Question about Dell Inspiron E1705 Notebook
Dell inspiron e1705
Won't even turn on. bought a new ac adapter and still nothing.
  • 68 Answers
Anthony,
Could be a failed battery, do you know anyone else with the same model who would kindly let you try your batery in their machine and theirs in yours?
Regards
Nick
Posted on Oct 26, 2008
The new adapter is not compatible with the battery more info: laptop-batteries.com.au
you will need a genuine dell charger and look on your old one to see what pa it is if it says pa-12 then you need the same one again
Feb 22, 2011 | Dell Inspiron E1705 Notebook
DELL E1705 model. When connecting AC adapter, even before pressing power button, led in power adapter goes off immediately. Why ? The power adapter is OK. When connected with Battery, no switch-on.
Since the system is not working ion both battery and the adaptor it could be a faulty motherboard.. Call dell @18006249896 if you are in warranty.. Contact local tech if thr\e system is out of warranty....
Sep 14, 2010 | Dell Inspiron E1705 Notebook
I have no led light on my e1705 when i press it and nothing comes on
Things to check:
1. AC adapter cord, esp close to the brick. Does the green light come on the brick? If not, replace the adapter.
2. Reseat battery. Check the battery charge by depressing the battery indicator button on the battery. Does it have a good charge? If so, then it could be the connection to the mother board causing the issue. If not, then replace the battery.
3. If both the battery is good and the AC adapter is good then you are looking at a mother board issue.
May 21, 2010 | Dell Inspiron E1705 Notebook
Dell Inspiron e1705 no longer recognizes AC Adapter and battery won't charge. Tried updating BIOS, but exe file won't open becuase the Flash app won't run. What can I do?
If the system doesn't recognize a the AC adapter, a BIOS flash will not run as system needs to ID the battery any AC to run the flash.
  1. Try a different AC adapter if one is available. The system IDs the adapter by the pin in the center of the DC connection to the system. If the pin is bent or missing, then the system cannot ID the AC adapter and the Battery Charger is disabled.
  2. If issue occurs with a new or known good DELL Branded AC adapter (Any Dell D Series adapter should work on system) then the motherboard is bad.
AC adapters run about $25
http://shop.ebay.com/?_from=R40&_trksid=p3907.m38.l1313&_nkw=e1705+ac+adapter&_sacat=See-All-Categories
Motherboards around $150
http://shop.ebay.com/i.html?_nkw=e1705+motherboard&_sacat=0&_trksid=p3286.m270.l1313&_dmpt=Laptop_Adapters_Chargers&_odkw=e1705+ac+adapter&_osacat=0&bkBtn=
Apr 03, 2010 | Dell Inspiron E1705 Notebook
Dell inspiron e1705 did factory restore then screen went black now what do i do?
Since you did factory install, Might probably that's the recovery partition you used, Try to restart computer, if does not work, turn it off, unplug ac adapter and battery then drain residual power of laptop by pressing the power button for 5 secs, then put the ac adapter and battery again. If it still doesn't work, try to run diagnostics first if it fails then you'll need to replace a part, if it passes then you'll need to do operating system re-installation manually.
Feb 12, 2010 | Dell Inspiron E1705, Intel Core 2 Duo...
On the issue with th ebattery on the 1521 inspiron. Took battery out and plugged in still will not power up. Could it be the adapter as well?
On the ac adaptor, look for a green light that will turn on when you plug it into the wall outlet, if its on that means the ac adapter working. If you get a green light on the ac adapter but then the green light goes away when you plug it into the laptop then that means the laptop has a bad motherboard.
If you plug the ac adapter into a wall outlet and get no green light then that means the ac adapter is bad and you would need to get another one.
Jun 21, 2009 | Dell Inspiron E1705 Notebook
Dell Inspiron 1505; Battery does not charge; DC jack is loose..
The loose connection for the AC adapter means the motherboard needs to be replaced or the AC adapter jack on the motherboard needs to be replaced. (With Labor, it is about the same cost to buy a new motherboard as it is to have the old one fixed)
Motherboards are available on EBay for around $100
Apr 25, 2009 | Dell Inspiron E1705 Notebook
My ac adapter is not charging my laptop
You have a Bad AC Adapter. If you will replace this it should fix this Problem. Please Rate My Response! Thanks!
Feb 07, 2009 | Dell Inspiron E1705 Notebook
Charger for E1705 beeps and no green light
If, when not plugged into the system, only the wall, the AC adapter LED doesn't come on and the adapter beeps, then it has failed and will require replecement. If the computer is still under warranty, the adapter is covered under the warranty.
If not covered under warranty, then buy a new AC adapter.
If the LED comes on when not plugged into the system, but goes out when connected to the portable, then the motherboard may be bad.
Nov 12, 2008 | Dell Inspiron E1705 Notebook
Dell Inspiron E1705 Notebook Logo
83 people viewed this question
Alun Cox
