Question about GE GSS20IEP Side by Side Refrigerator
Compressor and fan not running GSS2OIEPHWW
Had power outage , mainboard was making clicking noise , had burnt spot on back replaced main board , compressor and fan not running , lights everything else OK , no voltage to compressor - Any Ideas
  • curtisjune Oct 26, 2008
    my icemaker makes ice if i put water in manually,however not on its own.
  • 120 Answers
Repl board again and check outlet for proper ground and proper wiring
Posted on Oct 30, 2008
Refrigerator wont run. Clicking noise coming from main board preceded by a short humming noise every several seconds. Unplug for 30 minutes then plug back in and compressor starts up after several clicks...
That condenser fan motor needs to be replaced. You and doing the right thing as far as using a seperate fan to keep compressor cool,buy replacing the fan the compressor will run cooler and click off by being too hot as you have heard/seen.
Find your model number and call your local appliance parts store and see if they have a CONDERSER FAN MOTOR in stock
Gene
Aug 15, 2011 | Refrigerators
Control board clicks every 3 sec. No cooling. No fan or compressor running.
Avanb, I can almost assure you that the control board is the problem. I'm assuming that the interior lights are on, but no fans and the compressor is not running. To make sure, first unplug the temperature control harness. (encoder). If the refrigerator starts running, replace the temperature control board (encoder board. If it doesn't start running, replace the main board in back. To remove the control panel, remove the 2 screws located on the bottom. Slide the panel down. Then just disconnect the harness to the temperature control. Catriver.
Aug 03, 2007 | Hotpoint HSS25GFP Side by Side...
Refrigerator and freezer are not cold. Makes a clicking noise.
Check the starter relay which is next to the compressor behind the cardboard cover on the back. It may be burnt and can't start the compressor. It's on or near the compressor. If it's bad it will rattle when you shake it and may appear burnt.
Nov 17, 2010 | Jenn-Air JCD2290HES Side by Side...
Refrigerator stopped working nothing runs,all lights on, periodically a clicking sound
sounds to me like you have a bad relay on your main control board. It will be located on the back wall of the unit or down by the compressor on older models. The other possible clicking noise would be your starting components on the compressor. You will have to determine where the clicking is coming from and I would start by replacing either the board or the starting components. You could also do a visual inspection on the board for burn spots. Hope this helps. MJ
Jul 30, 2010 | LG LFX25960 Titanium Bottom Freezer French...
My samsung plasma tv went out and it just makes a clicking noise and wont turn on i replaced the power board but it still does the same thing help anyone!
It was not your power board, Thought the same on several repairs.Found out it was the main board. The clicking was the tuner relay. I bet you own a SP-R4232. If so,The part you need is BN41-00574A. Also might be under BN94-00669A. Hard to find. Try Shop Jimmy/Or Encompass Parts. Not cheep tho. Hope this info helps.
Have a happy new year. Todd
Jan 01, 2010 | Samsung SP-R4232 42 in. Plasma HDTV
Fridge is not cooling and making a clicking noise. Checked back panel. cleaned whole pile of dust, fan is running smoothly. clicking time interval has increased, but still not cooling.
Try replacing the compressor relay , which is not expensive , that could be the problem , but if the compressor keeps clicking on and off (overloading) , is probably burnt.
Oct 16, 2009 | Hotpoint HSS25GFP Side by Side...
The compressor is not running and there is a clicking noise coming from the circuit board panel on the back of the refridgerator
You have to replace the main control board . The clicking is the compressor board relay , which the only repair , is to replace the main board .
Sep 11, 2009 | GE Refrigerators
Ge fridge makes a clicking noise fan in frezzer
Main control board bad . The board controls the fan opperation and the clicking , sounds like a relay on the board . Replacing the board should solve the problem(s) .
Aug 05, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a Carrier 38tra048340 ac 4 ton unit outside, heater in attic. Thermostat is Totaline P374-1100. Power went out than back on after a few hours due to vehicle crashing into power pole. AC was running...
Blank screen sounds like a fried thermosat. Abrupt outages can affect certain types of thermostats. Make a jumper wire and jump across R and G. See if you get any action from anywhere. If a fan or compressor kicks in you know you have a burned out thermosat...
Jun 23, 2008 | Carrier Heating & Cooling
GE GSS20IEP Side by Side Refrigerator Logo
103 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
