Default codes for parental control
I own a Olevia HD tv and the Parental Control has me locked out . I need a default password too reset it so I can operate my tv .
I found in an online manual for the Polaroid 2632, code is 8202 and it works I just unlocked my own tv with it
Posted on Nov 08, 2009
Just tried 8202 on my Polaroid 2632. It worked right away. 0000 did not work. Thanks for the help. The big problem that I have now is that the sound cuts in and out. for the longest time there was no sound at all. Any help with that would be appreciated.
Posted on Nov 18, 2009
Is there a master code to reset the Parental Restrictions. I locked it a while back and forgot the code
Yes - the factory default password is 9999. This can still be used even after setting your own password. If you need any assistance with changing setting the parental lock settings, please let me know.
Jan 15, 2011 | Olevia LT37HVS 37 in. LCD HDTV
Model 232-S12 The screen is stuck on parental control. It is asking for a four digit password which we do not know. It also will not allow us to enter a password.
The default password on this TV is 9 9 9 9.
To get to the screen to enter this and deactivate parental control do the following;
1) Turn on your TV and press the "Menu" button.
2) Use the arrow keys on your remote control to navigate to the "Parental" header, then press the "Enter" button
3) Enter "9999" at the password prompt. That will lift the password lock.
Thanks for using FixYa.
Nov 13, 2010 | Olevia LT32HVM 32 in. LCD Television
Magnavox child lock help
hello The parental control menu enables
you to limit access to programs that
may contain objectionable material
or are not suitable for viewing by
children. The default access code is
The following table provides details
about the menu items:
Component Function Range / Options
Lock Enable
Enables the parental control lock. When
enabled, channels with objectionable viewing
content are blocked and can only be
accessed with a password. You can block
channels according to the movie or TV ratings
of the channel’s programs.
Off, On
Movie Rating Helps you block programs based on their
movie ratings. See “Movie Rating” on
page 25 for more details.
TV Rating Helps you block programs based on their TV
ratings. See “TV Rating” on page 26.
Change Code Changes the password for the parental control
Press the number keys to
change the password.
Reset Resets all channels and programs to their
default factory settings.
Parental Control Menu
Lock Enable
Change Code
Main Menu
Parental Control
Channel Setup
Press Right to Enter
Press New Code
Off On
TV Rating
Mar 13, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
We just recently moved and we just got are cable hooked up and the tv now has a parental control on it How do I get it off?
You control access to the Parental Control features with a password. The default password is “0000”. You can
change the password to any four-digit number.
To change the password:
1. Press the MENU button to open the main On-Screen Display
(OSD) Menu.
2. Press the on the remote control three times until the
Parental Controls menu opens.
3. Press button on the remote control to highlight Parent
Lock Enable. The “Key-In Access Code” window opens.
4. Use the number pad to type the default password (0 0 0 0), then
press OK.
5. Press button on the remote control to highlight Access
Code Edit.
6. Press the on the remote control to enter into the submenu.
You will need to use the number pad to type the default pass
word first.
7. Use the number pad to type the new password.
8. Confirm the new password by retyping it.
9. Press the EXIT button on the remote control immediately to exit the OSD menu.
Dec 11, 2009 | Vizio L32 32 in. LCD HDTV
How can I get my Olevia tv back to the factory settings?
It's at the bottom of the Miscelaneous Menu (Book & wrench icon):
"Reset Factory Settings:
Initiating Factory Default will reset all OSD settings to original
manufacture settings. The only items, which will remain unaffected are:
Auto Scan Channels
Edited Channels
Parental Control Password "
If you are trying to take off the parental password:
"Note: If you forget the password, press "9999" to lift the Password lock
and change to a new preferred password. "
"" = Quotes straight out of the manual.
Nov 06, 2009 | Olevia LT37HVS 37 in. LCD HDTV
Reset Parental Control
There you go:
1) Hit [MENU]. Press [CH up / down] to select ?V-CHIP SET UP?, then hit [VOL up].
2) Enter 4-digit access code with the Number buttons. If you have not set up your personal access code, enter 0000 (default access code).
Jan 09, 2009 | Emerson EWF2004 20" TV
What is the v-chip code for polaroid tv
DVD discs equipped with the child lock function are rated according to their contents and settings vary from disc to disc. Depending on the disc, you can lock out selected scenes or playback of the disc altogether. Access parental control by pressing the left/right (direction buttons together) on the remote control and then press the OK button.
System Setup/Password
Parental control features are password protected. The original setting is unlocked. This setting allows you to use number buttons to input any password. Note: The Default Password is 1369. This password is always effective even after you
have selected your own password and changed it. To avoid the possibility of others using the default password to set the parental level and change the password, you can record this default password in another area and delete it from this manual. Some discs can be limited depending on the age of users while some discs cannot.
Manual is here
(you need Adobe Reader) and their phone # is
at the end!
Jan 05, 2009 | Polaroid FDM-0700A 7 in. TV/DVD Combo
Parental Control Lock password Spectra KT2313
default passwords are often 1234 or all zeros that would be a good starting point
Sep 08, 2017 | Spectra KT2313 Combo
How do you reset forgotten parental control password?
Disconnect power to the TV. The power interruption will allow you to reset the parental control password to the default password of 0000.
To change the password after disconnecting the power, do the following:
1. Press the Menu button on the remote.
2. Arrow up / down to SET LOCK CODE
The lock icom will appear
3. Arrow left / right to operate
4. Press 0 to access the lock code
5. The first digit will be highlighted.
Arrow left / right to select the number
Arrow up / down to move to the next digit
4. Continue to follow these directions for all 4 code numbers.
5. Arrow up / down to FINISH
6. Arrow left / right to save settings and exit.
The password has now been reset.
Nov 29, 2007 | JVC AV-36260 TV
I'm really guessing here - -but while you're in the parental controls screen I believe you can use 0-0-0-0 as a backdoor key. It's different for every manufacturer, Philips uses 0-7-1-1 example. But the users's manual for that TV says that the "default" is 0-0-0-0.. Don't really understand their use of that terminology so it's merely a guess... But here's something I am really sure of;;; The owner's manual can be downloaded for free at the Vizio web site: and their support line is: 1-888-849-4623 or you can email tech support at: Hope this helps. Good Luck Bill
Jun 05, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
796 people viewed this question
Top Televison & Video Experts
