Question about Husqvarna Garden
Fuel line replacement
Do U replace the fuel line through the small hole under the carburater?? What size hose?? thank you..
O husquvarna chainsaw 36/41
  • Anonymous Mar 13, 2014
    how to replace fuel tank vent on husquvarna chainsaw
  • Anonymous Mar 23, 2014
    Fuel line needs to be replaced
    Problem Solver:
  • 16 Answers
I recommend remove all fuel from the tank. Remove the hose from tank to carb. take the tube with you, when getting new hose.
Posted on Jan 19, 2009
The fuel lines in my Ozito 25.4 cc 305mm bar chainsaw are perished, how do I replace them?
Chainsaw fuel lines are specialized hoses that either need to be replaced with TEFLON hoses of the same diameter, or the specialized rubber hoses that are resistant to gasoline and other chemicals. You should ask at a hardware store and make sure you get a hose that fits TIGHTLY into any holes on the gas tank, and also snugly fits over ant incoming metal or brass lines going into the carburetor.
Oct 18, 2014 | Garden
Easy way to install fuel line and primer bulb return line into gas tank
Chainsaw fuel lines enter the gas tank from holes in top of tank. They are sized for a tight fit to prevent leakage. Make it easy on yourself when pushing the line through the tank by cutting a long lengthwise taper cut with razor knife 3 inches or longer to easily feed through that tight hole. Once started you will then have to grab it through the gas cap hole with needle nose pliers, then cut the tapered end flush and add fuel filter. Readjust inside length by pulling from above, then cut to length to upper carb fitting. If connecting to primer bulb a filter is not required and make sure the line goes to fitting on primer bulb marked tank.
on Nov 17, 2015 | Fuel Line & Primer Bulb Repair Kits 2...
What is the raio for e240 chainsaw husquvarna
All Two Stroke Engines will use a 50 to 1 Ratio using Today's
Gas . I would try to to put Premium 100% real gas with all your small engines . The Ethanol blended fuels play hell with the carbs , hoses ,
and internal parts like pistons and valves . Mix enough for about 2 weeks , after that the fuel starts to brake down , this will save you time and money . also Head aches !!!!!!!!!! Hope this helps , Grant
Aug 11, 2014 | Husqvarna Garden
Install new fuel line
Ryobi makes a great little kit for fuel lines its not expensive and it fits most small engines (less 46 cc) like weed whackers and chain saws , it includes a "TOOL!!!" for feeding new fuel lines thru and of course has new fuel line too , this tool is invaluable in getting these things to fit , and its got some neat directions on how to use it , best of all it fits lots of makes and models too
Apr 29, 2014 | Poulan 18" Wild Thing Chainsaw
Poulan Woodshark 1950 14" Chainsaw Family: WPWES
Checked all the parts lists, they seem to use the same primer through all types no.s part no. 530047213.
Jun 24, 2011 | Poulan Garden
Fuel line in tank broke off need to know if fuel tank can be taken apart to replace hose and if so how
No the fuel tank is part of the case. The fuel line needs to be pushed through the holes. The supply line goes through the big hole on the left. And the return line goes through the small hole on the right hand side.
It is tricky getting the lines through these holes, It helps to use a small pick or punch to push with, then I use a hemostat to reach inside and pull the lines in. Use bulk line and dont cut it until you are happy with the length. The supply line ( the one with the filter) should extend outside the fuel opening. The return line just need to enter the tank about an inch or two.
Hope this helps
Nov 12, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Fuel Lines - 25cc Craftman weedwacker
Your Craftsman Trimmer/weedwacker:!retrieve.pd?modelNumber=358795591+&pathTaken=partSearch
Best Poulan Engine Match (probably real manufacturer):
My decisions are being driven by my experience with Poulan chainsaws. Small hose in tank (long enough to reach all corners), filter on bottom, connects to lowest connection on carburetor. Small hose on upper carburetor connection to small fitting on primer. Large hose from large connection on primer through largest tank hole, roughly mid tank long. nothing on bottom. I suggest you leave the 2 connections on the carburetor long enough they can be swapped (just in case) then try it. if no go swap them.
Typical fuel system and a suggestion or two:
This is how I would configure it if a chainsaw, doubtful they would do something completely different. In defense of Jerry, he knows how it should be done, clarity of instruction could use some help. Good Luck. HTH
Feb 24, 2010 | Craftsman 25cc Gas Line Trimmer
Fuel line positions ?
The longest fuel line, which has the filter attached to it, goes to the brass fitting furthest from the primer bulb. The short fuel line goes directly under the primer bulb. Which hole to put it in doesn't matter if the lines are the same size. Just choose the shortest path for each. However, if the lines are different sizes, then the longest line (smallest in diameter), goes in the smallest hole of the tank.
May 25, 2009 | Ryobi 15" Electric Factory Reconditioned...
Fuel return line ;is it the same size or smaller than feed line
diameter of return is smaller and avaiable at the dealer or model car-airplane shops
Dec 09, 2008 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Garden Logo
351 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
