Question about Panasonic Televison & Video
We have a panasonic vcr/dvd combo which works fine. The remote however has a broken play button, it just won't play. All the other buttons seem to work fine. We have changed the batteries but that doesn't work. The model # on the remote is Eur7720x40. If this can't be fixed, where could we get a new remote from please? '
snakehead
  • 1074 Answers
SOURCE: Use Zenith XBV443 DVD Player / VCR Combo without remote control
if you need a remote control for your unit go to www.partstore.com and purchase a originald remote for your unit.good luck.
Posted on Apr 08, 2007
  • 2326 Answers
SOURCE: Panasonic Instruction Manual and Remote for VCR/DVD Combo DMREZ47V
Check HERE to downlaod the instruction manual.
For the remote you should do a google with your DVD model number.
Posted on Feb 29, 2008
SOURCE: Philips Universal Remote with Emerson VCR/DVD Combo
http://www.urc.philips.com/
US2-PM335
There you will find all needed information
Posted on Jul 05, 2008
SOURCE: WHEN I TRY TO USE
I called tech support and their answer was simple!
Error Code U30 1.......the fix, press and hold the number one (1) on your remote and at the same time press and hold the ENTER button for 10 seconds while pointing the remote at the units sensor.
Automatically, my unit returned to normal and all my buttons on my remote returned to operational mode!
So, it was confirmed by Vincent at Panasonics tech support, that error codes U30's are rare, but it's a system safety feature. If you were to come across an error U30 2, you would push and hold the number 2 while pressing and holding down the ENTER button....so on and so forth.
I hope this helps someone else out there!
Shelley
Posted on Jan 08, 2009
SOURCE: Need code for Emerson TV,DVD,VCR Combo
called comcast
Posted on May 28, 2009
Remote codes for Panasonic MODEL# PV-DF2704
5 digit code for the comcast red button silver remote is 21462 this pertains to Panasonic MODEL# PV-DF2704
Nov 20, 2011 | Panasonic PV-DF2703 Triple Play 27 in....
Remote broke how can i record vcr/dvd player . wnat to record on my vcr?
I assume this combo unit has basic front panel buttons (behind the right-hand door - where the copy button is) - there should be a drive select (VHS or DVD) button stop play record. I strongly advise if you really need a remote for this model, particularly when it comes to menu/setup options, that you search various online and similar stores for one.
The cost will depend where you go and who you deal with - and if the remote is available (you can always ask Panasonic about a remote for a DMR-EZ48V even though your model may be a DMR-EZ47V - they both use the same remote (N20AYB000136 or equivalent number); they can probably tell you how to order one through them, the price, etc.
A universal remote may work, but with limited functions. If the combo unit works in general, you should not have too much trouble obtaining a replacement remote (just keep in mind the model above).
The remote may cost just over $100 but remember, this is only if you want full control of your combo unit.
Mar 13, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
Remote control arrow buttons suddenly dont select things anymore
Read page 36 of your users manual Its all under Manual Exposure
Please rate our help ++++
Thank you for using Fixya.com
Sep 01, 2009 | Panasonic PV-DM2794 27 in. TV/VCR/DVD...
Panasonic DMR-ES45V - DVD recorder / VCR combo Remote not workin
My remote is not working. When I press a button, I get the following message on my unit: U12, U30, SET #, CHK REMOTE #, or RC #. What can I do to fix this? The message displayed means that the remote control and unit are not communicating and the remote needs to be programmed. To program the remote, press and hold the same number that is displaying on the unit and the [ENTER] or [OK] button for more than 2 seconds. For example, if the unit displays “SET 2”, press and hold [2] and [ENTER] or [OK] for more than 2 seconds.
Jun 04, 2009 | Panasonic DMR-ES46VS DVD Recorder/VCR
DVD PLAYER Locker
press the stop key on the television and the on/off button on the remote at the same time.
Dec 26, 2008 | Panasonic PV-DM2792 Triple Play 27 in....
Need remote control code for Panasonic PV-DF2703
I found a newer Comcast PDF file that shows a 5 digit number for tv with vcr ( no mention of DVD) but the code worked to turn on the tv and cable box together. My problem is it won't work the volume, yet
https://www.comcast.com/MediaLibrary/1/1/Customers/Customer_Support/Digital_Cable_with_OD/Digital_Cable/remotes/Remote_M1067BX3.pdf
Dec 24, 2008 | Panasonic PV-DF2703 Triple Play 27 in....
No remote--how do I record a dvd
On the lower right side of my unit there are STOP - PLAY - RECORD buttons
for operation without a remote control.
Dec 13, 2008 | Panasonic PVD4744 DVD Player/VCR
Panasonic PV-D4743S combo DVD/VCR player won't eject DVD
This unit has seperate power supplies for the DVD and VCR side and the DVD side supply seems prone to failure. I have not isolated the cause, but can tell you this will require a component level repair. Unless you are a tech you may as well buy a new unit.
Sep 22, 2007 | Panasonic PV-DM2794 27 in. TV/VCR/DVD...
Dvd not ejecting
I just found my solution. I pressed the power button on the remote and the stop button on the tv at the same time, and it unlocked the dvd eject.
Sep 14, 2007 | Panasonic PV-DM2792 Triple Play 27 in....
Televison & Video Logo
98 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
