Question about Linksys (WRT54GC) Router
Linksys BEFSR41 V.2
I have a Linksys BEFSR41 V.2 router which is locked in the diag function with the LINK and DIAG LEDs on. A reset does nothing and none of the 4 ports are active. This condition started when COVAD did a diag of the system. I have replace the router but I would like to get this working as it has been a great router for about 8 years. It has worked FLAWLESSLY till this time and has the original firmware.
Any suggestions?
  • 45 Answers
The only way to revive the router is by doing a reset. If it still won't work I hate to be the to tell you this but the router is busted. Consider yourself lucky that it worked flawlessly for eight years. =)
Posted on Oct 11, 2008
I have RV082 Router , and Diag Led is constant what to do
Checking the Router's LEDs
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router check the lights on the front panel of the router.
The Linksys router's front panel will indicate the status of the connection. After connecting the broadband modem to the WAN or Internet port, the computer to an available numbered port and powering on the router, the following should be lit:
  • 1 - 8 (LAN)
  • DMZ/Internet (WAN2)
  • Internet (WAN1)
  • Diag
  • System
Step 1:
Make sure the System LED is lit.
NOTE: If the Diag LED doesn't goes off, you need to upgrade the router's firmware. For instructions, click here .
Step 2:
Make sure the LAN 1-8 ports is lit depending on the computers connected to the designated Ethernet port.
NOTE: If the LAN 1-8 port is not lit, make sure that the computer is powered on. You can also try connecting the PC using another working cable.
Step 3:
Make sure the Internet (WAN1) and DMZ/Internet (WAN2) LED is lit.
NOTE: If the Internet or DMZ/Internet LED is not lit make sure the Broadband modem is powered on and that the modem is properly connected to the Ethernet port
You can access the web-based user interface utility of the RV082 by using one of two methods:
  • Through the RV082 IP address ( by default), or
  • Through its default hostname ("RV082")
1. Open a web browser (Internet Explorer or Netscape Navigator)
· By IP address: Type ( is the default IP address of the RV082)
and click Go or press the [Enter] key.
· By Hostname: Type http://RV082 and click Go or press the [Enter] key.
2. When the username and password prompt appears, type admin in both the username and password fields. (admin is both the default username and default password for the RV082).
Nov 08, 2010 | Linksys RV082 Router (RV082-AU)
Power and diag lights are flashing no response to reset
if the power light on the router is flashing then thats a indication that the router has gone bad but u can try & remove the powercable from the router for 15 sec & then put it back or also try & reset the router for 30 sec
Jul 17, 2010 | Linksys Wireless-G WRT54G Router
I`m use linksys rv042 router I can try firmware upgrade. after firmware upgrade my router`s DIAG light comes on at that point. If I do a power cycle to it, often times, the DIAG light comes on a stays...
sounds like a bad firmware updgrade,
roll back the firmware by redoing the upgrade with your backup that you made prior to the upgrade.
you made a backup right? they may provide older firmwares on the manfactures website linksys is usually good about this.
Jun 11, 2010 | Linksys RV042 VPN Router
Red diag light flashing
This is happening because the firmware did not load correctly.
Please follow the link below and follow the instructions. there are many steps to use to resolve this.
Hope this helps!
May 30, 2010 | Linksys EtherFast Cable/DSL Router
Linksys orange reserve light preventing me from connecting to internet
Does it say diag on the orange LED. if it does, that means there is a problem with the actual hardware. try pressing the reset button on the router for 20 sec, unplug the power of the router for a minute, plug it back in and wait for the power light to stay steady for 1-2 minutes.
Jan 14, 2010 | Linksys (NR041) Router
Power light is on and doesnt blink, Link light is solid green and there's a red light on the "diag". when I try to plug a Lan cable into the router I get no up link. My friend ask me to take a look at the...
You said there is a diag light lit up on the router.
In that case you can try to reset the rotuer for 30seconds . unplug the power and plug it back in. wait for a minute.
Check the lights on the rotuer. If you still see the diag light then try to reset the rotuer again. If there is a diag light on the router then the rotuer is not working.
Try to reset the rotuer for 2 - 3 times . power cycle the router till you get no diag light.
Once the diag light is gone then reconfigure the router.
Connect the modem to WAN port and computer to one of the 4 ports. Do not conenct anything to the uplink port.
Reconfigure the router.
Click Here to know more about how to set up router
Nov 19, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Power and Diag lights blink.
When the diag and power light always blink it only means one thing there's a problem with the router, Try tor eset it by pressing the reset button for 30 seconds then after that tunr off the power for 5 seconds then trun it back on, of the diag and power light are still blinking the router is already bad and needs a replacemenet, If the router is still under warranty have it replace to Linksys this is the number 800-3267114.
Hope that helps.........
Aug 29, 2008 | Linksys Wireless-G WRT54G Router
Linksys WRT54G router
Yes there's a possibility that the router is dead already because that diag light will only be lit up when there's a hardware failure on it, you can try press resetting the router by holding the reset button for 30 seconds then power it off then power back on hopefully the diag light will be off, if still on you need to replace the router already...
Aug 15, 2008 | Linksys Wireless-G WRT54G Router
Router problem: Linksys router (RV016) not working
to reset your router there is a small button at the back of your router press it for a few second then start to configure again open your internet explorer then type the default af add then enter then at the log in box type admin leave the password blank then set up your router by entering your modem ip address, gateway,subnet mask ,dns... to get the ip rigth clik the connction icon at the lower right of your monitor then click status then click support
Mar 18, 2008 | Computers & Internet
Diag led
wat about the powerlight in the router....
Oct 24, 2007 | Linksys Wireless-G WRT54G Router
Open Questions:
Linksys (WRT54GC) Router Logo
167 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
