Question about Hunter 52" Ceiling Fan With Light And Remote Control
Lost conection between fan and remote
It seems the the remote has lost its connection to the fan unit. The battery is still good (I tested it in another remote) and the LED lights when I press a button. Is there a way to reset the connection? Thanks.
  • Anonymous Feb 11, 2009
    ceiling fan starts itself ,periodically,daily..
    Scholar:
  • 75 Answers
There seems to be a problem with the upper part of these remote controls. They work for a while and go out. I have replaced 5 for people in the last 3 months. The store where most of these were purchased gave me new fan, and let me bring back the parts that were bad. I did not have to assemble another fan, just change the bad receiver on the remote. I hope they work as well with you. I think they know there is a problem with them.
Posted on Dec 21, 2008
Lost all power lights totally and engine shut off
check battery cable connections, Good Luck
Mar 26, 2015 | 2004 Chevrolet Silverado
Kichler ferron 60" why ceiling fan will only move very slowly remote does not appear to be working
If your Kichler ceiling fan appears to have lost touch with the remote, try the usual routine of removing batteries from the remote, pressing all buttons to eliminate a stuck button as the cause, then reinstalling the old batteries (or new batteries) and testing operation. If no luck, disconnect power at the source, not the fan, pause briefly (to "reset" the fan control) and reconnect power to test operation. If still no luck, the remote receiver in the fan or the remote itself may be defective.
Aug 31, 2014 | Kichler Dryers
Kichler uc7206t
Check for correct battery installation
Apr 22, 2013 | Dryers
No conection and shuts down
test your PSU power supply unit if the units fan is not working the psu is faulty
test the leads from mother board to hard drive make sure the connections are secure and dust free
if its a 40 pin ide this will be the first to fail include electrical extensions
make sure your ram modules and cmos battery have good dust free connections on some motherboards cmos batteries are soldered in
computers need all power and data to travel through every working device and to contiue its cycle and to have an end to work
hope this helps you
Nov 06, 2011 | E-Machines eMachines Desktop PC
Lost manuel and can't get remote to work
These Hampton Bay Remote units are notorious for failing.
I'm sure you've done this , but just in case: Are the batteries good and installed correctly?
Is the wall power on?
If the remote is a standard feature, make sure the fan switches are on. (The remote add-on kit bypasses the switches)
Bring the remote to within inches of the fan and try it.
If it works then, The remote/receiver is combo needs replacement or removal (switch back to manual because the string has a better range.)
Sorry for the bad news, but please don't shoot the messenger.
Mike
Sep 28, 2010 | Hampton Bay 46056 Callaway II Ceiling Fan
The remote control will no longer turn off the lights on the fan but will still turn the fan blades on and off. What do you suggest? Would getting a new remote control solve the problem? If so, how do I...
You remote is working fine but for the control on the light switch. If teh fan is switched on and off then the communication is good enough and the remote and the main unit is communicating. Hence remove the remote control and clean the pads of the light button. Dry up if possible and if there is a carbon track, the you can use a carbon pen to make up the lost track, or if the pad has lost the carbon pad then stick one conductive pad so that the circuit is activated. I hope you try this out. Good day
Aug 16, 2010 | Hampton Bay 24002 Ceiling Fan
Lost remote
Well you can purchase a universal remote in place of your lost remote. You need to connect the universal remote to your fan, universal remotes have a code search button or sequence. Turn on your fan, activate code search, & press the power button until the appliance turns off, then press the set button. or use the manual book provided by the universal remote manufacturer.
Good Luck!!
Thanks for using FixYa!!
Jul 06, 2010 | Hampton Bay 24750 Huntington III Ceiling...
We just installed yesterday. Ran it with remote for about 3 hrs, on and off, tested speed, reverse, all worked. Come back 5 hrs later and go to turn it on and it does not work. Usually i hear a beep when...
The beep comes from the receiver in the fan hub. If no beep, I would suspect the receiver is not responding to the remote.
Reasons could be:
- loose connections to/from receiver or,
- with bad luck, the receiver could have failed already (loose conections could cause premature receiver failure) or,
- the fan pull-chain switch is off -- your scenario does not allow for the chain being pulled during the 5 hours the fan was not run, but who knows... or,
- receiver/remote are out of synch (set on different frequencies). Are there dip switches in receiver/remote to set frequency, or is the frequency set by the remote with a combination of button pushing? If the latter, maybe the frequencies for the two are were accidentally set out of synch...
More info, let me know...
Charlie
Sep 25, 2009 | Casablanca Fan 6646T Panama® Rustic Iron...
Compaq laptop 6710b, wont turn on battery now gone flat ac adapter ok,no lights comes on no fan no hard drive whiring absolute dead suggestions please Thanks
I know batteries cost a little, but replace it. The power connection works through the battery charging unit. If the battery is no good, your connection is lost.
Jun 11, 2009 | Computers & Internet
FAn and lights won't go on.
I'm not familar with the remote control for this unit but if anything is blinking is an indication the batteries need to be replace.
Jul 09, 2008 | Hampton Bay 52 In. White Redington...
Dryers Logo
333 people viewed this question
Top Hunter Dryers Experts
Paul Bade
Thomas Perkins
Thomas Perkins
Are you a Hunter Dryer Expert? Answer questions, earn points and help others
