scan now" (thus by-passing the button on the actual AIO machine). This scanned photos into my picture program so I could email to all the grandparents!
