Question about Mitsubishi VS-50803 50" Rear Projection Television
Convergence picture is good but for the red convergence cant be adjusted top of picture has re droop advanced convergence has red lines off at top unable to adjust
  • nolakron Dec 23, 2008
    Convergence starting having problems earlier this year, but would return to normal after a few minutes. This weekend the red convergence failed completely. The red convergence lines droop at the upper left and lower right of the screen and can not be adjusted. XP electronics says $300 to replace the convergence amplifiers should fix the problem 90% of the time. Or, it could be the convergence generator that may not be available anymore. Is there a good way to determine if it is the amplifiers or the generator before I waste $300?
  • Mitsubishi Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jul 11, 2010
My picture is doubled on my toshiba TN50V71 as if there is a shadow behind everything? Please help!
hi, sounds like a convergence issue. try this...
  • Look through your manual. Your manual will always give you the most specific directions for your particular model. Look for an "adjusting convergence" or "set manual convergence" section.
  • Enter the menu on your TV. Use the remote control and bring up the menu.
  • Choose "Convergence." This may be under "Picture Settings," "Function" or "Advanced Options."
  • Select a color. You will have red, green and blue to choose from. Do each one, starting with red.
  • Press "Enter." A crosshair pattern will appear on your screen.
  • Adjust vertically. If there is a horizontal red line visible, press the up or down arrow keys (or channel up or down) to adjust the convergence until the line is superimposed on the horizontal-center line of the white crosshair.
  • Adjust horizontally. If there is a vertical red line visible, press left or right (or volume up or down) to adjust horizontally. Do this until the line is superimposed on the vertical line of the white crosshair.
  • Save settings. It is important to save your settings when you are done, instead of simply exiting the menu.
  • Repeat these steps for all colors.
    good luck!
  • Feb 02, 2011 | Toshiba TN50V71 50" Rear Projection...
    It has tripple vision and looks like a bow tie.
  • good luck!
    Feb 02, 2011 | RCA HD61W66 61" Projection HDTV
    How do you set convergence
    What is your Make and Model number?
    Mar 18, 2010 | Televison & Video
    Conversion-----the red lines are distorted so badly they won't move at all. I've managed to line the other lines up. The top left quadrant has drooped so badly that they will not adjust back. The bottom...
    Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
    • Screen looks 3D
    • TV shuts off after powering on - TV may also make a chirping noise.
    Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
    93a1209.pngCONVERGENCE SOLUTION
    This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
    Feb 11, 2010 | JVC AV-56WP74 56" Rear Projection...
    Have a red line drooping from bottom to top of picture also have color seperation how do you fix this
    These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
    When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
    You can get more information and a DIY convergenece repair kit with instructions from the link below.
    Here are some of the most common problems with these sets...
    Problem #1) Convergence
    Yours may have one or more of the following symptoms...
    *Screen Looks 3-D
    *Colors wont align
    *Screen may look distorted or warped
    *No Audio/Video - TV Shuts down - May also make a constant chirping sound
    Problem #2 - Another common problem is dull or washed out video.
    Your set may have one or more of the following symptoms....
    *Dull looking picture
    *White looking picture
    *Halos around objects
    *Red/Orange looking picture
    bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
    Jan 23, 2010 | Zenith R45W46 45" Rear Projection...
    Color seperation and red drooping line
    You have defective Convergence IC's. It's best to have a service company verify and do the repair if you wish. Normally runs about $250.00
    Jul 14, 2009 | Zenith R45W46 45" Rear Projection...
    Mitsubishi VS50805 Serial # 102718 No red in picture
    Replace the convergence ICs your model uses two STK392-040 Convergence ICs. You can get replacements at the following link with instructions.
    http://servicemanuals.vstore.ca/
    Dec 28, 2008 | Mitsubishi VS-50605 50" Rear Projection...
    Convergence issue
    try fixing the convergence 2 after your've aligned the convergence 1 - the second (accessed via the set up control) let's you adjust on 9 different axis to align the red and blue tubes to the green. you select which + sign you want to adust by pressing the corresponding number for the + ie 1 for the top left, and 9 for the lower right corner.
    good luck (note - you cant change the green only the red and blue, if the whole edge is a mess try moving the image (you need to be in zoom mode, and then access the position adjustment via the pitcure set up screen.
    Nov 05, 2008 | Panasonic PT-47WX49 47" Rear Projection...
    Red/green drooping L top corner
    i have found when samsangs convergence are out of range perfect focus will fail. if the are out of range a technician will try to adjust the set in service mode. store these values and then this will be the base for the perfect focus. If the set has a bad convergence cuircit then they have to be replaced.
    Nov 05, 2007 | Samsung HCN653W 65" Rear Projection...
    Color problem
    Did you try alignment of color convergence in setting up. Try this
    1 Press MENU
    2 Select SET UP
    3 Select CONVERGENCE
    4 Select screen mode ZOOM this accesses the center convergence adjustment.Press set/enter
    5 Use arrow keys to aline the red cross to the white cross.Press set/enter
    6 Use arrow keys to alingn the blue line in the same manner. Once adjustment is complete press MENU to turn the menu off.
    I hope this helps if you cant move the red or blue lines you face the same problem I face. I still havent gotton any solutions to my post about being unable to adjust the red line.You could also call Pioneer's help line 800-421-1404.
    Oct 04, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
    Televison & Video Logo
    129 people viewed this question
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Jaime Hernandez
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
