Question about HP Pavilion ze2000 Notebook
Surface mounded capacitor ze hp
Hi did the laptop power on at all with any light as i have the same laptop here with the same symptoms and wish to try and change the surface mounded capacitor but i have a limited amount knowledge to check the short. should i get myself amili volt meter test it it
  • webbkiddy Oct 11, 2008
    thanks for the advise i think i am ok as i have tested the power supply and it seems faulty to start with
    I have orderd a new one and will keep u posted when it comes
  • 135 Answers
No, don't mess with the surface mounts.
You don't even know their value!
Posted on Oct 11, 2008
Does nothing when i try to switch 'ON'. i press a few keys on the board and F12 light comes on
That is the classic symptom of GPU damage caused by overheating. Seek a GPU re ball repair.
Nov 07, 2015 | HP Compaq Presario CQ57 Laptop
Hi, when i switch on my LCD, screen is coming blank, with clear sound and after few seconds the LCD is switched off automatically.
In that case or symptom,the problem is either come from the power supply or back lights inverter board.The screen or the display is totaly black when the back lights is not working. The inverter board have blown surface mounted fuses that my cause of shorted transistor,transistor or leak capacitor.Thanks.hope it will help you..
Sep 03, 2011 | Panasonic Viera TX-32LX70 32 in. LCD TV
My CQ61-411WM doesn't boot anymore. Symptoms:
Hi
If the graphics card was intact, the external monitor test would have given you an image.
Unfortunately, this seems like a graphics card problem common to this manufacturer (google HP Compaq Notebook Graphics Problems).
This fault can be repaired only by specialist laptop repairers with specialist tools.
The repair is called Reballing the Ball Grid Array.
Reballing has a marginal success rate and even if successful, the fault can reoccur. A typical professional repair warranty would give you 3-6 months post-repair warranty.
Sometimes the surface of the graphics chip is too damaged to repair.
This repair can be expensive as it may involve several time and labour intensive rounds of disassembly, repair, reassembly and testing.
If you do opt for repair, ensure that the repairer is a specialist, properly equipped with an Infra Red Workstation, experienced in this specific type of repair, is willing to do a No-Fix-No-Fee Repair and offers a Repair Warranty.
If the laptop's warranty has expired and the repair cost seems high to you, it may be time to consider a new laptop.
Sorry for the bad news.
Hope this helps.
Aug 23, 2011 | HP CompaqPresario CQ61310USE Notebook
Is there a fuse in the laptop. I have power to the laptop but nothing goes on
Laptops do have a fuse near the DC power jack but it is soldered on to the board so it can't be changed. More likely than that you have a bad power jack. If your symptoms were intermittent charging or powering which got worse with time or if you wiggled the power cord you might get a connection it is probably the DC jack. These are repairable but require dis-assembly and some light soldering. If you are uncomfortable attempting that a shop usually charges about $80 to do it. To try it yourself download a service manual for your model, purchase the part (about $10), and give it a try.
Apr 16, 2011 | Computers & Internet
Hi My panasonic microwave nnv672s Inverter has stopped working. It powers on and goes for about 15 secs then stops. when in grill mode it is fine though. what should I do
I had the similar problem with my 667. My model had on the right hand wall a plastic plate covering the microwave emitter, secured by one screw. It is made of plastic so care is needed to remove it. I tried cleaning its surface with a number of methods, but the only one that worked was to take sharp knife edge to the surface ie. literally scrap the baked on material. Care in replacing this plastic shield is advised since it can crack if bent too much.
At first, there was no change in the prior symptoms and it even stopped working altogether. Since the "1" button gets used the most, I tried other numbered buttons and now it seems to be working correctly.
Hope this helps solve your problem.
Sep 22, 2010 | Microwave Ovens
My acer aspire 5315 wont turn on I press button and it lights up as if gonna come on but screen stays blank and then it powers out its only 1 year old help
Maybe the screen has some problems, or try clicking to the power button for some minutes, or Try charging the laptop, or try to change the laptop's battery.
This is all I know, wish it works :)
Jul 16, 2010 | Acer Aspire 5315 Notebook
Avertec 2300 laptop will not start. Have tried removing ram and battery. All I get is a blue power light and wifi light. HD clicks a couple times and cd drive spins if there is a cd in it. Fan does not...
Hi as for symptoms you have problems with you hardware. Basically thats means that one of the devices like harddrive or Video card fail to go through POST test. You can check your users manual for this very symptom
Sep 15, 2009 | Averatec Computers & Internet
My dell laptop does not start
Generally, it is an indication that the system is not receiving power. Here are some possibilities:
  1. Bad AC adapter, not providing any/enough power to start system/charge battery. Try a different AC adapter, see if anything changes.
  2. Bad damaged AC connector on motherboard. If the power connection to system is wobbley and not firm, then the adapter plug may be broken. It is possible to got the plug repaired/replaced but generally this is a motherboard replacement.
  3. A component is preventing system from starting. Remove all customer removable items (HDD, CD Drive, RAM, Modem, Wireless Card & battery) see if system will power on and give any error codes (The lock lights on/flashing) If the symptoms change with the removable parts out, then add them back one at a time and see if the system will turn on. If no change, again, replace the motherboard.
Apr 02, 2009 | Dell Latitude 110L Notebook
Dead Sony Laptop
If power supply is supplying correct voltage, then you do not need power supply PCB.
Try starting the laptop with AC adapter and no battery, if battery is shorting out you may get same problem.
Test the soldering joint on the AC socket and laptop motherboard, if there is a bad soldering on laprop ac adapter socket, you get same symptoms.
If it is none of the above, and the adapter is fine, then it is usually a faulty motherboard.
Nov 16, 2008 | Sony VAIO PCG-V505CP Notebook
Hp power supply failiure
Ive worked on a friends G7000 series laptop, since it had the same symptoms you have with yours.
I tested it on my own(identical) working charger/PSU and still no charging.
After taking the motherboard out, i traced the fault to a short circuit FET (field effect transistor) with the PCB reference of PQ1, located right next to the connector for the DC power jack loom.(short from gate to source) The FET is made by Fairchild Semiconductors and its part number is FDS6675BZ. Being in the UK, i ordered the part from www.farnell.co.uk at a cost of 56pence. After changing this FET(which is there to control power) the laptop is working.
If you are not good with very intricate surface mount soldering, then i suggest you buy the component, take the motherboard out of the laptop(not too hard) and take them both down your local TV repair shop for them to check and change it(tell them the board reference PQ1).. shouldnt cost more than £20 or so been as they dont have to fault find.
Martin
martinkwashere at hotmail dot com
Feb 26, 2008 | HP Pavilion dv6000z Notebook
HP Pavilion ze2000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
