FixYa.com
Tags:
Universal Remote Control DIRECTV Universal Remote Remote Control
URC 6131 Universal Remote Problem
By Mini Me - usenet poster
Based on recommendations posted here I purchased a URC 6131 universal remote
control. The Info button will not call up the program information banner
and the Exit button will not exit any on-screen menu. I have tried using
the out-of-the-box code (preprogrammed for a Phillips DirecTV/TiVo) and also
the listed codes. The problem exists with both a Hughes HDVR2 and a
Phillips DSR 7000. Is this a known problem, and if so, is there a fix?
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Best Solution
posted on May 26, 2006
Thanks for Trying (70)
lawyer
lawyer - usenet poster
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
I just used the remapping feature in the URC 6131 to remap (IIRC) the
"right directional button" to info. I did something similar for exit
after figuring out which button did the same thing.
Play around with the remote a bit to figure out which buttons have the
same function and remap them to info & exit.
Jon Biggar
Floorboard Software
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
Not Rated (0)
Grant
Grant - usenet poster
Rating: 0%, 0 votes
In article <>,
"Bruce Dannells" <> writes:
There are two interacting issues:
1) The URC-6131 does not, by default, map quite all of the buttons.
2) The Series 2 DirecTiVos try to determine which of two or three models
of remote you're using based on the presence or absence of certain
keypresses. It'll then change its behavior slightly, so the remote may
work differently depending upon how you're using it and if you're
using it instead of or in conjunction with the "peanut."
I've not studied the details of #2, but I know you can reprogram the
remote to handle the remote codes that OfA left off of the buttons. Check
here for information on using these "advanced codes:"
For a discussion of how this applies to the URC-6131 and TiVos
specifically, check this TiVo Community Forum thread:
In particular, the second page includes information on advanced codes for
TiVos. There may be more information elsewhere, but I don't recall
precisely. (The thread covers a lot of territory, including non-OfA
remotes.)
Rod Smith,
Author of books on Linux, FreeBSD, and networking
Solution #3
Not Rated (0)
kioner
kioner - usenet poster
Rating: 0%, 0 votes
I have a 6131 that I use with a Hughes HDVR2, and the "info" button works
fine, so I can't help you there. As far as I know, the "exit" button is a
dead key on the remote, and you just have to arrow your way out of menus.
To be honest, I never really noticed until you mentioned it.
I use a different OFA remote for the main setup: one with programmable keys.
. .but even there I never programmed an "exit" key.
Anyhow, sorry if it's not working out for you.
Solution #4
Not Rated (0)
Reynolds
Reynolds - usenet poster
Rating: 0%, 0 votes
Based on recommendations posted here, I bought a URC 6131 remote. The Info
button does not call up the program information banner and the Exit button
will not exit from the Main Menu (or from anything for that matter). All
other functions seem to work OK. I have tried the out-of-the-box code for
the PVR as well as listed codes. The problem exists with both a Hughes
HDVR2 and a Phillips DSR 7000. Is this a known problem, and if so, is there
a fix?
Can you Help with these Remote Controls problems?
Universal Remote Control DIRECTV Universal...
amigos tengo bloqueado mi...
el problema es que la tecla (ON... Answer This...
32 inch tv 2001 model
it has sounds but no picture do... Answer This...
need tv code for phillips model...
looking for a tv code for my... Answer This...
remote control
I have a Magnavox tv. I lost... Answer This...
direct tv remote- volume...
I'd like to program my new... Answer This...
Repair Service
Find Remote Control Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
