Question about Procom ML060HPA Heater
Heater won't light
Pilot light works fine but regardless of how long I hold down the light pilot light button, when I try and move the control to ON, the pilot light decreases then goes out and the heater does not light.  I have installed a new regulator on my propane tank but that did not help.
    Novelist:
  • 124 Answers
YOU HAVE A BAD THERMOCOUPLE. IF YOU LOOK AT THE FLAME you should see a little match size piece of gold metel connected to a metal tube like then screwed into the gas valve. what happens is when you light the pilot, the gas heats up one end of the thermocouple and the other end changes that heat into microvoltage. the gas valve senses the microvoltage , knows the pilot light is lit then opens the main gas valve. when they go bad they cant send voltage to valve and th valve locks out. you always have to start at off. then depress valve button and turn to pilot and light it. hold button down 3 minutes then turn to full open or main the thermocouples are cheap, call supply houses or service companoies till you find one that will sell you one. unscrew the thermo couple from the valve with a little wrench unwravel the excess tubing , size of a pencil lead in diametor, then the probe part usually slids up through a spring like holder, note position of old sensor before reoming. get end half of new sensor into good pilot flame. reuae old retainers or new ones that come with new t couple.
Posted on Oct 09, 2008
When I try to start my mr. Heater I hold the pilot button down and the starter knob won't do anything? I can't get it to light the pilot, I've only had it a month.
Gas is turned on? Pilot button is in pilot position? Push and hold pilot button down, keep holding it down, push igniter many times, while keep holding down pilot button, keep holding until pilot lights. May take several minutes.
Feb 14, 2017 | Mr. Heater Heating & Cooling
The pilot light won'jt light in my warm morning propane gas stove
If you dont have gas coming thru while holding down the button, you have one of the following; no gas, main valve off, or a bad gas valve.
Jul 21, 2017 | Heating & Cooling
How do i light the pilot?
Turn the Gas Control Knob inside the heater compartment from OFF to PILOT. Push in the knob and hold it, at the sametime push the ignitor button (will probably be a Red button). Once the pilot lights, continue to hold the Control Knob down for one minute. Then ease off of it. If the pilot stays lit, turn the Control Knob to the ON position. The burner should light, if the Thermostat is set higher than the ambient temperature in the house. If the Ignitor button doesn't work, you can match light the pilot. Just be careful and follow the instructions above, once it's lit.
Hope this helps solve your problem.
Feb 23, 2011 | Williams (5009622) Ceramic Gas Wall...
How do you turn the pilot light back on? This is an older model, probably about 10 years old or so.
Move the gas valve knob to the PILOT position and press down on the knob. You will be pressing down on a spring loaded safety magnet. Now light the pilot and keep holding down the knob till the thermocouple gets hot enough to produce electrical current and hold that spring loaded magnet in. This is your safety device. If the heat gets too hot the furnace has a fuse in line with that magnet.
When the pilot stays lit by itself without you having to hold down the button then advance the knob to the ON position. Then go to the wall thermostat and turn on the heater.
HOW IT WORKS: WILLIAMS WALL HEATER
Nov 11, 2010 | Williams 6508732 Gas Heater
We dont think our cylinder is on we have just moved in and have no hot water
The question is? I'll assume you cylinder is the water heater, right?
On the heater (water) you will find or see the red controls and a sheet metal cover over a hole. Remove the cover and this is where you light the pilot light. Press down on the red dial and turn it to pilot. In that position you will be able to press the red button . Geyt a long match or bbq lighter, then, holding down the red button dow for a minute or so and place a match or lighter into yhe area where the lines go The flame will catch the gas and lite the pilot if yo simply move your glame around. When the flame catch on the pilot, continue holding the button down for sveral minutes until the buld the flame isheating gets hot. Then release the buton and turn the main dial to on. The main burner should fire up. If not, and the pilot goes out, repeat the process. The bulb in the pilot flame is a thermocoupler that shuts all gas off if it doesn't detect a pilot flame, so hold the button down longer. If the pilot goes out when you release the button, The thermocoupler is no good and needs replacing. Good Luck_Ned_
Oct 31, 2009 | Rheem 80 GAL ELEC TALL Water Heater 6YR SC...
From the ignitor button there is a wire, what should it be attached to?
It should be attached to a spade connector on the pilot assembly. There should be a metal rod there that the wire goes to to provide the spark to the pilot light.
Oct 03, 2009 | Cozy Enclosed Front Console Heater 70,000...
Pilot Light will not remain lit
Try this, turn the black gas ****, on top of the control box, to the Pilot position. Set the temp. control on the front of the box to the desired temp. Then, hold a match or whatever else you use to light it, next to the end of the pilot, then, while holding the match to the pilot, press the reset button on top. When the pilot lights, continue to hold the reset button down for about 1 minute. Then, after a minute, turn the gas **** to the ON position, then it should remain on.
Jan 20, 2009 | Water Heaters
ProCom blueflame heater pilot light difficult to light
You pilot ignator is plugged.I take a small wire and run it in the hole every year and I also Blow the heaters out real well with air.THis has always worked far me.I need a phone number or email address to Pro Com because i'm having problems with a new one i just bought and I can't find the papework.Could you pleas eif you have this info email it to me
Good Luck
Jay
jaycalk@yahoo.com
Jan 07, 2009 | Procom (177653) Utility Heater
Pilot light won't stay lit on convection heater.
replace the therocouple. next year do not turn the pilot off
Nov 24, 2008 | Clairion Convection Heater - HC-1500
I need to know how to light the pilot on my somewhat old water heater. The model is called the challenger 5 the model number 153.331471
On these older gas water heaters there is a gas control with temperature selection and below that is a removable cover. Once you remove the cover you can gain access to the pilot. You must rotate the knob on the top of the control to the pilot position. When in the pilot position, hold the red button down and light the pilot. Continue to hold the button down after the pilot is lit for about one minute. If when you release the red button the pilot goes out, try one more time. If it goes out again after releasing the button your thermocouple is bad and must be replaced. The thermocouple generates a millivolt electrical current that hold the gas valve in the operating condition when the pilot is lit. When the pilot goes out there is no heat to generate this small electrical field.
Jun 08, 2008 | Kenmore Heating & Cooling
Procom ML060HPA Heater Logo
338 people viewed this question
Top Procom Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Procom Heating and Cooling Expert? Answer questions, earn points and help others
