Question about HP DVD Movie Writer Dc3000 DVD+RW Burner
HP DVDMovie Writer dc3000
When is connect to vhs to copy a tape to dvd it shows the transfer in process with sound, when finished I get an error message that it failed to write to the disc.
sandrew
  • 2961 Answers
SOURCE: problem copying a movie onto a lightscribe hp dvd +r media disc, using my hp dvd940e dvd writer
The semaphore timeout period has expired refers to the fact that the driver is no longer communicating with the device and failed. Each time a CD Burner is setup for a CD Burning session the burner hardware will perform a 15 step power test to determine the OPC for a Blank Media Disc, OPC meaning Optimum Power Calibration. This test also takes place during the CD Burning process so the CD Burner can determine the best burn speed and method for the disc; this test is called 'Running Optimum Power Calibration'. Although the test is performed by the hardware of the CD Burner, the device initializes the CD Burning Software for the test to take place. This is one reason why your software may report the "Power Calibration Error" or ?Calibration Error Full?. With Power Calibration errors they can be caused by different factors and sometimes difficult to locate, especially if the errors are at random. Below are the known factors that will cause the Power Calibration Errors and how to check each factor, it is important that each point is considered if wanting to get to the bottom of the error. Power Calibration Errors can occur when OPC or ROPC tests for the media disc so the condition of the disc, brand of disc and even the firmware for the CD Burner can be the cause for the errors occurring. A device such as a CD Burners can have different problems if there is a power consumption issue with the system and the Power Calibration Error is just one of those problems. If using either an internal or external CD Burner make sure to disconnect all other devices, except the hard drive and Burner, before attempting to burn a disc. Double check all cables for any faults and if possible test with a 2nd Data Cable. It is also advisable to disconnect the power connection for the CD Burner and test with a spare connector. If you have no trouble with other discs, use them and put to one side the lightscribe, other than that try the burner in another pc or with other burning software, as you can see it's quite ridiculous what problems burners can create.
Posted on Jun 13, 2007
  • 373 Answers
SOURCE: HP 640b DVD Writer tray will not eject after burning DVD
If all else fails you can take it to best buy
I did that with one of my comp.
Posted on Feb 03, 2009
z89s
  • 225 Answers
SOURCE: problem with hp dvd writer 740b
make sure all the cords are hooked up to it properly in the computer case and if they are hooked up tight and none are loose make sure you have music/dvd codecs on your computer get a codec pack and then it should write a cd like normal for a codec pack just go to google and download one doesnt matter what one
Posted on May 29, 2009
PolyrhythmFX
  • 109 Answers
SOURCE: hp 1040e dvd writer plays cd's but not dvd's.
What brand DVD's are you using? Its best to use the same brand discs as your burner. This is because in the design and testing stage they are using their own brand of discs to test them. Some other brand discs may be thicker or thinner and not read correctly. The "blank" disc may have already have been written on. Make sure the Nero software is loaded on your computer that came with it.
Posted on Jun 23, 2009
SOURCE: power calibration error, hp 1040i dvd writer, windows 7 upgrade
pls
Posted on May 27, 2010
VCRs problems and solutions
You can get a box called Copy Decoder. This will connect via a scart socket between a video recorder and a DVD recorder. It will remove the copy protection system. If you have decent computer you can also transfer them to your computer. There are several brands of software that will take in the video file and upscale them to high-definition files and make DVD's or Blue Ray discs if your computer has a Blue Ray writer drive.
The box and software can be found by searching Amazon.
Jun 12, 2013 | Televison & Video
I get a tracking error code when trying to write to a CD. I don't have the code number with me, but it ends with 1h. The program I'm using is Cakewalk Pyro and I'm converting a tape to a CD. ...
so what CD??? CD-R recordable, CD-RW?
No PC stated. NO OS stated ,wow.
just DC3000 and some kind of VHS tape?
