Question about Pioneer Car Audio & Video
SUB PULLS IN INSTEAD OF PUSHING OUT
I HAVE A PIONEER GM-7300M HAS WORKED FINE FOR A LITTLE OVER A YEAR NOW ALL OF A SUDDEN WHEN THE BASS HITS SUB SUCKS IN INSTEAD OF PUSHING OUT AND VERY DISTORTED
    Scholar:
  • 92 Answers
In a normal subwoofer it does pull in and push out to create the sound. It could be that the voice coil is damaged (by over excursion running it into the magnet) and it now can't push out past a certain point hence looking like it's pulling in. Push in on the woofer with your hand, do you hear a scraping sound? If so it's time for a new sub. If not, take it out of the enclosure and push out on the cone from the inside, scraping now?
Another test for loose voice coil windings that I find works is the hold the sub up close to your ear and bang on the magnet with the palm of your hand, if you hear faint rattling or anything other than a low "thud" sound then there's is some sort of mechanical failure within the woofer............also time for replacement.
If all seems good at this point, try connecting it to a different amplifier, the sub itself may be fine. If you've lost one of the amplifier rail voltages the sub will pull in but not push out...(or vice versa depending on if it's the positive or the negative power rail)......and yes, it would sound distorted.
Posted on Oct 09, 2008
Bass cut off when volume is too high
When an amplifier shuts the Bass off that means its going into protection mode otherwise it will burn out the outputs. One way is to turn your gains down, Pioneer amps are not the best amps for bass out there, they are more for car speakers, I personally wont use a pioneer amp to run my subwoofers especially if they are hard driven subs like JL , Kicker Solo's and MTX subs. But for now just turn the gains down to 3/4 and that should help u, you can also install a fan to keep your amp cooler, if this never happened before in 5 yrs and now it does then that means your amp is just tired and the inside components are overheating easily, thats common with Pioneer and Sony amps.
Good luck buddy.
Lex...
Jun 12, 2010 | Pioneer Car Amplifier GM-5100T - 2CH 760...
I have a few problems. i have 2 amps and 4 subs. first problem is when i connect one amp to my speakers it just hisses and crackles. this never happened before. when i turn up the gain to try and get...
The first amp, sounds like there is straight power going through the gain instead of it being limited. The second amp...hook the other subs up to it and see if it sounds ok. If so, then the subs are messed up. If it sounds the same, make sure the subs are connected correctly.
Oct 21, 2009 | Car Audio & Video
I got a 800 watt amp from my friend and he didnt have instruction
What's the exact model of your amp? For taking the higher frequencies/treble out of the subwoofer, the amp should have a little button on the side that says "Hi Pass" or "Low Pass" or maybe an adjustable knob-thing that says "X-Over". These will set a cut-off frequency for your sub output. Some amps don't have this feature, but many do.
May 18, 2009 | Pioneer GM-7300M Car Audio Amplifier
Need help
It should be better to use the Pioneer GM-7200M Amp with your subs.
For 8 ohm setup hook up this way:
Amp out+ to Sub1 +
Sub1 - to Sub 2 +
Amp out - to Sub2 -
For 2 ohm setup hook up this way:
Amp + to Sub1 +
Sub1 + to Sub2 +
Amp - to Sub1 -
Sub1 - to Sub2 -
Nov 09, 2007 | Kenwood KAC 6201 Car Audio Amplifier
Need help
u should connect at least six 12" subwoofers (preferably 1000W each) to that pioneer amp of yours. Crank it up and enjoy. Your amp shouldn't cut off now. If it does cut off, you should change the fuse on your amp to a higher ampere.
Oct 30, 2007 | Pioneer GM-7200M Car Audio Amplifier
Pioneer GM-7300M 800 Watt amp will not power on
This may have a different type of triggered turn on wire. On some of the older Pioneer amps (and maybe some new ones) the trigger wire would SUPPLY B+ TO THE RADIO and when the radio was switched on the amp would sense a current draw on that wire and would then switch on. Unlike most common amps which sense the presence of B+ on the trigger wire supplied by the radio and then turn on. Look in your owners manual to see kind of turn on system you have. If you don't have an owners manual then perhaps you can download one from Pioneer support. good luck
Aug 23, 2007 | Pioneer GM-7200M Car Audio Amplifier
No bass at higher volume
Your battery should be fine! Although the amp might not be strong enough for the sub. All you can do is check the RCA cables from your radio to your amp as these might vibrate loose when you get to 17 volume and also check the monster cable from your amp to your sub asit might have vibrated loose as well.
Oct 21, 2006 | Pioneer GM-5200T Car Audio Amplifier
Car Audio & Video Logo
152 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
