Samsung SC-D363 Mini DV Digital Camcorder Logo
Posted on Oct 09, 2008
Eject flashing c with a pyramid symol to left. also says eject
  • seamus43 Oct 31, 2008
    the eject symbol with ..d is popin up how can i resovle this
  • Anonymous Nov 28, 2008
    different model... VP-D362, but same symptoms
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Oct 28, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
207
Points
The eject symbol with ..d is popin up how can i resovle this
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 27, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1633
Points
I need this program
Att.
George
Why were pyramids built/what were they used for
hi Emmi.
The ancient Egyptians built pyramids as tombs for the pharaohs and their queens. The pharaohs were buried in pyramids of many different shapes and sizes from before the beginning of the Old Kingdom to the end of the Middle Kingdom. There are about eighty pyramids known today from ancient Egypt.
Pyramids - Ancient Egypt
www.ancientegypt.co.uk/pyramids/home.html
Why was the great pyramids built?The Great Pyramid of Giza was built for the Fourth Dynasty Pharaoh Khufu (or Cheops), and was completed around 2560 BCE. ... The Great Pyramid is the largest of the three pyramids, and it is part of its own smaller complex that also contain 3 smallpyramids that were built for Khufu's wives.The Great Pyramid of Giza: Last Remaining Wonder of the Ancient ...https://www.ancient.eu/article/124/the-great-pyramid-of-giza-last-remaining-wonder-of/
What was the purpose of the pyramid?Pyramids. The ancient Egyptians built pyramids as tombs for the pharaohs and their queens. The pharaohs were buried in pyramids of many different shapes and sizes from before the beginning of the Old Kingdom to the end of the Middle Kingdom. There are about eighty pyramids known today from ancient Egypt.Pyramids - Ancient Egyptwww.ancientegypt.co.uk/pyramids/home.htmlSearch for: What was the purpose of the pyramid?
How many years did it take to build the pyramids?20 yearsThe Great Pyramid, also known as the Pyramid of Cheops, in Giza, Egypt took 20 years to build.18 Feb 2010How long did it take to build the Great Pyramid in Egypt? - Travel Mamashttps://travelmamas.com/how-long-did-it-take-to-build-the-great-pyramid-in-egypt/Search for: How many years did it take to build the pyramids?
if you want to know more go to this link.
Why were pyramids built what were they used for Google Search
Ejecting dvd
Look for a character that looks like a little pyramid on the screen or when you touch the Finder key. Hit it and when it goes off it means that you ejected the disc.
Idk wat the symol <:L>
In HTML (2.0) < means "less-than sign"
> means "greater-than sign" >
I would expect L> to render as; L>
As far as I know there is no specific L> symbol.
My ps3 the yellow light flashes then the ride light goes on then shuts off it won't open to install a game
hey its the symol of overusage of yourps3 which result in overheating..itry switchin gon in the safe hdmi mode if it doesnt work try this site to solve the problem..
HOW TO CONNECT A PYRAMID 10 BAND GRAPHIC EQUALIZER/AMPLIFIER
It has a blue witch and a green witch?
Recommend contacting a local car audio professional or Pyramid customer support directly here:
http://www.pyramidcaraudio.com/ContactUs.aspx
How to hook up a pyramid pro plus 4 channel pb-180px without using rca jacks for 6 by 9s
The pb180 has High Input receptacles on the back end. They are marked High Input and identified as Channels 1&2 left/right, and channels 3&4 left/right. You will need to identify all speaker wires coming from your head unit ( left front +&--) , and so on. You will be sending the speaker wires from the head unit to the pb180's High Inputs. In other words, the front left speaker wires(+&-) from the head unit will go to the High Input Channels 1&2 side, left input of the pb180, and so on, so the speaker wires coming out of the head unit will need to be cut. And LABEL all sets of speaker wires before you cut them! Then on the OUTPUT end of the pb180, you will be sending the wires back to the the respective speaker wires which are going to the speakers. So it's out from head unit to pb180 and out from pb180 to speakers.
Hopefully you have the plugs that Pyramid uses for the speaker wire inputs to the amp. If not you have to get creative, and make up terminals to fit into the input receptacles. Maybe a wire terminal from Radio shack will fit those pins..
Also, if you go on line: Google search "Pyramid auto amps" and click on "SEARCH" (upper right hand) of their Web Page. Plug in your model number like this, pb180, and you'll be able to download the manual for this amp. The manual has a full description of the wiring options.
Hope this was helpful and Good Luck!
5helpful
2answers
Coin pyramid puzzle
These are the coins
Solution:
On the second row move the coin on the right up.
On the third row move the one at the far right to take the place of the second row right.
On the third row take the one at the far right and put it at the top left.
Voila
Oct 09, 2008 • Toys
26helpful
4answers
Wiring a pyramid 903G
red - power
Black - Ground
Blue/Black - rear Left Speaker Positive
Blue - Rear Left Speaker Neg
White/ Black - Front Left Speaker Positive
White - Front Left Speaker Neg
Brown/Black - Rear Right Speaker Positive
Brown - Rear Right Speaker Neg
Yellow/Black - Front Right Speaker Positive
Yellow - Front Right Speaker neg
Green - Left Input Positive
Green/White Left input Neg
Gray Right Input Positive
Gray/White - Right input Neg
Top Samsung Video Cameras Experts
302lab
Level 1 Expert
NOEL
NOEL
 Grubhead
Grubhead
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
