Question about GE Televison & Video
VCR ejects blank tape only
I have a GE VG2061, which is I don't know how old. Old. But it still works just fine, or so I thought. It loads and plays other VHS tapes very nicely, but I recently bought a blank VHS to record on. That one it won't 'keep down'-- it'll eject it a few seconds after I load it. If I push it back in, it'll just eject it again. If I try to fast forward, rewind, play, or record (before it ejects the tape) it'll sit for a few seconds and then turn off the VCR completely. I can't figure out what's going on because it behaves perfectly normally with other, non-blank tapes.
From what I can tell there is nothing wrong with the new tape. It looks as normal as can be.... any ideas what's going on here?
Notes: the record tab is intact on the blank tape (it's new!)
The clock on the VCR is set and there are no programs set to record.
Also, nothing stuck inside the VCR that shouldn't be there.
  • djscurvy22 Jun 11, 2009
    i got rid of the tape and bought a more expensive one at radio shack ($6 instead of $2-3) and that works fine. weird, but at least i got it solved.
  • 520 Answers
It sounds like the cassette is not releasing the tape so the machine can put it around the heads. This could damage the machine. Don't use it. A two dollar tape is not worth damaging your vcr. Throw it away.
Posted on Oct 11, 2008
  • Bob Citizen Oct 18, 2008
    ....or return it.
Cannot play a VHS tape. Push in and pops out.
The belt on the loader motor is slipping. This causes the tape to not completely position itself to allow the tape to load around the drum. The machine senses this and ejects the tape.
Feb 20, 2014 | Samsung DVD-VR375 DVD Recorder/VCR
VCR won't eject tape or play & powers off
It sounds as though it's jammed. If you're mechanically inclined you can unplug the unit, take the cover off, and manually eject it. Just look for the motor that drives the load basket and manually spin the shaft. The guide-posts should retract towards the tape and the basket will then lift and eject. Just be aware that whatever bit of tape that's out of the cassette won't spool back in. You will have to do that bu hand once it's out.
When you're done, plug it back in and let it cycle then put an old cheap tape in and see if it works. If not, take it in for repair.
Nov 08, 2007 | Emerson EWR20V4 DVD Recorder/VCR
I have the Philips DVP3150V/37 DVD Player / VCR Combo. The DVD player works fine, but when putting in a VCR tape, it plays for a few seconds then shuts itself off. Any suggestions on what to to?
The 3150 has two belts or bands that can slip when old, just like the old days. One is for loading the cassette and the other is for providing take-up torque for the tape. Have also seen the tape loading arms get out of sync and don't put the tape around the heads..... working on one now but dont have a fix yet..it has the loading problem.
Nov 01, 2011 | Philips DVP3150V/37 DVD Player/VCR
I have a philips DVDR3510V ( DVD/VHS Recorder) which is 16 months old. The problem is that the buttons on the recorder do not work ( except power button) . We thought we had got round this as the remote...
I can only speak to getting the tape out. If all else fails, you can take the player to your local best buy and have them remove the tape for a minimal fee of no more than 30$.
Jul 18, 2011 | Philips MWD2205 DVD Player/VCR
When I try to tape a program to the vcr, the tape ejects when I press record. I unplugged it as suggested in the manual and tried again. The dvd works fine.
Check the record switch in the video recorder. The thing that pushes on the tab on the video tape! If bent or broken, your VCR will assume that the blank tape has no tab and thus eject it, as though it was a protected tape!
Mar 04, 2010 | Televison & Video
Tape keeps getting ejected
This unit requires the rubber parts to be replaced. The loading sequence is not completing properly. The VCR will eject the tape when the sequence fails as a safety measure to prevent damage to either the VCR or the tape.
Parts cost for this should not be more than $10.
Dan
Feb 03, 2009 | RCA VR639HF VHS VCR
SAFE
Hold down the power button (or the vcr button if on a combination remote) for six seconds. This will unlock the child lock feature of the vcr.
Aug 12, 2007 | GE VG4060 VCR
My VCR is playing too fast
try recording on a blank tape and setting the tape speed to SP (standard play). you should also see options for (LP-long play) and SLP (super long play). I think your machine is stuck on SLP option. if no-go, look for a manual on the web.
May 27, 2007 | Daewoo DV-T8DN VHS VCR
Vcr not playing tapes, just ejects them
Not enough info. What is the product? Brand, model, how old?
May 13, 2007 | Philips MWD2205 DVD Player/VCR
Video tape ejects itself
not to overlook the obvious but check to make sure the record safe tab is still on the tape. (little black tab on lower left corner on back of tape)if tab is gone the machine will not go into record mode.
Mar 11, 2007 | Sony SLV-ED85 VCR
Televison & Video Logo
266 people viewed this question
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
