Question about Sony KP-46WT500 46" Rear Projection HDTV-Ready Television
Sony_kp_46wt500_46_in_rear_projection/focus I have same problem as yours, Red and green shadow with image pulled at edges. What solved your problem. Can you suggest
  • 185 Answers
Again a connection problem or a converge chip problem if the problem pops in and out by itself then it's a connection if not the stk's would take care of that. be sure to always check the limiting resistors for a higher than normal resistance that doesn't agree with the marked resistance usually 1 ohm or around that.
Posted on Nov 11, 2008
Out of focus, double blurred image with pinks & greens
Out of focus, double blurred Problem with the Sony KP-51WS500 51 in. Rear Projection Television
Apr 21, 2011 | Sony KP-51WS500 51" Rear Projection...
My sony KP-46WT510 has double images and the edges are red and green
Try pressing the Flash Focus button on the TV to adjust the convergence of the TV.
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 22, 2010 | Sony KP-51HW40 51" Rear Projection...
Sony kp51hw40 has green shadows and on edges in pictures and blue flickers on and off, tried all adjustments including screen, focus, and menu??? no luck
The CRTs in this model of TV had a problem with internal leakage. The blue was usually the first to show the symptom (flicker). Because all 3 CRTs are connected to the same high voltage source, when 1 acts up, the other 2 suffer as well. You need to replace the Blue CRT. However, this TV has some age on it... 1 tube will lead to 2 tubes, and 2 tubes to 3... They only last about 7 years. If you love the TV, replace all 3 (about $200 each). I recommend replacing the Red and Blue first, adjusting the geometry and convergence to the original Green. Then replace the Green, adjusting the geometry and convergence to the new Blue and Red.
Mar 15, 2010 | Sony KP-51HW40 51" Rear Projection...
I have a sony projection tv KP-46WT500 and have red/green shadows around the people plus some double word image that are red & green. On the tv guide the station #'s are double and green and red.The...
Replace Both of your convergence ICs STK392-??? they are big black ICs will have part number on them also CK pico fuses they look like resistors but are fuses they will be yellow or green will be around ICs.
Aug 08, 2009 | Sony KP-46WT500 46" Rear Projection...
Tripe image, blue, red and green color on image, not focus
you will need to replace the two STK392-560 ICs and also check the 4.7 ohm 1/2 watt resistors and the six 3.5 amp pico fuses.
May 05, 2009 | Sony KP-57WS510 57" Rear Projection HDTV
Red shadow on images and letting
Check your convergence, Using your original remote go to the Menu, in the settings select convergence, try to align the colors to each other.
Apr 20, 2009 | Sony KP-51WS510 51" Rear Projection...
Image on tv casts a red shadow.
TRY THE MAGIC FOCUS BUTTON. IF THIS DOES NOT CORRECT THE PROBLEM YOU WILL NEED A SERVICER TO GO IN AND REPAIR CONNECTIONS OR REPLACE THE CONVERGENCE IC'S AND OR RESISTORS. AND READJUST CONVERGENCE IN THE SERVICE MODE.
Jan 07, 2009 | Sony KP-57WS500 57" Rear Projection...
Focus problem, see Green and Red misalignment;
this could be caused by the loss of the power to the converge circuit or the failure of the converge chips-stk-xxx-xxx if the problem pops in and out it's a connection problem.
Oct 09, 2008 | Sony KP-46WT500 46" Rear Projection...
Red Shadow
UNDER THE FRONT DOOR PRESS THE BOTTOM BUTTON "FLASH FOCUS" AND SEE IF IT FIXES IT. IF NOT AND YOU SEEN RED DOUBLE OF THE IMAGE, THEN THE SET PROBABLY NEEDS THE CONVERGENCE CIRCUIT REPAIRED.
DON.
Feb 01, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-46WT500 46" Rear Projection HDTV-Ready Television Logo
50 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
