Question about Bunn HW2 Electric Kettle
No water come out
I have a bunn hw2 electric kettle, the problem is it can not come out water in busy time. I want to know how the safety switch(float) work, how can i know the correct direction if i took it out and forgot to mark it? how to control the level? how to measure if the probe is ok? how to know if the control board working properly?
3 Suggested Answers
SOURCE: hot temperature
If you turn the unit around and look indise the back of it, there is a black knob that you turn to adjust the temperature. It is kind of hard to see unless you turn the machine full around.
Posted on Jun 19, 2008
SOURCE: krups electric kettle leaks
You cannot fix it when they split like that.
Posted on Apr 01, 2010
What are good features to look for in an electric kettle?
One of the best feature of electric kettle is it should be cordless. One of the most advantageous benefits experienced by those choosing to switch from the traditional methods of boiling water to the more convenient cordless electric kettle comes in the form of optimized time savings, cutting the time it normally takes to boil water by as much as seventy five percent. So for the cordless electric kettle water level indicator is essential. It must be long lasting and more durable. You can get more information about it from the coolkettles.co.uk. so go with this my provided link.
Nov 24, 2012 | Office Equipment & Supplies
How can i rewire a lpg bunn coffe grinder? i ordered it on ebay and the wiring and parts were not connected when it finally came, please help!
the wiring diagram should be inside the grinder pannel.
if not then take modal number and call BUNN
or go to BUNN website
please rate my work
Sep 01, 2011 | Bunn LPG Commercial Coffee Grinder...
Kettle has just suddenly tripped the electricity. Tried changing fuse and different plug socket but still tripped. O oh!
This is because there is a current leakage between the live and earth terminals of the kettle.
You see, if current leaks from live path to earth, you will get an electric shock when you touch the outer metal surface (because the metal part is earthed). To protect you, the trip switch will cut off the electricity supply.
You can try drying the kettle in hot sun. This is because the current leakage is most probably due to water leaking in to the circuitry.
You can try replacing the heating element, if it is available in the store. Otherwise do not use it. That's better for your safety.
Jul 22, 2011 | Dualit 72024 Cordless Electric Kettle
My kettle keeps blowing the circuit
If the fuse in the mains plug or MCB at the consumer unit / fuse box keeps tripping then there probably is a fault in the kettle element or switch. If the RCD is tripping (the safety device with the test button on it) then there is an electrical leak either due to a crack in the element or water has got into the wiring, switch or power cord of the kettle.
Allow the kettle to dry out in a warm place for a day. Also check it at another power outlet to eliminate any problem with the outlet you are using.
May 28, 2011 | Dualit 72300 Stainless Steel Cordless...
I need to order a kettle for my Old Fashion Movie Time Model CCP-509 and I don't know what size kettle it is and where to order it from??
Nostalgia Electrics CCP-509 Movie Time Popcorn Maker
  • Now for the finishing touch -- a full sized popcorn cart that makes delicious, old fashioned, movie house popcorn. The design is nostalgic, but the features are very modern.
  • Tempered glass window.
  • Large stainless 4 oz steel kettle with built in stirring system.
  • Warming light.
  • Kernel catcher.
  • Supplies compartment.
  • Safety Electrics, and easy to clean design.
  • Popcorn never tasted so good at home.
  • Makes up to 1.5 Gallons of popcorn per batch. 4 oz Kettle.
  • Storage compartment in base of unit.
  • Dimensions: 16"L x 19"W x 60"H
Feb 04, 2011 | Nostalgia Electrics Helman Group CCP-509...
Water between the walls of the pot. How do we get it out?
I suggest contancting them directly for advise. Some of these types had a fluid for insulating, but i dont think Bunn did. Please Contact 1 800 637 8606 Bunn-o-matic
Jun 26, 2009 | Bunn 32125.0100 Airpot Stainless Steel...
Bunn G2 is caked and I need to remove burr gear
For this job, you will need detailed instructions. You can download a use and cleaning manual for this Grinder at this adress: http://www.bunn.com/pages/techdocs/manuals/grind.html
Nov 18, 2008 | Bunn Commercial Grade Home & Office Black...
Hot temperature
Nov 28, 2007 | Bunn HW2 Electric Kettle
Problems with Breville SK500XL Stainless Steel Cordless Electric Kettle
There's a thermal cutout that trips if the regular safety switch isn't enough. According to the manual, if the thermal cutout trips you have to send it back to Breville for servicing.
That may be what happened, if just letting it cool down and trying again didn't work.
Aug 13, 2007 | Breville SK500XL Stainless Steel Cordless...
Bunn HW2 Electric Kettle Logo
62 people viewed this question
Top Bunn Kitchen Appliances - Others Experts
jasbo
jasbo
Kelley Hopper
Jerry Greenberg
Jerry Greenberg
Are you a Bunn Kitchen Appliances - Other Expert? Answer questions, earn points and help others
