Question about HP Pavilion dv6000z Notebook
Need to find a replacement
I need a flat ribon 12 pin cable, its part number is E118077 2896 80C VW-1. I cant seem to find it anywere, if you could tell me wher would i be able to find this item. its very important to me for puting my computer back to work.
  • ard0100 Oct 09, 2008
    I have the same problem, i need replacement cable. I have no sound without this cable and power on button not working too, oh yes and microphone in laptop as well.
  • 2,712 Answers
Please call HP Sales at (800) 227-8164 between 5 AM and 6 PM Pacific Time, Monday thru Friday to order the required part.
Posted on Oct 09, 2008
  • 334 Answers
Try ebay newegg and part shops online in google serch have u buy old broke labtop just like this on ebay cheap use its parts
My screen has developed vertical lines, I don't know how this has happened
You have one of the pins in the ribon cable broken , usualy when that occurs you need a new display
Jun 04, 2016 | Televison & Video
Need pin outs for eagle cuda 168
Coda has flat D 6 pin with center pin grd for 4 wire vs old arrow 6 pin round black one. Flat on bottom, count cw 12345 pins w pin 6 center... 2 pin minus 12 v, 4 pin +12v. For other 4 wire like speed/temp... 1 blue, 3(top) white, 5 pin bot right yellow, 6 center ground for spd/temp. White for speed wheel, rest not known. I used 2wire cable and 4wire cable with 2ft pigtails and 3amp fuse in red wire. I used old radio stereo 2 and 4 pin male female connectors at end of pigtails.
Nov 06, 2012 | Eagle Cuda 242 Fishfinder
How do i fix a flat ribbon cable awm 20624? it only has 1 pin broken
Check most of the ribbon cable have their two ends detachable. Replace the entire ribbon is the solution to the broken pin. Attempt to fix the cable may cause short circuit on the cable which will impact on the equipment if used.
Sep 29, 2010 | Computers & Internet
Alternate IC to STK404-050 is required?
The STK404-050 is hard to find but I have sub'd a 13 pin STK404-130 several times. All the pins are shifted over to the right to add another pin for the thermal sensor that is added to the STK404-130.
By clipping pin 1, all the remaining pins, 2-13 are in the correct position to insert into 1-12 on the pc board. The only problem is the mounting screws are spaced wider so new holes in the heat sink will need to be drilled. Be sure to de-bur the new holes so the module mates flush with the heat sink. I have used this method to replace STK404-50's and STK404-100's with good success.
Jul 27, 2010 | Yamaha NS-P320 System
Cvilux e208903 awm20706 105c 60v vw-1 looking
cannot play H.264 video clips stored on my flashdrive
Sep 04, 2009 | Sharp Televison & Video
Broken touchpad connector
I suggest you replace the motherboard. A recent search on ebay turned up three ranging in price from $18 to $85. Soldering a motherboard by hand has a very high failure rate. It's easy to bridge or scratch something and fry the board. You could of course try to do it and if it fails get a replacement board.
May 28, 2009 | HP Pavilion ze1115 Notebook
IH36 iHome degrading
The problem is that the flat flexible cable which connects the dock to the main unit is breaking. After taking mine apart(!), I found that the point at which the cable connects to the main unit is flexed very strongly each time the dock is opened. Each time the dock opens & closes, it gets worse.
Replacement is a 260mm, 12 pin, 1mm pitch, flat flexible cable, AWM 20624 80c VW-1. I have yet to locate a supplier of this cable.
Jan 04, 2009 | Audio Players & Recorders
Dell 1800FP
What's wrong with your monitor?
Feb 10, 2008 | Dell UltraSharp 1800FP 18.1" LCD Flat...
EM 500 RIBON CABLE TORE how to replace?? HELP!!
It might be possible to repair the tear. You'd need to bond a plastic backing to the back of the ribbon to support it. Clean off the front layer to expose the torn conductor ends then paint a thin strip of conductive epoxy or car heater matrix repair along each of the flat wires. Finish off by covering (when set) with scotch tape. Everything needs to be completely squeaky clean (use alcohol) before you start.
Sep 05, 2005 | Casio Cassiopeia EM-500 Pocket PC
HP Pavilion dv6000z Notebook Logo
428 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
