Question about Samsung HCL4715W 47" Rear Projection Television
Samsung PCL542R Manufactured in 2002 color is off
I have asked 4 techs with 15+ yrs experience and got 3 different answers :( My color is turning a little yellowish/green and have seen a yellow or organish circle about 5" in dia on the screen but only when it's on for awhile. I puilled off the front to look into the 3 tubes... Red has a image, Green has a image and Blue has no image but is as bright as the other tubes so I'm guessing this is probably my problem. 2 tech say it might be the Board, 1 says it has to be coolant and the other tech said the tube is going bad and they don't make the tubes anymore, then goes on to say SAMSUNG tubes can't be recooled... Who is right lol Any ideas ? I'd haul it in for service but no truck and they want $100 just to come look at it.
If you did not see the picture on the blue tube; that is your problem -- the drive signal is not getting to the video amp and the mixed color from the green tube and the red tube is giving you a different color wich is unnormal. a good picture is when the 3 crt are emitting the video
Posted on Oct 09, 2008
Service manual
Search Google by model # and call Samsung Tech support.
Nov 03, 2013 | Samsung PCL542R 54" Rear Projection...
Strange yellowish circle appearing on white shirts
i believe the stains are actually semi burn marks. If you are drying your whites try a lower heat setting. i had this problem with my kenmore dryer before too. Got bad especially with towels. Make sure your vent is not clogged and your filter is cleaned regularly to let the heat flow better. should help.
Sep 17, 2007 | Whirlpool LER8648L Electric Dryer
Fuse list ford contour
The following specifications are for the Ford Contour and Mercury Mystique manufactured throughout 1995-2000.
Fuses Rating Color Circuit
Engine bay fuse box
1 80 Black Power supply to main fuse box
2 60 Yellow Radiator fan
3 60 Yellow ABS
4 20 Yellow Daytime running lights
5 30 Light green Fog lamp
6 30 Light green Not used
7 30 Light green ABS
8 30 Light green Air pump
9 20 Light bue PCM module
10 20 Light bue Ignition switch
11 3 Violet PCM memory
12 15 Light bue Horn & hazard flasher
13 15 Light bue Oxygen sensor
14 15 Light bue Fuel pump
15 10 Red Right-hand low beam
Passenger compartment fuse box
16 10 Red Left-hand low beam
17 10 Red Right-hand high beam
18 10 Red Left-hand high beam
19 7.5 Brown Heated door mirrors
20 10 Black Windshield wipers
21 30 Light green Electric windows
22 7.5 Brown ABS
23 15 Light bue Reverse lights
24 15 Light bue Brake lights
25 20 Yellow Door locks
26 20 Yellow Main light
27 15 Light bue Cigarette lighter
28 30 Light green Power seats
29 30 Light green Heated rear window
30 7.5 Brown Engine management
31 7.5 Brown Instrument pannel lights
32 7.5 Brown Radio
33 7.5 Brown Front and rear sidelights (left)
34 7.5 Brown Interior lighting & clock
35 7.5 Brown Front and rear sidelights (right)
36 30 Light green Air bag
37 30 Light green Heated blower
38 Unused
Relays Color Circuit Location
Engine bay fuse box
R1 Green Daytime running lights (Canada)
R2 Black Radiator fan (high speed)
R3 Blue AC cut-out
R4 Brown AC clutch
R5 Dark green Radiator fan (low speed)
R6 Yellow Starter
R7 Brown Horns
R8 Brown Fuel pump
R9 White Low beam headlights
R10 White High beam headlights
R11 Brown PCM power supply
R12 White Interior and courtesy lights
R13 Yellow Heated rear window
R14 Yellow Heated blower
R15 Green Windshield wiper motor
R16 Black Ignition
R17 Unused
R18 Black One touch window switch Driver's door
R19 Blue Cruise control cut-off Central fuse box bracket
R20 Unused
R21 Unused
R22 White Fog lights Interface module bracket
R23 Black Turn signals Steering column
R24 White Left-hand flasher Door lock module bracket
R25 White Right-hand flasher Door lock module bracket
R26 Unused
Bulbs / Lights Wattage Type
Low beam headlamp 55 9006 Halogen
High beam headlamp 55 9005 Halogen
Parking / Side light 5 2357A Wedge
Front turn signal 21 2357A Bayonet
Rear turn signal 21 1157 Bayonet
Tail light 21 1157 Bayonet
Stop light 21 1157 Bayonet
High mount stop light 5 2723 Bayonet
Fog/Driving light 55 893 Halogen
License plate 5 6418 Festoon
Reverse light 21 1156 Bayonet
Front sidemarker 5 2357A Wedge
Glove box
Map light 5 64111 Wedge
Dome light 10 6411 Feston
Step/Courtesy light
Trunk/Cargo area
Engine compartment 10 89 Wedge
Automatic trans indicator
on Apr 15, 2015 | Ford Contour Cars & Trucks
Trailer Wiring Cheat Sheet
Hello all,
For those of you that have or occasionally borrow trailers and look at the wiring plugs with disdain (I mean face it they don't make sense, ground is white, +12vdc is black, etc), this is for you.
