Question about Gaggenau ED 220/221 Electric Single Oven
Steam ovenFault codes
My steam oven is at it again. I have a gaggeneau ED221600/01 steam oven which is now out of warranty. I was getting an error code of F70. Since it's out of warranty I opened up the side panel and I think I found the issue. There a reservoir that's leaking, it looks like the plastic melted where it attaches to a clear hose coming from the top. I dried up the spilled water took the reservoir out and removed the melted piece with a dremel tool, epoxied up a copper pipe in it's place and reassembled ( the only reason I found the fault is because the part was replaced under warrranty about 2 or 3 years ago) the oven starts now but after a few minutes I am getting eror codes F20 F21 F22 F23 and sometimes F72 comes back. What do the error codes mean. I can actually start the oven up after a few minutes but it shuts down Please help
  • brianmichon
    brianmichon Mar 11, 2012
    Hi
    I have an out of warranty ED 230 Gaggenau steam oven.
    It too had error code F70 and I called a profession to repair it.
    They informed me my reservoir was leaking as well and that there is no factory replacement part.
    Two questions: did you fix of the reservoir end up working?
    and
    Seems like this is a systemic issue and I would not recommend anyone spending the amount of money these things cost on a product where the manufacturer doesn't make replacement parts.
2 Suggested Answers
  • 414 Answers
SOURCE: we have an Gaggenau EB 290 oven and the error code
F23-relay electronics not selecting. There is either a fault with the pcb or a loss of continuity within the ribbon cable. Unfortunately, I think you are going to need an expert to look at this to confirm.
Sorry I cannot be of more assistance but some faults do require a physical check from a professional and cannot always be sorted out from a distance.
All the best.
Posted on Jul 13, 2010
Neff Oven B58VT68 Error Code E5116
check with the manufacturer .
May 19, 2016 | Neff Ovens
Unable to remove blown Blanco oven light bulb-stuck fast
I boiled the kettle, added the hot water to a tray and placed it in the oven, shut the door then left it for 10 minutes so it steams up the oven (make sure power is off first). Do the same again. Then get a multi grip spanner and place a kitchen rag over the cover and turn to the left. It does take a bit of force depending on how stiff it is, but the steam will loosen the cover. The steam also cleans the oven quite a bit too!!
Mar 04, 2013 | Blanco Ovens
We have a westinghouse wall oven PON783 and the error of F08 comes up on it regularly not allowing us to use it. It now turns on & off by itself and personally i reakon its dangerous. What needs to be...
Hi Paulahogan_1, We have had the same F08 error code with our Westinghouse oven. The repairman said its because of two holes drilled in the upper casing of the oven which allow steam to get through to the motherboard - messing with the thermostat I think. The quick fix was pulling out the oven unit by undoing two screws, then undoing two more screws to lift up the motherboard, and filling the two holes with silicone. However, the steam coming through over the last year or so has caused some corrosion of the motherboard, so they're going to replace that given that the oven's still under warranty. Sounds like your oven might have the same problem, but may have suffered more corrosion over time, thereby messing up the controls? Good luck! Hopefully you've already had it fixed by now :)
Jan 23, 2011 | Ovens
Error code On Miele Steam oven - oO
o O means that the unit needs to be descaled. See your owners manual for the procedure. If the unit displays O - - o, the safety lock has been activated. Again, see your owner's manual.
Feb 01, 2010 | Miele DG155-1 Steam Oven Single
Thunderclap. no power loss. Our Bosch steam oven
I read a similar story from the site where an owner waited 15 minutes before switching the machine on again. That worked. A mystery!
Oct 26, 2009 | KitchenAid 30 in. Architect II Series 4.3...
Error message F7-EO
turn the circuit breaker off for about 15 mins. turn it back on and it might reset itself. let me know if it works!!!
Apr 05, 2009 | KitchenAid 30 in. Architect II Series 4.3...
Hot steam from oven
your oven does not generate steam, only pulls moisture out of what you you place inside of it, poultry being the highest moisture content, i would look into what you are cooking
Nov 18, 2008 | GE JGRP17 Gas Single Oven
Gaggenau Ed 220/221 Error Code F 70
I had the same fault F70. Poured several liters boiling water no result. I decided to take the oven out the kitchen and put on the table. Be carefull, its edges are sharp. You need to disconnect water supply, first close the tap, then remove the water pipe from the oven by hand. Remove also the drain pipe from the sewage connection. You cannot detach it from the oven. Unplug power supply. Then start unscrewing the top panel. Once removed you can unscrew also the side panel left side (by looking at the oven from the front door side) and finally remove the back panel. You will need a special screw driver as the screws are star type.
I found out that there was some little water on the bottom panel of the oven. There is a safety sensor which is in contact with the bottom panel on the left side of the oven near the electronic board.
If this get wet, the faul code F70 appears.
Also some water was in the hole of the level sensor in the pump chamber next to the other sensor (white plastic box)
So dry all the water with the help of kitchen paper and finally with hair dryer.
Put back all teh parts and voila', it works again.
Feb 20, 2008 | Gaggenau ED 220/221 Electric Single Oven
Gaggenau ED 220/221 Electric Single Oven Logo
324 people viewed this question
Top Gaggenau Ovens Experts
Dennis Boxerman
Jaime Hernandez
ashburton
Are you a Gaggenau Oven Expert? Answer questions, earn points and help others
