Question about Pioneer Car Audio & Video
I installed my new pioneer AVH-P4000DVD in my car/ I soldiered all the connections correctly and taped them off. My neighbor helped me run wires for a subwolfer to the outputs and we will try and install the sub and amp sometime soon. However, before i completely put everything back, i tried to use the unit. I tested the radio first, the antenna went up and the radio turned on, but there was no sound. I tried turning up the volume to maximum and tried to mute and un mute the sound. Nothing happened. I them tried a cd, and the same thing happened, no sound. I looked in the manual, checked all of the connections, and made sure everything is plugged in. My car is a 2004 hyundai sonata. Can you please help me so that is can listed to my system?
  • eragon246 Oct 09, 2008
    i don't know if it has an on board amp. that is the only explination that i can find. Would you know how to find the amp?
    it may have a factory amp
You may have connected the mute wire to something. I have a mustang, and the diagram I found told me to leave it unconnected. Check out some wiring diagrams for the cars wiring harness and the adapter you connected them too. Make sure they match up pretty closely.
Posted on Oct 03, 2012
    Sergeant:
    Champion:
  • 334 Answers
Does car have onbord amp
Posted on Oct 09, 2008
  • nick helpap
    nick helpap Oct 09, 2008
    my sebring has it under seat ground sterio super well once also
  • nick helpap
    yes by pass factopr y amp cuse distorion at loud er levels sound like ****
No sound from ipod, usb or aux?
I removed my Pioneeer AVH-P4000DVD from my Tacoma pickup to upgrade to an AVH-X2500BT and installed the AVH-P4000DVD in my mustang cobra and found myself suffering from a strange issue (that seems to have happened to a lot of you too). All of a sudden I had lost my audio on my USB and AUX inputs. I tore the net apart for a solution, pouted, drank, and started doing more and more research, and check instruction manuals. I eventually found the solution based of one lone comment someone had mentioned regarding ground and comparing the wiring diagrams for the two decks. I pulled the pioneer harness out of truck and compared it to the pioneer harness in my car and found an inconsistency. This may solve the issue that plagues you as well. Check the harness you are using. I was not able to find a pinout, but the 4 wires on one end of the harness for the AVH-P4000DVD should be +12V battery, +12V ignition, ground, and ground, (yellow, red, black, and black). If you have received the harness for a newer model of pioneer AVH it will still fit fine but one wire is out of place. The second ground wire you need has been replaced by a purple reverse gear sensor for the backup camera. Ground out the purple wire and it should solve your issue... It did for me. Good luck.
Sep 20, 2011 | Pioneer AVH-P4000DVD Monitor
I need a avh-p4000dvd wiring diagram
i have the manual for it .. i hope this helps -- ther are phone numbers to call Pioneer to get further information
http://www.pioneerelectronics.com/StaticFiles/Manuals/Car/AVH-P4000DVD_OperationManual0123.pdf
Oct 30, 2010 | Pioneer AVH-P4000DVD Monitor
How do i play video from usb on a Pioneer AVH-P4000DVD?
You can NOT view video using USB on this unit. Video has to come from the AV inputs (RCA connections) or from an IPOD connection. Sorry.
Jun 30, 2009 | Pioneer AVH-P4000DVD Monitor
How do i bypass the brake safety switch on a pionner avh-p4000
CONNECT A SWITHC TO THE PARKING BRAKE WIRE ONE OF THE PINS FROM THE SWITCH TO GROUND AND THE OTHER SIDE TO THE PARKING BRAKE WIRE.
Mar 14, 2009 | Pioneer AVH-P4000DVD Monitor
What's the recommended camera for avh-p4000dvd pioneer unit
Pioneer recommends Pioneer ND-BC2, but you should be able to use any with a descent viewing angle and RCA connections.
Watch a dvd while driving pioneer AVH-P4000 DVD
ground the wire to a hot (ie power comes to the wire) switch in your dash, like a rear window defroster or seat heater. turn the switch on then off and it will trick the system into thinking you activated the parking brake.
Mar 03, 2009 | Pioneer AVH-P4000DVD Monitor
Installing a avh-p4000dvd up in a 98' gmc sierra
http://www.crutchfield.com/ YES THEY WILL HELP YOU 24/7.RICHARDM69
Dec 06, 2008 | Pioneer AVH-P4000DVD Monitor
I have the pioneer avh-p4000dvd.but what are the main power wires
what are you trying to do.????
you mean the RCA jack or jus the yellow and red wire???
Oct 14, 2008 | Pioneer AVH-P4900 Car Video Player
Car Audio & Video Logo
200 people viewed this question
Top Pioneer Car Audio & Video Experts
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
