The four buttons at the bottom of remotes just blink and blink I have reset all of them. Reset from the beginning to trying everything. I get no cursor.
SOURCE: wii not working
I have followed all the steps many times and I can feel the console working as it vibrates when I press the buttons but even when I turn the SKY on and off, and all the other links like DVD the Wii does not come on the screen even when I manually seek the channel...any thoughts
SOURCE: remote disconnection.
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
129
SOURCE: wii remotes blinks several times but doesn't work.
you see the little flap on the wii open it and the back of the wii remote then press both red buttons and wala good as new
SOURCE: my remotes wont respond at all
It sounds like the remotes have become unsync'd with the system for some reason, so you'll have to resync them. To do this you should take the battery cover off of the back of the remotes and locate the little red button inside. There is also a red button on the front of the system. You need to point the remote at the sensor bar and press both of the buttons at the same time and hold them for around 5 seconds.
All you have to do is hold down the button and make sure they are pointed to the screen
