Question about JVC Audio Players & Recorders
JVC CA-FSX5 error message CD 7.4 V 15 - JVC Audio Players & Recorders
2 Suggested Answers
  • 17130 Answers
SOURCE: my CA-DXT99 jvc component appears tray error
The fault could be the wrong alingment or the failure or displacement of the mode switch or sensors int he tray settings. If the trays set bacl after few times then you will have to check for dirr tin sensors or failure of the optocoupler sensors. However if the tay never sets right, then the mechanism has a wrong mode settting which might have happened as it jumped over.You will have to take the entire tray mechansim and set them. However this is quite tricky and you will have to set from the begining of the resting of the tray to the noemal setting of the cd drive mechanism. If you have not attempted this sor tof job I would not advice you as the logic settings of the tray must be thought of. However if you can try set the tray and use the load motor drive to trun externall and see that the mechanism works from the outside. If so set it back to the circuit and test. Please see if any tray has been damaged and will result in the same fault.Hope you do this right. Good day
Posted on Jul 26, 2010
I have a JVC CA-MXB5 stereo. As soon as you push the cd button error shows up on screen. Everything else works.
If you have a CD loaded, and you get that error, it means the laser can't detect focus on the CD.
If the laser detects focus on the disc but the turntable motor doesn't spin up you still get that error. Sounds like the laser is the problem in yours.
Oct 04, 2009 | Audio Players & Recorders
Mini hi-fi JVC CA-FSX3 stops after power on
Well, I disassembled the unit carefully. And I've found that diode SR303 was blown. It's very easy to find near huge pulse-code converter chip. This diode is used at power supply stabilization for amplifier that has a D-class i.e. pulse-code amplifier, and for CD part. Testing of this diode confirmed that it's dead. After a couple of days received the diode from shop, is very cheap. Changing the diode recovered all the functions of the unit. Now it works fine.
Resume: The diode was burned as a result of incorrect connection to line input. The owner of the unit haven't seen that a volume level was at maximum. The connection of line input overloaded the maximum current capacity of the diode and it was blown. As for it, I've seen that in that circuit in reality must be used a stabilization chip, that is not so cheap like a diode. I think it's a constructor's error to change the chip, that is overload protected, to a simple diode.
Waiting that my info will be useful because it´s a most vulnerable part of JVC CA-FSX3. And don't overload the amplifier!
Sep 06, 2009 | JVC FS-X3 CD Shelf System
Downloading video problem JVC GR D90
Should be able to get the Instruction Book and necessary driver at:
May 24, 2009 | JVC Cybercam GR-D90 Mini DV Digital...
"LEVEL" error message
Hope this link to the user manual will help you with your problem..
Good Luck.
Feb 10, 2009 | JVC KD-G720 CD Player
Error message No Disc
Unit has bad disk t-table motor
May 06, 2008 | JVC MX-J200 CD Shelf System
CD player not turning
The laser is damaged/worn out. It would be cheaper to purchase a whole new unit, instead of repairing that one.
Sep 20, 2007 | Audio Players & Recorders
32 people viewed this question
Top JVC Audio Players & Recorders Experts
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
