Question about Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker
Wattage and amps?
I have 2 1200W Sony Xplod subs and 2 1100W Sony Xplod amps. Will this work without destroying the subs or do I only need one amp?
  • dra91392003 Oct 09, 2008
    one sub on one amp? that wont make the sub burn out?
  • Anonymous Mar 28, 2014
    I have a 2000 GMC Sierra, since my old Sony Radio stopped working, I had to purchase a new set. I got the XO Vision X349nt model. After installation, my subwoofers wouldn't work but the Amp does turn on. The Subs shouldn't be blown because I have a lower wattage amp to avoid overpowering the subs. They worked well before I got the new radio. The REM wire is hooked to the P. Cntrl wire but a friend of mine suggested I should hook it to the P. Ant wire since I don't have a power antenna. If not, what could be the problem?
  • 790 Answers
Good and compatible!
Posted on Oct 09, 2008
  • carlos fernandez Jr.
    carlos fernandez Jr. Oct 09, 2008
    see the specification bridge wattage type? if the PMPO is 1100watts in bridge type that is good for 1 amp for 1sub..
    Thanks!
Which amplifier i should use with JBL CS-1205T
this sub woofer tube has a rms rating of 275 watts... try using a kicker or orion 600 watt mono amp to run this. the brand name is what tell you about how good an amp is for instance the names i just mentioned rate their amp by standard play frenquencies where as other lower brand names rate their amps by the max out put on certain subs at certain frequencies which may lower their impedance and create more power although you will never play your sub at those frequencies. as for the max power of your sub of 1100 watts that is more than like only at a certain frequency so always only double your rms rating of your sub to find max power handling.
Jan 29, 2011 | Sony Xplod Amplifier XM-SD51X - Class D...
What amp do i need for Sony Double XS-L124P5B 1300w each?
Most professional car audio installers and manufactures say that to get the best sound out of your subs, you should run half of the RMS wattage listed on the speakers, which in your case would be 1300w for both which is kinda up there, but you can find a 1200w amp and even a 1000w amp would work great, just make sure that the amp has true wattage listed because they have a habit of over rating them until you read on it later. Another way of going about it would be 2 amps, 1 for each speaker, which would be smaller amps, but you would have to make sure both are getting the same amount. Hope this helps.
Mar 03, 2010 | Sony Xplod (P589) Car Subwoofer
Amplifier For Powering Sony Xplod xs-l121p5
Pump the brakes!
You need to know the RMS power rating of the sub you are powering.
Dont exceed the RMS power rating of the sub by more than 25%.
If you see a peak power rating on either the sub or the amp, ignor it, means nothing. Always compare RMS ratings.
Example: a Sony 12" Xplod sub, boasting 1200 watts, will only handle, 350 watts RMS, so the amp you choose to power the sub should be 350 watts RMS as well, and should not exceed more than 25% of the RMS power handling (487.5 watts).
Bottom line, know your RMS numbers, not Peak.
Byron
www.distinctbeat.com
Dec 06, 2009 | Sony Car Audio & Video
Amp often decides to not work.
HI DUDE ,, TRY CHECKING UR RCA CABLE ,, COZ IT MIGHT B UNPLUGED AT UR PRE AMP OR PLAYER ... OR CHECK UR SUB WOOFER WIRE INSIDE THE BOX ....
Apr 14, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Settings for a Sony Xplod 1200 watt amp, with two 12 inch subs
What kind of subs are you running? Meaning what brand, what are the ohm, spl and wattage? I'll look up your amp while you get that info to me. Looking forward to helping you:) Thanks!
Apr 08, 2009 | Sony Xplod 1200W Class AB Bridgeable 2-Ch....
What size is the voice coil in my 1100w 10" sony xplod sub?
go to the sony website or any dealer website and look at the model number of your sub, punch that in and get the measurement.. mostly gonna be inches.. but then go to google and convert it to mm
Apr 06, 2009 | Sony Xplod 1100 Watt Max 10" Subwoofer,...
Can I run 8 speakers and 1 sub through 1 1200watt 2:1 Sony Xplod?
asuming the 8s are 4ohms each; wire two in series and that gives you 8ohms then two more in series then you put those together in parallel and it gives you a 4ohm load. repeat with other four for the other side. you should then be able to bridge the sub
series; posative of one speaker to negative of other speaker and that doubles your ohms
parallel; posative to posative negative to negative and that cuts the ohms in half
Apr 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Sub not working any more
mine does the same DONT BUY SONY XPLOYED THEY EXPLOYED!!!!!!!!!!!!!!!!!
Jun 23, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
Amp not putting out any sound
Check you pre amp RCAs and make sure they are holding a voltage...this is where the Amp takes that signal and amplifies it...without this connection the amp will not produce any power.
Jan 31, 2007 | Sony Xplod Amplifier XM-SD51X - Class D...
Sony Xplod 1100 Watt Max 10" Subwoofer, XS-L100P5W Car Speaker Logo
324 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