The following are the accepted standards for different trailer types.
The different plugs and connectors used are marked with either a number or letters. Having the functions of each in advance can save a lot of trial and error when troubleshooting..
Plug Types/Application
7 Way - RV Trailers, Horse and Utility Trailers
6 Way - Horse, Stock and Utility
4 Way - Utility Trailers
Columns are: Color, Function, Mark on the plug.
Seven wire Trailer plugs:
Horse, stock or utility trailers:
White = Ground - 1
Blue = Electric Brakes - 2
Brown = Tail and clearance lights - 3
Black = Battery, aux power - 4
Yellow = Left turn/Brake - 5
Green = Right turn Brake - 6
Orange or Purple (not both) = Auxilliary or Reverse - 7
Recreational Vehicle:
White = Ground - 1
Green = Tail and clearance lights - 3
Red = Left turn/Brake - 5
Brown = Right turn Brake - 6
Yellow = Auxilliary or Reverse - 7
Six wire trailer plugs:
White = Ground - GD
Yellow = Left turn/Brake -LT
Green = Right turn Brake -RT
Brown = Tail and clearance lights - TM
Red or Black (not both) = Battery, aux power - A
Blue = Electric Brakes - S
Recreational Vehicle: (color, use, plug mark)
White = Ground - GD
Brown = Right turn Brake - RT
Green = Tail and clearance lights -TM
Black = Battery, aux power - A
Red = Left turn/Brake - LT
Four wire plugs:
White = Ground
Ground should be 10ga.
Others 14 ga
Best regards
on Dec 25, 2009 | GMC Blazer Cars & Trucks
3 Horizontal lines distorting picture
When you say "distort the picture", are you referring to dark image? double picture
Jan 20, 2013 | Samsung Touch of Color LN52A650 52 in. LCD...
My break light are out and i do not no what color the fuse are so i can replace them
The fuses are colored based on the amps. Usually under the fuse # it will tell you how many amps to use. Usually as follows though: 4-pink, 10-red, 15-blue, 20- yellowish, 25-clear 30-green, 40-orange
Aug 18, 2011 | Dryers
What causes the yellowish hue in the centre of the screen
There are several different types of projection sets: some use 3 picture tubes, red,green,blue--if this kind of set is what you have the coolant used in the blue tube is bad-----this type of problem leaves red and green which = yellow.
Most common in Samsung, Philips, Magnavox type sets.
If it is a newer set without picture tubes (a dlp style set) yellow in the middle of the screen would denote a damaged optical light engine.
Let me know brand, model number, date made----all are on back of set.
Feb 25, 2011 | Televison & Video
Where can i find a owners manual for my samsung television model number pcl542r
Go to : - you can download it
Mar 07, 2010 | Samsung PCL545R 54" Rear Projection...
I have a small issue with my brand new Samsung PN58B650 plasma TV. When I turn on the TV for the first time during the day, the picture appears but the colors are mostly pink, green, and yellow. ...
Take it back!!!
This is a bad sign of more issues trust me after 15 years in the biz. If you got a chance take it back and stay away from that line
Sep 22, 2009 | Samsung PN58B650 TV
Screen is green
You might have a faulty HDMI cable--I just had this same problem: audio was fine, but TV was green-screened. I tried everything, finally opting for last-generation multi-colored cables (one double-ended yellow, white, and red, and another blue, green, and red). Believe it or not, this solved the problem. Resetting the TV is another option--use your original TV remote and look for Reset under the menu options.
Sep 11, 2009 | Televison & Video
Samsung HCL4715W 47" Rear Projection Television Logo
136 people viewed this question
Jerry Greenberg
Jerry Greenberg
