Question about HP PSC 2210 All-In-One InkJet Printer
Carriage jam I've turned the machine off and on and I still have a carriage jam - they will not move.
  • 905 Answers
Will need hands on to determine the reason for the jam , but try to look and see if you can see anything inside that coulbe causing it , piece of paper or maybe something with the ink cartridge
Posted on Oct 09, 2008
Why does my HP C4480 say "carridge jam" and flash when there is no paper inside the machine and I've cleared the carriage to the left? I have to turn it off and back on to have it work again.
Paper has nothing to do with the carriage jam. Something is hindering free movement of the carriage back and forth. Check to see that the carriage moves freely, and there are now buildups of dirt or trash in the area. You may wish to reset the print cartridges to ensure they do not hang when moving.
Feb 24, 2015 | HP PhotoSmart C4480 All-in-One Printer ...
I can not manually move the printer carriage on my HP Photosmart B210e printer
Might be service station jammed.Service station work is to clean the print heads,stores spitting ink init as we as capping the print heads to protect from the nozzle drying..After switching off the machine service station capping the print heads and arrest the carriage assm for protecting the print heads, in this condition carraige assm wont come out until its released by service station. Its required expert to release the service station, if you force to pull it will damages the print heads.. You justify what you can do for this issue...If you are capable do it...But care fully
Jan 09, 2012 | HP OfficeJet Office Equipment & Supplies
My HP 8500 a909a states there is a carriage jam. However there is not paper jam. I've tried resetting it and turning off, pluging into wall outlet, removing and replacing the printheads. I think...
Hi, please try this:
1. Remove all media from the output tray.
2. Check the duplexer.
a. Push the button on either side of the duplexer, and then remove the panel or unit.
b. Locate any jammed media inside the device, grasp it with both hands and then pull it towards you.
c. If the jam is not there, push the latch on the top of the duplexer and lower its cover. If the jam is inside, carefully remove it. Close the cover.
d. Reinsert the duplexer into the device.
3. Open the top cover and remove any debris.
4. If you have not found the jam and have Tray 2 installed, pull out the tray and remove the jammed media, if possible. If not, do the following:
a. Ensure the device is turned off and disconnect the power cord.
b. Lift the device off Tray 2.
c. Remove the jammed media from the bottom of the device or from Tray 2.
d. Reposition the device on top of Tray 2.
5. Open the print carriage access door. If there is paper remaining inside the device, ensure the carriage has moved to the right of the device, free any paper scraps or wrinkled media, and pull the media towards you through the top of the device.
6. After clearing the jam, close all covers, turn on the device (if you turned it off) and resend the print job.
Aug 23, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
The error 6A81 comes up on the sml screen of my canon PIXMA MG5150 It suggests to turn it off and on again which I've done but the same error comes up????
This is a purge unit error. There maybe something jamming the purge unit or just a absorber out of place which is picking up on the carriage preventing it from moving correctly. if you can move the carriage away from the purge (its where the printhead/carriage parks its self on the right side of the machine) with no resistance then you can shine a torch into the machine and look at the purge unit. there maybe crumpled paper jammed in the purge. If all looks well then the purge may need replacing. Lastly the wiper on the purge may have stuck. It slides back and forth and they have been known to stick. just push it with a long screwdriver to see it it moves.
Good luck
Jun 04, 2011 | Canon MG5150 AllInOne Printer
How do I clear a carriage jam error on a Dell 942 all in one printer?I changed both ink cartridges and the carriage moved and let out a scratching sound and the error msg, clear carriage jam came up on the...
Carriage jam errors usually mean something is blocking the carriage from moving. It's usually a crumpled piece of paper left over from clearing a jam, or a faulty purge unit/capping assembly.
You should check to see if the printhead is locked or movable when you power off the unit. If it will move freely when it should be locked then something is blocking it from moving into the "home" position. If there is no foreign object inside then the capping mechanism in the wiper or purge unit may be broken or jammed. Oft times a good disassembly and bath for the purge unit will get it working again. However, this depends on how technically skilled you are and how much the machine is worth. It would take at least an hour in a shop. If you don't do it yourself and the machine is worth less than $100, it may be time to replace the machine.
