Question about Kenmore 62602 Electric Dryer
Dryer will not start.. Here clicking sound when i push start button but nothing happens
Dryer just stopped working... Dryer was set on high and lint screen was full. Dryer will not start. Checked the heater coil which I changed less than a year ago it is fin all connections good. I here clicking noise when i push start button but nothing else..
  • Anonymous Oct 11, 2008
    I cleaned all the lint screen and the back and it still wont work.
Did you clean the lint screen and replace? Also - all lint should be cleaned from back of dryer and the duct...many dryer manufacturer have safety sensors that will not light dryer due to there being too much lint, not enough air flow...(safety feature) ...
Posted on Oct 09, 2008
Dryer was working when I left, came home clothes were dry, but now will not restart. Pushing start button does nothing. Light is on in tub when I open door.
this sure has all the suspicions that it's the thermal safety switch , (1) it worked on last load
(2) nothing happens when start is pushed
( 3) tub light works ok
both gas and electric models have one , and they both do go bad , the switch is mounted usually at top of air outlet tunnel on back of dryer , some do have reset buttons , but rarely do they trip for false reasons , something musta happened to cause a high heat build up in dryer ,Lint build-up is most common reason I can think of
May 18, 2015 | Dryers
What is the problem with my dryer?
The motor starting circuit is failing. Confirm this by giving the drum a push start when it hums. Most likely, the centrifugal switch on the motor is sticking (due to lint buildup) or broken. It has a mechanical component that operates an electrical switch. Check the mechanical operation, then check the switch. Also, check that the motor electrical connector is seated completely.
Apr 02, 2017 | Whirlpool Dryers
I have a Bosch 500 Next series dryer. The dryer now is not working. The lights are on, and they give esitmated times for each drying setting. But when I click start, I hear 2 clicks, and nothing happe
Most Bosh dryer have a high limit sensor inside. Very easy to fix. disconnect power, remove back cover. there is lots of screws. usually torx head. you will see at the bottom of the dryer from the back side that there is 2 wires going to a round black "snap disk". there will be a bottom in the middle push the button in. if this dose not fix your problem you should get a in to fix it.
Jan 21, 2014 | Bosch Nexxt 500 Dryer
Maytag dryer 2003 was working great I took one dried load out put another in and started the dryer. Working just fine then I found a wet garment that I dropped so I opened dryer door added this item...
When your dryer won't start, it could be a number of problems from a broken door latch or start switch to an exhaust duct blocked by lint. It could even be a tripped circuit breaker or blown fuse.
The first step in troubleshooting any electrical appliance is to ensure that it is plugged in and receiving power. While dryer plugs do not come loose easily, it can happen.
For more troubleshooting tips, read Dryer won't start for possible causes, signs to look for and things you can do. I hope this helps!
Aug 03, 2012 | Dryers
I have a Maytag PYE2300AYW. Push button but nothing happens. Had breakers to house checked and all good.
Dryer suddenly stop working when pushing start button (knob will make a humming or ticking kind of noise but won't turn on. I cleaned and check the outside exhaust and lint screen passage. Nothing is helping. help
Jan 08, 2010 | Maytag PYE2300AY Electric Dryer
Press start button and dryer will start and stop , if you press start button again nothing happens , if you unplug dryer and plug back in it will try to start again and stop
Howdy: The motor could be popping it's breaker once the start button is pushed. When unpluged the motor resets and the cycle starts over. But also the dryer thinks the element is too hot and resets the safety switch. The temp thermistor (overtemp sensor) could be clogged with lint or open circuit. Not easy to diagnost. Do you smell burnt wires or lint? Check to be sure the door is completely closed. It may think the door is open and not start. Doug
Dec 09, 2009 | Maytag Dryers
My Kenmore gas dryer stopped in the middle of the time. When I pushed the start button, it buzzed, but the dryer didn't start. I waited to make sure the dryer hadn't overheated, and then I pushed the start...
sounds like the mtor over heated and stalled out . it will do it again . best to delint motor this will help to keeeep it cool and may prevent a lint fire . mm
Dec 03, 2009 | Dryers
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Dryer won't start.
possibly the starter/hold relay or the timer itself. ensure the door is shut properly aswell.
Mar 13, 2009 | Dryers
Bosch Dryer lint filer warning
The Bosch Dryer has a temperature probe in the heater exit and in the exhaust area visible when you open the door. If the temperature difference between the two gets to high, the lint filter is assumed to be plugged and the alarm goes off.
It seems that the temperature probe at the heater, can end up with a faulty connection to the control panel over time due to corroded contacts or lint build up. When this happens the control panel thinks the filter is clogged and it may also not turn on the heating elements properly. Remove the back cover over the heating element (12 screws) and then remove the one screw holding the red wiring connection to the dryer body. You can then wiggle out the wiring connection and clean / unplug and replug in the connector for the sensor. (plug with two small wires only). A little hard feeding the connector back through the hole so take your time and don't damage the wires). Should all work again. May want to inspect inside the heater at same time and make sure the overheating switch is not tripped. ( press in the red button).
May 21, 2007 | Bosch WTMC3510UC Gas Dryer
Kenmore 62602 Electric Dryer Logo
425 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
