Question about Teac GF-350 CD Shelf System
Turntable Spinning too fast
On my GF-250 the turntable is spinning too fast. Noticeable in sound. recorded revolutions and found it to be hitting either 33.3 or 45 rpm in 57 secs.
Does anyone know if there are any adjustments?
  • faspadafora Oct 09, 2008
    it is belt driven. would a loose belt cause it to spin too fast?
    Sergeant:
    Champion:
  • 334 Answers
Ya buy new belt loose or is this direct drive
Posted on Oct 09, 2008
  • nick helpap
    nick helpap Oct 09, 2008
    yes or to slow cheak that out
Direct drive spinning to fast
Sounds like a speed sensor in the motor has opened up. You need a repair shop my friend.
Apr 21, 2013 | Gemini PT-1000 II Turntable
My Teac sl-a100 record player sounds like a chipmunk
hi,
somewhere on that player is a switch for 78-45-33 rpm the speed switch look up around by the tone arm above by where the record goes, it may not be on the front. switch it to the correct record you have 45's are small. 78's are medium and 33rpms are the big records..
jm
Apr 30, 2011 | Teac SL-A100 Turntable
Spins too fast
Check that the belt [under turntable] is`nt twisted or the 33/45 speed button is`nt sticking on 45rpm
Feb 26, 2010 | ION Audio iTTUSB Turntable
My Crosley turntable is spinning too fast at 33RPM
Mismatch speeds on older turntables is normally due to either 1) a kink in the speed switch mechanism or 2) a hardening and slipping of the rubber drive wheel.
A very small motor with a chamfered shaft drives the rubber drive wheel, and the wheel is moved by the speed control up and down the drive shaft to produce various rpm speeds.
In your case, it's likely turning at 45rpm because it isn't settling onto the 33rpm part of the shaft.
Piddle with the speed control, then count the speed (number of turns in a minute) You'll figure it out!
Nov 25, 2009 | Crosley Audio Players & Recorders
AT-PL50 won't play
take the turntable arm by your hand and place it above the record,then use the up and down lever to lower arm on record!!
Aug 18, 2009 | Audio Technica AT-PL50 Turntable
Technics turntable model SL-bd27. center spindle rubbing noise.
hi, try to open or remove the platter on the deck, maybee there some small thing inside..
Apr 09, 2009 | Technics SL-1200M3D Turntable
LP audio recording seems to be at the wrong speed
1- The turntable is set to 45 rpm and the album is recorded at 33 rpm. Press the 33 rpm button the red light should come on turn the and be fine.
or
2- This turn table has a fast record mode where you can record a 33 rpm LP faster by spinning it at 45 rpm. If you are trying to use this mode you will have to make a software setting to tell the TTUSB10 digital converter program what mode you want to run.
Nov 29, 2008 | ION Audio TTUSB10 Turntable
Turntable spinning too fast
The turntable speed is controlled by a belt, which is virtually a big rubber band. If it spinning too fast , then this means the belt is too tight. The only way this can happen is for the unit to be fitted with an incorrect size belt. You didn't say if you have a new unit, or a second-hand one, or if it has recently had the belt replaced. If it is a new unit and still under warranty, take it back to the retailer and ask them to fix it for you. Again, if you have recently had the belt replaced, take it back and ask them to do the job again, and this time to please use the correct belt. Be polite but firm....If you are a handyman, the job is not too hard to do yourself, and if you need any extra help, just ask, johnatwagga@yahoo.com. To buy the correct belt, you will need the name, model number, and preferably, the serial number. All of these can be found on the back of the unit. Good luck, and I hope this helps.
Nov 24, 2008 | Teac GF-350 CD Shelf System
Teac GF-350 CD Shelf System Logo
548 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
