Question about Motorola Mobility MOTOKRZR K1 Cellular Phone
Setting ringtone. Hi. I love this phone but cannot for the life of me figure out how to set a new ringtone to my phone. I have one I want saved on my computer media player thingy and just don't know how to get it on my phone even with the manual. Complete well almost, techno dummy. Please I need step by step instructions as if for a three year old! Thanks.
    Problem Solver:
  • 4 Answers
Hey. I hope I can be some of help, as I used to have the same phone as you and I always added music from my computer to use as ringtones. For starters, make sure the song you want to use is 192 kps or lower, and is in the mp3 format. I usually downloaded my songs via limewire; however, as long as you have the song(s) you want in a separate folder(like your music folder) in your computer documents - it makes for easy transfer from your computer to your cell. Now onto the transferring....
What you want to do is have the usb cable that came with the phone plugged into a usb port on your computer, then plugged into your phone. A little icon will appear in the lower right corner of your computer screen displaying a message - new hardware found(usb storage) ignore that
go to your music folder and right click on the song and select - send to (whatever drive your usb cable is plugged into - for example - :J drive
you should see a grey box appear up in the left corner of your screen displaying the copy animation.
Once your finished with the transferring part, you are going to want to unplug the usb cable from your phone and computer, then look up your sounds file in your phone to make sure it's there and plays.
After the first transfer, it's a piece of cake from there! =)
Posted on Oct 11, 2008
"how to set ringtone in nokia 2690 "
Hi..
By going setting and open Profiles - edit - there will be all ringtone and sms tones options.. change and save it..
Apr 05, 2014 | Nokia 2690 Cell Phone
Hi sir mere nokia6600 me call ring par koi dosri ring select kaise karenge.maine mp3 ringtones ki aur jab usko select karo to format ring batati hai.Please answer of my qustion!
Hello Mr. Aamir, Aapko mobile ki setting check karni hogi uske baad settings main sound select kijiye; Is setting main aapko ringtone ka option milega **** aap click kijiye; click karne k baad aapko ringtone choose karna hoga... mp3 ringtone select kar k use save kare. Hume bataiye agar aisa karne se ringtone change ho jati hai. Kuch samay lekar mere suggestion ka rating dijiye. Thanks, Richee
Jun 21, 2011 | Nokia Cell Phones
The User Manual does not explain how to change the ring tone, can you help please?
Hi gary468780 There are two ways by which you can change your samsung mobile phone ringtone . For changing ringtone of your cell use one of the following methods : 1} Go to Music option from main menu then you will get music library files to play and listen music if you like any song then you can set it as your ring tone by selecting option menu and then select set as Ring tone 2} Go to setting option from main menu and then select profile setting and then edit the profile setting after editing profile you will get another menu from which select Vice call ringtone option and then change ring tone and save it
Jun 06, 2011 | Samsung GTC3300 Cell Phone
How do i save audio as a ringtone on my motorola moto ve240?
go to settings of ring tones and choise use as a ringtone
Jun 04, 2009 | LG CHOCOLATE VX8500 Cellular Phone
Setting my sounds as ringtones
Send it by text to yourself and save as a ringtone whenyou save it. worked for me
Apr 19, 2009 | Lands Phones
Message tones and vibrate facillity
To change the vibrate function:Go to main menu, phone settings, phone profiles, highlight the 'normal' one & press the 'options' soft key to the left of the touch screen keypad. Pick 'edit', then the 'call alert type' will be highlighted. Press the left soft key saying 'options' & select 'change'. You can then opt for it to vibrate by highlighting the vibration one & pressing the tick on the touch screen bit. Then don't forget to save the changes!
To Change the ringtone:
  1. From the standby screen, press Menu (Figure 1).
  2. In the main Menu, press Settings (Figure 2).
  3. In the Settings menu, select Phone profiles and press (Figure 3).
  4. You will be presented with a list of phone profiles for different situations and environments. The one you're currently using will be ticked. Highlight the one you want to use (in our example, Normal) and press the Edit button at the bottom of the display (Figure 4).
  5. You are taken into the profile settings (Figure 5). At the top of the list you'll notice three tab icons - these represent (from left to right), ringtone, message alert, and keypad sounds. You can switch between settings for these by tapping one of the tabs.
  6. You should be taken first into the ringtone settings list. Should you want to change the Call alert type (from melody to vibration then melody, for instance) tap this option and scroll through the list of options to choose the one you want.
  7. To change the Voice call ringtone, tap this option on the screen. You will be taken into a list of phone file folders from which to choose your ringtone (Figure 6). You can tab across to view files stored on a memory card, if you have one installed.
  8. Press the Sounds option. You now have the choice of choosing from yourMusic files, Ringtones that are loaded onto the phone, or My voice clips(clips you have recorded) (Figure 7). You can select from whichever of these folders you want - the setting procedure is the same for each. In our example, we'll choose from our Music folder to select one of our tunes as the new ringtone.
  9. Press the Music option. A list of tracks appears (Figure 8). Tap the one you want in order to highlight it (Figure 9). Press Options, then tap on theSelect menu option to install it as your ringtone (Figure 10).
  10. You are now taken back to the Normal profile settings, where the Voice call ringtone has changed (Figure 11). To save this change, press Options and then Save (Figure 12). Alternatively, press Back and you will be asked whether you want to Save?. Press Yes.
In the ringtone settings menu, you can also change the video call ringtone (which is lower down the menu) by following the same procedure.
Aug 27, 2008 | Samsung U900 Soul Cellular Phone
How to save under ringtone file???
A ringtone file must be a specific size. You might be able to put your ringtone in your cell phone provider web account and from there download it to your cell phone. Only if your cell provider has this service. Like Virgin mobile has the option where you can create your screen background and ringtone. You have to dowload it to their web page then to your phone.
Artgirl
Jul 19, 2008 | Sanyo Katana SCP-6600 Cellular Phone
How can I set an mp3 file as a ringtone via the SD disc?
well my friend if you want to use a mp3 as a ringtone here it's what you have to do.... buy it! no just kidding save your mp3 ringtones on to the memory card in the "my sounds" section make sure it doesn't go over 400 kb , select ringtone and send it on a mms to your self and  thre you have it save it as a ringtone hope this helps you oh also you can send and recieve ringtones to via blutooth but by mms messaging
Oct 26, 2007 | LG enV VX9900 Cellular Phone
Setting ringtones
bitpim - software that communicates with whichever type of pda/usb device.
Jul 06, 2007 | LG CHOCOLATE VX8500 Cellular Phone
Motorola Mobility MOTOKRZR K1 Cellular Phone Logo
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
