Question about Emerson MW8106W Microwave Oven
No heat the light off,but the power still run and heat no up.
  • 905 Answers
The magnetron needs replacing
Posted on Oct 09, 2008
Microwave has power will not start
When you say it just hums, do you mean that it sounds like it is running but isn't heating? Or do you mean that the sound is different from when it normally runs? Is it quieter or noisier than normal? Do you hear the fan running or is that sound missing?
IF it sounds normal (or about the same as when it worked), but it's nust not heating, then it is probably a bad magnetron tube.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Aug 18, 2014 | Whirlpool Microwave Ovens
Sharp r2103j microwave lights on doenst heat up
No heat, but unit seems to run normally in all other ways - possible causes: failure of high voltage rectifier, shorted high voltage capacitor, magnetron failure, power transformer open/shorted winding(s), thermal protector open, or no 120 v supplied to power transformer.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/david_29ad5d1dd86564b0
May 04, 2014 | Sharp R310J 1200 Watts Microwave Oven
GE spacemaker XL1400
what problem do you have mention ? attached is there a list please indicate. God bless you
    No Lights or Power, Unit seems Dead The voltage to the unit is good.Lights come on, but can not program unit, Touchpad dead
    Microwave Runs, but no Heat Turntable rotates, acts like it is heating but doesn't. This is the big one, many possibilities.
    Microwave Runs, Heats, but turntable does not move
    Microwave is arcing
    Microwave Vent Hood is not working Over The Range(OTR) Models.
    Microwave Stove Light not Working OTR models, light bulbs good.
    Microwave overheats and keeps turning off
Oct 01, 2012 | Microwave Ovens
My microwave oven is not heating food
HI..there is a heating filament of an oven MAGNETRON..it s responsible of producing heat to the oven..possibly this is defective ..this filament must be replaced by a new one..theres no problem with the motor cos it runs the table power and light button seems working..HOPE THIS HELPS
Jul 07, 2011 | GE JVM1630 Microwave Oven
Does not heat anymore, power is going to unit, the clock, and fan work, light still works but it will not heat and makes a low growling sound when we try to run it. Help!
What you are describing is a problem with the magnetron and it has become faulty, that is the main part that heats the food, the growling sound indicates it is loading down the power transformer that energizes the magnetron. The repair cost will not justify the expense "costly" replacement of the microwave oven "cheaper" in the long run.
Jan 21, 2011 | Kenmore 80412 Microwave Oven
Samsung microwave -the electrical panel runs, the
it sounds like it one of your micro-switches inside that control the power to the doors, if one of the switches is bad, it would cut the power , the panenl will light, the turn table will work, the fan will turn on , but you will not get any heat at all, micro-switches run depending onthe unit from 5-10 bucks, when you open the unit you will see the one that is bad, is usually bent or the connector might be burn or melt, good luck..!
Nov 14, 2009 | Samsung MU3250W Microwave Oven
Sharp carousel microwave model # 508ak has power but does not heat food when you press the start button. thanks in advance!
9 times out of 10 this is usually this is a bad magnetron, the other time is sometimes a bad high voltage diode. See components section. Q - My microwave is running and sounds like it is working but will not heat up anything.
A - Many thing can do this but, common things are....loose high voltage wire.....poor solder joint on board.....magnetron.....power relay.....
Q - The microwave display counts down and the inside light is on, but nothing is heating and the fan is not running.
A - This most commonly is a bad door switch, other possible problems are a faulty relay or solder joint on the power module, but a bad door switch is most common.
thanks.
Jul 11, 2009 | Sharp R-510HW Microwave Oven
Microwave not heating...power going to it...turntable runs, lites on...no heating
If you have the experience with discharging a capacitor and you have a (VOM) Volt Olm Meter. Unplug microwave, discharge capicitor, and check the resistance of the two thermal cut-off discs by removing the lead and set VOM to RX1. If you don't get a reading of zero, replace the discs. If you found any of these suggestions helpful, please rate my solution. D. Lange
Apr 26, 2009 | Microwave Ovens
If we close the mircowave door the units start to run by itself. - it will not heat, but the light comes on and the turntable rotates it will not stop until we turn the power off - when power is turned...
i think you have a welded controller, either a digital one or a mechanical one. microwave won't run unless you switch it to run. the door switches are safety switches to turn off the microwave once you open the door. if you have a digital controller, you could have a welded relay, if you have a mechanical timer, it could be a welded contact at the timer. another thing is that it should heat what ever you are heating. if it is not heating, check if it has a fuse and if it is busted. some fuse are installed to protect only the magnetron that is why the light and turn table are still running. if there is no fuse to the magnetron, then check the diode from the capacitor to the ground. it could be open. if not then you can have a bad magnetron. i hope i was able to help.
Jun 24, 2008 | LG Microwave Ovens
Slow heating; sluggish fan; low interior light
The main power supply may have a fault. Also, the HV supply may be weak at the same time.
Jerry G.
Apr 01, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Emerson MW8106W Microwave Oven Logo
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
