Question about LG LRE30451 Electric Kitchen Range
Controls I have a LG range that the controls are not working. It burner controls will work then the next minute will not work. Some will turn on but the up and down arrows will not work to raise and lower the temp. Last week the burner would not turn off. I had to trip the breaker to shut it off. Thanks,
  • 4 Answers
If you take the sheet metal backing off the top portion of your range, then un-seat and re-seat the two blue wire ribbons, to try to get a better connection...you may find you have success. try re-seating others as well...typically a loose connector...worked for me...
Posted on Aug 24, 2010
Burner control not working
Hello Tom, thank you for your post!
I understand the burners on your Frigidaire range, FEF336BC, continue to stay on. Try resetting the unit by either unplugging it or flipping the household breaker to the off position. Wait approximately ten minutes and then turn on your range. If these troubleshooting steps prove ineffective, you may wish to contact a professional as your range may possibly have a potential wiring failure, faulty EOC (electronic oven control) or burners.
Nov 26, 2013 | Frigidaire FEF336BC Electric Kitchen Range
I have a whirlpool GW395 gas stove with a problem. When you first turn it on it lights, it will stay lit for about 45 seconds then the burner will go off , after you let it set for about 45 seconds it...
The usual problem with these ovens is the oven burner itself. the burner will click 3 times and usually lights but after a few minutes shuts down and will no light again until you reset the control. If this is happening then try replacing the oven burner. It comes as one unit the burner assembly and electrode. Part # 8191123. If this doesn't work then it coould be your spark module unit. This is about twice the cost or more.
Dec 01, 2012 | Whirlpool GW395 Gas Kitchen Range
The heat control on one of my burners on my smooth top range doesn't work correctly. The burner is only on when control is turned all the way up, lowering the control turns off burner
the burner; control/switch is bad /unplug range ..pull knob off burner control to see srews..remove back panel on range..1/4 inch srews are used ....look at all them wires an switches ..wow ..locate the bad switch ...buy a new switch from appliance parts store /or one from a used appliance store ..make sure you have the make /and model/serial # off of the range... to get the right switch ...install switch.. remove one wire at a time when installing switch or wright down how it is wired ...let me know ..good luck/joe/
Aug 26, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Range top front burner will not shut off, stays on high, back burner up button does not work and timer does not work. Even though it was fixed in Feb of this year LG will not fix it again
I have the same problem with the LG LSB5682SW Electric Range - Font Left Burner will not go off / stays on high. This is very dangerous. LG customer service is horrendous. I think it is time for a recall before someone's house burns down!
Jun 30, 2010 | LG LRE30755 Electric Kitchen Range
LG lre30451S burner will not shut off. It is stuck on high and the only way to get it to go off is to flip the breaker. When I flip the breaker back on the burner goes back to high. Thanks
I had the same problem with my LG front left burnr. Look at the back of your range there should be schemetic for your power control board. look for defective burner wire going into relay. There should be 5 relays in rows. Relay is the problem. I had the same problem with my front left burner stuck on high.
After replacing relay everything works fine.
Mar 02, 2010 | LG LRE30451 Electric Kitchen Range
Maytag oven will not get hot
the ignitor is bad, the ignitor opens the valve when there is enough amperage. the ignitor isn't pulling enough to fully open it
Sep 08, 2009 | Maytag MGR5870 Gas Kitchen Range
LG Electric Range Oven Keeps Shutting Off
When you say "Just shut off" do you mean the circuit breakers would trip, or fuses would blow? If so, I would have an electrician check that the circuit is properly fused/breakered and wire sized for the amount of power required by the oven. If the installation directions say it needs a 50 amp service, it better be a 50 amp service.
If shutting off is just something within the oven, then get LG back out again, and let us know of what they say is wrong.
Jan 24, 2009 | LG 30 in Kitchen Series Dual Convection...
All my burners arnt working! HELP!!!
There is a cooktop PCB (power control board) which is separate from the oven. Perhaps that is the problem. That board is located behind the cooktop control membrane panel.
Oct 24, 2008 | LG LRE30755 Electric Kitchen Range
Ornery Oven
Hello mary Jenkins,
Here is a link to the service manual for your stove http://136.166.4.200/contents/Range/LRE30451/LRE30451_Service_Manual.pdf
page 49 and up discuss keypad operation an from the sound of things, yours need to be replaced...
When buying LG products, ALWAYS buy the extended warranty ! They had a great reputation but to be honest, from my experience... they aren't all that great.. Many component related issues and service requirements... Hope this provides some incite... Good Luck
Sep 22, 2008 | LG LRE30451ST Electric Kitchen Range
Kenmore electric range 911.9369181
F8 Failure of Electronic Range Control (ERC) Replace Electronic Range Control/Clock (ERC)
Dec 01, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
LG LRE30451 Electric Kitchen Range Logo
228 people viewed this question
Top LG Kitchen Ranges Experts
JP Services
JP Services
Dan Webster
Dan Webster
Oloyede Monsuru
Are you a LG Kitchen Range Expert? Answer questions, earn points and help others