Sep 24, 2010 | Dell 942 All-In-One InkJet Printer
I have a Epson stylus CX9400fax a piece of paper is jammed way inside the machine, I can't even see it to try and get it out! I've tried turing the machine on/off numerous time (still not expelling the...
If paper is jammed, a Paper jam message will appear on the control panel display.
Follow these steps to clear the jam:
  1. Gently pull any jammed paper out of the output tray or sheet feeder.
  2. If the paper is stuck inside, turn off the Epson Stylus CX.
  3. Open the scanner, remove the jammed paper and torn pieces, close the scanner, and turn the Epson Stylus CX back on.
    alert_note.gif Note: Be sure to check the far left of the carriage area when checking for jammed paper. Paper that is jammed there may be hidden from view.
If paper jams inside the Automatic Document Feeder, clear the jam as follows:
  1. Open the Automatic Document Feeder cover and remove any jammed paper.
  2. If necessary, lift the document cover and remove any paper that has jammed inside.
  3. Press OK to clear any messages on the display screen.
Jun 02, 2010 | Epson Stylus Multifunction Inkjet Printer/...
Carriage jam - Turn machine on, get carriage jam message, however the carriage can move freely if moved by hand. If I close and hit enter, carriage sounds like it's moving, then I get the error message...
Sorry about the B.S., you can move the carriage by hand, and all you need is to clean the encoder strip that runs across behind the carriage assembly. You can wipe the strip gently with an alcohol swab or a Q-tip moist with alcohol. The bars on that strip tell the carriage where it is and grease or ink on it will give the carriage jam error. No calibration necessary after moving the head or cleaning the strip.
Jan 07, 2010 | HP OfficeJet 7410 All-In-One InkJet...
My hp 1040 constantly jams have tried to clean it and makes little or no difference any suggestions. It will print half of a page then it will say that it is jamed.
>first try to power reset the fax machine, then see if the error still persist..to to a power reset unplug power cord from the back and wall outlet then wait 30 sec and then plug it back
>if the error still persist open the the rear access door and check the if there is any jammed paper in there.using a lint free cloth lightly moistened with distilled water wipe the rollers clean. also check if there is a paper jam from the inside of the printer by opening the cartridge access door
>If there is no paper jam and it gives you a paper jam error message then try to check if the carriage can move freely, first while the printer is on open the cartridge access door of printer cover, the carriage will move to the center which will give you access on it, now unplug power cord from the back of printer with out pressing the power button off. try to check if there is any debris or paper that is blocking the carriage path. with your fingers try also to move the carriage from left to right and see if it can move freely. if the carriage can not move then you have a carriage jam which causes also the paper to jam, if it can move freely then try printing and see if it will jam again.
>also try to remove and reseat the ink cartridge.
>if this will not resolve the issue try a hardware reset, while the fax is on unplug the power cord from the back with out turning it off. press and hold # and 6 at the same time.while holding the buttons plug back the power cord and wait till you see semi-full or nvn reset when it turns back on then release the buttons. if the machine will not automatically power back on press the power button. it should ask for you to select language, region etc a proof that you have successfully done the reset..try printing...
>if it jams again contact hp and ask for replacement if it is still in warranty if its not ask for an upgrade
Sep 21, 2009 | HP 1040 Plain Paper Inkjet Fax
How to Clear carriage jam on HP PSC 1610 Printer? No obvious paper jam visible.
Dear it's the carriage jam error. so it mean that your carriage is jam not paper. so open the printer where you insert the cartridge. check whether it is jam or what . cartridge carrier is jam kindly turn off the printer and try to move the cartridge head by hand very gently and if seems to be stuck than check for anything which abort him to move freely so than might be anything like dust or else. when you get success in moving the head put some machine lubricant on the rod on which head moves and check it ok.
Dec 04, 2008 | HP Office Equipment & Supplies
R200 jammed carriage Grinding belt
Hi-
Normally it will not allow you to move carriage manually. Belt is broke. have it service or purchased a new one.
Hope this helps
Nov 08, 2008 | Epson Stylus Photo R200 InkJet Printer
HP PSC 2210 All-In-One InkJet Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