My guess bad media. (CD-r)
or the drive it self is bad.
or as all XP are , virus infected,
the spec says
Transfer, edit and burn home videos with this all-in-one external HP DVD movie writer. The built-in analog video capture lets you quickly and easily transfer home video directly from tape to DVD via your camcorder or VCR, while the included suite of software lets you add special effects, music and more to video and photos. Also great for creating music CDs, it writes and reads CD-R and CD-RW discs in addition to DVD-R and DVD-RW discs. Includes software CD, electronic user's guide, USB cable, composite video/audio cable, 1 blank DVD-RW disc and 1 blank DVD-R 4x hi-speed disc. Requires a PC with Microsoft Windows XP or 2000 Professional SP2 and USB connectivity.
Nov 05, 2017 | HP DVD Movie Writer Dc3000 DVD+RW Burner
How do I get the drivers needed to make the DVD Movie Write DC3000 work on Vista?
HP does not make a Vista driver for your device. Here is their driver page for you unit:
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=228&lc=en&cc=us&dlc=en&sw_lang=&product=327406
When you plug it into your PC, it should auto-discover it. While connected to the internet, reply YES to let windows search for a driver at MS. If it finds one, you should be ok. If it can't find one, I'm afraid it's not going to work.
There are drivers only for Windows XP and Windows 2000 Pro.
Dec 03, 2010 | HP DVD Movie Writer Dc3000 DVD+RW Burner
Copy from vhs to dvd- want to speed process ???
I'm afraid, VHS tape have to be playback on standard speed for good picture and sound and dvd would also burn accordingly.
Noo way for fast dubbing because VHS tape video is analog signal that changed into digital signal in circuits to write on dvd disc.
I hope you understand how this dubbing works.
Nov 08, 2009 | Emerson EWR20V4 DVD Recorder/VCR
I have a Samsung DVD-VR357. I get no color on vhs tapes. I only get black and white.Picture is good. DVD color is ok. When I copy VHS to DVD, the DVD copy is in black and white also. DVD copies from...
Are you trying to copy a comercial VHS tape to DVD?
If you are then macrovision copy protection system on either the tape or in the machine is the reason for the loss of colour.
There's not a lot you can do about it. If you want to copy commercial material you will need to transfer it to a computer and get a program to do it. But unless it's unavailable it is cheaper to buy the DVD version I have found and you will get better picture and sound too!
If it does it with a none comercial tape (ie something recorded of the TV). Then it could be a head fault or something else. In which case try cleaning all the heads guides etc first.
Jun 20, 2009 | Samsung DVD-VR357
Panasonic DMR-ES40V DVD-Video, Transfering of..
ok,you need to prepare your VHS tape and put to what portion of it you want to transfer.but, you will need a cd/dvd writer.it is used to record whatever you want to record.you need a computer to do this.it's complex but if you get the hang of it, it's very easy.
May 07, 2009 | Panasonic DMR-ES40V DVD-Video Recorder
Connect DVD recorder to Video player/recorder- transfer VHStodisc
hook the video output from vcr to dvd input at rear, then hook output from dvd to tv input. note; you can not record protected vcr movies you can only record tv shows from sattelite to vcr or dvd recorder. its best to record straight from sattelite to dvd recorder for picture clarity.
Jan 27, 2009 | RCA DRC8300N DVD Recorder/VCR
Recording from vhs to dvd
Direct copy VCR to DVD:
- Insert VHS tape you want to copy
- Insert a recordable DVD disc
- Press DVD copy button on front panel or remote control (to DVD).
- To stop recording press the stop button.
IMPORTANT: If attempting to copy copyrighted material the Samsung DVD-VR320 will detect the encoding and will not allow the copy to be made.
Jan 20, 2008 | Televison & Video
Dubbing vhs to dvd
Easy. Connect RCA lead from video/audio OUT on the VCR to video/audio IN on the DVD recorder. Set DVD recorder source to VIDEO then press play on the VCR and record on the DVD recorder.
Sep 09, 2007 | Aspire Digital AD-8091 DVD Recorder
HP DVD Movie Writer Dc3000 DVD+RW Burner Logo
41 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
