Question about GE JVM1640 Microwave Oven
Microwave will not heat food.
My daughter thought she was setting the timer, but turned on the microwave at high. It ran for 15 minutes before I got inside to turn it off. Now it will not heat anything. Everything else works.
  • William Miller
    William Miller May 11, 2010
    When a microwave is run empty, the energy is reflected back to the magnetron.
    If it happens for too long, and the thermostat doesn't shut it down, it will damage the magnetron.
    I would say the magnetron is destroyed.
    Would you or a friend want to work on it yourself? I can give you more details and tips.
  • GE Master
  • 43,501 Answers
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
wsw
Posted on Sep 30, 2010
I have a microwave in which i have option only for timer no option for setting temperature how to use it
Unlike a conventional oven, your microwave does not have a provision for setting a specific temperature. There may be only settings for different levels of heating such as high and medium and a special setting for thawing frozen food. The manual for your microwave could be a useful source of information regarding operation.
Dec 02, 2014 | In Microwave Ovens
Why can't you run a microwave without anything in it? What happens and can you fix the problem? I forgot to put the food in and ran it for 4 minutes with nothing inside. Now it won't heat any food.
A microwave oven works on the principal of a high power high frequency radio transmitter. The device that emits the microwave energy is a tube called a magnetron . When you run the microwave empty with nothing to absorb the microwave energy it is all reflected back to the magnetron causing it to overheat and destroy itself or cause failure in the High Voltage power supply due to excessive current draw.This is caused by standing waves.
Aug 08, 2014 | GE Spacemaker JVM1740 Microwave Oven
If you try to heat something for a minute , the microwave will turn on for about 15 seconds then shut off . It doesn't even seem to warm the food.
It may need a reset. You can do that by unplugging the power for a minute or two, then plugging it back in and setting the clock.
If it still fails, you may have a failing cooling fan or a problem on the control circuit board.
Apr 14, 2013 | Thermador MCES Stainless Steel 1000 Watts...
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
The microwave runs like normal but doesn't actually heat anything. I went to heat something and it came out cold. Timer set just fine, it ran and sounded like it always does, turntable turned, it dinged at...
The most likely problem is the magnetron that heats the food, the other less likely is the high voltage transformer that energizes the magnetron. To replace either part with labor would be as much if not more than a brand new microwave oven.
Jan 19, 2011 | KitchenAid KHMS145KSS Microwave Oven
My GE Profile over range microwave spacemaker xl 1800 model jvm1870bf02 was working just perfect until my daughter decided to use the microwave as a timer and actual ran the microwave with nothing inside...
Magnetron is blown.
This high-energy microwave-transmitting device hides behind a small plate on side of oven.
The waveguide sticky-out part looks like a small tube.
Normally, water molecules absorb the energy, heating the food.
Without an absorbing 'load' inside the oven cavity, the high-frequency, high power energy bounces back into the magnetron and it destroys itself. (Magnetron Hari-Kiri).
In a nutshell, tech must renew magnetron.
Then iInstruct family members to never run it empty.
Oct 11, 2017 | GE JVM1850 1000 Watts Microwave Oven
A visitor to my home used the microwave as a timer for 15 minutes. She didn't use the "timer" button. She turned on the microwave as if to cook something without anything being in the oven. Now the oven...
Without a load (food or water) to absorb the microwave energy the microwaves will bounce back into the waveguide and on to the magnetron antennae causing damage. Usually there is a lot of arcing and noise when there is nothing inside the oven cavity which alerts you to the problem. I cannot say for sure if it destroyed the magnetron.
Jun 23, 2010 | Kenmore 80012 Microwave Oven
Kenmore 401.8008700 ran 10 minutes thought I'd set on timer
It could be the fuse. You will also need to check the condition and alignment of the door switches.
Eric
Jul 15, 2009 | Whirlpool GH6177XP Microwave Oven
Microwave won't come on
I am a recently retired appliance engineer of 20 years, i am reluctant to help with microwaves because of the dangers, the store electric even when unplugged, but it sound just like an internal fuse, these are special quick blow types, can be bought from most electronic high store shops, and replacements must be exact match, if a replacement blows there is another fault and don't recommend self repair work with safety and remove the plug first etc oh the fuse is just inside following the mains wire in, and normally on a small circuit board if i have helped please rate me
Sep 09, 2007 | GE JVM2050 Microwave Oven
GE JVM1640 Microwave Oven Logo
190 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
