How to refill colour print cartridges - Office Equipment & Supplies
    President:
  • 2,712 Answers
There are kits available in the market that allow you to refill cartridges. You should be able to find them at most computer stores. Each kit comes with refilling instructions, and these steps can vary from company to company.
However, I do not recommend refilling cartridges or even using generic ones. Always buy original inks, even if they are a bit more expensive. These days printers come with sensors that detect when an empty cartridge has been refilled, or if a generic cartridge (duplicate) has been used, and will cause all sorts of printer error which will be more expensive to repair than the few extra bucks it will cost for genuine inks.
Hope that helps! Should you have any further questions, please feel free to post them here.
P.S. - If you find that the solution/answer I provided led you to, or resulted in a fix, please close the ticket with a FixYa! rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
Posted on Oct 09, 2008
Had refill at Costco for hp 4620 printer 564 cartridge and now printer will not print in color. What do I do to make it print?u
That's means you didn't refill the colour ink properly.
Try this method, use the injection to draw any of the colour of about 2mm of the refill you bought, inject it into one of the tiny holes of the cartridge and draw a little back so as to remove the dirt in the foam inside the cartridge.. That's all
Aug 09, 2014 | HP Office Equipment & Supplies
My cyan colour is finished, i have to print a black colour documents, printer is not allowing to print, please help
switch to black and white on the printer settings.make sure ignore colour warnings are turned off
if that doesnt work youll need to replace the cyan,get it refilled for less or order online to reduce cost
Mar 07, 2011 | Epson Office Equipment & Supplies
Installeds a refilled colour cartridge and will work but printer says empt..may do damage. Lexmark x5450 colour cartridge # 33.
Using a refill for this printer will not "do damage." The damage they are referring to is if you continue printing with an empty cartridge you can damage the print head on the cartridge. Since you replace the print head every time you replace the cartridge, you never damage your printer.
Nov 03, 2009 | Lexmark X3470 All-In-One InkJet Printer
Lexmark X1100 Series won't print in colour after cartridge refill
I have refilled my cartride many times. Sometimes the colour has not worked so I found that if I put the lower end in hot water and made sure all 3 colours came out in the water the printing then worked. It simply was clogged after refilling.
Dec 27, 2008 | Office Equipment & Supplies
Can't print just black when out of color with Samsung CLP-300
its not possible till you get that rec colour refilled in your colour cartridge or replace the colour cartridge.so you cannot print black as the printer is not been able to end its cycle as the cycle is getting break at the colour cartridge.its very common problem faced by many users but no other option except replacing or refilling the cartridge.
thanks.
Dec 14, 2008 | Samsung CLP 300 Laser Printer
Colour cartridge has run out and printer won't print.
Hi
Realy sorry but the only non new purchase option I have occsionaly found to work is to pull the colur cartridge and reinstal without using.'
Another one I've heard of and would definately not recoment is if you have an old recharge kit top the colour up with meths. My opinion of this is a great way to destroy your print head and cartridge.
Rewcharge kits containing all of your colours are inexpensive if a littlebit messy do it in the laundry or bathroom, over newspaper and preferably with a pair of gloves.
Kind Regards
Nov 14, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Refilled ink cartridges problem colour
this is not a printer problem, you have a problem with colour cartridge! u can fix this in 2 diferent way: 1. replace the colour cartridge with new one, or gently clean the nozzle cartridge with a wet tissue until the cyan colour mark a line on the tissue just like the others colours: yellow and magenta. maybe must repeat this several times.
Sep 13, 2008 | Canon PIXMA MP150 All-In-One InkJet...
HP colour cartridge no. 22 won't print
if the test pages come out OK then the problem can not be the printer !!!!!!!
it must be from the application
Sep 04, 2008 | HP Color LaserJet 2600n Printer
My Xerox DocuPrint M750 printer will not print black text but will print colour
This is just a suggestion. I recently bought a Staples refilled cartridge and had to return it because it did not work. When returning it the Staples Rep said that 50% of the cartridges do not work and get returned. This was an astounding amount I told the rep. Means nothing to him but to you, you may need to return the black cartridge if it is or is not a refill and try it out again. Let me know if that works.
Cynthia Charczenko
Jan 15, 2008 | Xerox DocuPrint M750 InkJet Printer
48 people viewed this question
jasbo
jasbo
