SOURCE: Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
SOURCE: My printing displays wrong ink levels and prints blank pages
If your cartridge is new (or full) and you know that not just from ink levels display, then you did not used the printer for a while (at least a month) and the nozzles of the cartridge are clogged. If u used the cartridghe 4 or 5 moths ago, then the whole cartridge is dryed out, so get out and get yourself a new cartridge.
If it's just a month, then you should put a paper-tissue on a small plate (like a coffee-cup plate), then put some boiling water on it, just 2~3mm of water over the tissue.
Put the cartridge with the nozzles part downside on the tissue, in the hot water.
Let it stay there in the water 30 min.
Put the cartridge in an other clean tissue, than shake it strongy as if you want to force ink to get out trough the nozzles. Then clean gentle the nozzle part of the cartridge on some sheets of tissue.
Install the cartridges it in the printer and run a few cleaning processes from the printers maintenance software.
If the cartridge is new and just installed in the printer, and you have the inklevels but it does not print, then get it out of the printer and back to the store, they should replace it for you. I hope you removed the protective plastic stripe that covers the nozzles before installing the cartridge?...
OK, let ne know please how things evolve.
Hope it helped you, rate the solution.
Almoust forgot: ink levels are displayed by Lexmark inkprinters by estimating the ink consumed trough you printing process, it has no sensors in the cartridge. It's just kind of a counter, you can evan set an empty cartridge to be seen as a full one.
SOURCE: Printer stays offline on Vista
To help you resolve this problem, try the suggestions below.
The Basics:
1. Check your cables and their connections. Reconnect the parallel or USB cable to the computer and to the printer. Make sure there is a direct connection, with no scanners, switchboxes, or hubs inline. Other devices can sometimes cause communication problems between the computer and printer. For more information on this issue, see 'Scanners and Other Devices' below.
2. Remove the power supply cord and reattach it to the printer. The printer should make a noise soon after the power cord is reattached. Note: This is a general diagnostic that seems to fix minor communication issues.
3. If you are using a parallel port, verify that your computer is set up for bi-directional communications. If bi-directional communication is not enabled on your computer, the parallel port mode setting in the computer CMOS setup will need to be set to either bi-directional or ECP. Do the following:
1. Right click on My Computer and select Properties.
2. Click Device Manager. You should see a section called Ports (COM & LPT). There should be a (+) sign to the left of that section.
3. Click on it, and look for ECP Printer Port (LPT1). You may need to contact your PC manufacturer if any of the following are true at this point:
* It does NOT say ECP in the description.
* There is no listing for Printer Port or any variation of'LPT.
* There are question marks or exclamation points next to the LPT1 port listing.
Let your PC manufacturer know what you are trying to accomplish and what you have done up to this point.
4. Go to Start, Settings, Printers. Right click on the Lexmark object and select Properties.
5. Click the Details tab.
6. Under Print to the following port, it should say LPT1 for parallel cables and USB Lexmark or USB00x (<x> = 1-9) for USB cables. You can change these values by clicking on the arrow and selecting a new value from the list. Click Apply, and OK.
If you are using a USB cable and the USB value is not in the list, try uninstalling and reinstalling the driver as detailed in your manual.
If you are using a parallel cable and do not see LPT1, you will need to ask your PC manufacturer to walk you through the process of turning your parallel port on. You will also need to make sure the Lexmark printer is set as default. If not, right click on it and select the default option.
7. If the printer does not work when connected directly to the computer's port and you have complied with the steps above, there may be a hardware problem. In this case you should perform a self-test on the printer. (Click Start a New Search above this solution and enter self test in the search field.)
Scanners or other sharing devices could cause communication problems.
* If you are using a parallel connection, please verify that your cables, scanner, or other sharing devices are IEEE-1284 compliant .
If you are using an USB connection, they need to be at least USB 1.0 compliant.
* If the printer prints normally without the scanner/sharing device and its cables, there might be a problem with the scanner/sharing device. Please contact the manufacturer for information on how to fix such issues.
Note: Although connecting devices through a scanner (or other sharing device) may work, we do not recommend or support the use of such devices as they can interfere with the signal strength that is sent to the printer. Please contact the manufacturer of the scanner/sharing device regarding communication issues for that specific device.
USB Issues:
2. Click Device Manager. Click on the plus (+) sign next to Universal Serial Bus Controllers. The host controller listed here is the software that runs your USB ports. It is linked to a chipset on the motherboard that requires frequent updates to satisfy the needs of newer products such as your printer.
3. Look at the name of the host controller. Some of the more common names are Ali, Intel, AMD, Via, and SIS. You will need to contact your PC manufacturer to get help updating these specific controllers to the newest driver set.
If YOU are the PC manufacturer, check the manual for your motherboard to find out who makes the chipset for the motherboard. Again, Ali, Intel, AMD, Via, and SIS are some of the more common manufacturers of chipsets.
4. Look for either Lexmark USB Printer or Other Devices in the Device Manager.
5. If you see anything with Lexmark..., click on the plus (+) sign to its left and look for Inkjet Color Printer below it.
6. If it is present, double-click on it. Tje next screen should report that the device is working properly.
7. If you see any question or exclamation marks listed in the Device Manager (small yellow icons next to the listings), double-click on those items to obtain information on what's wrong with the items. This information is useful for troubleshooting the system.
8. If not or there is nothing present, you will need to uninstall and reinstall the printer driver software, or download a newer version from our web site. Click here and follow the link to our Drivers & Downloads center.
It is also recommended that you connect your printer to a USB port that is hardwired or "part" of the motherboard. USB ports that are located in the front of the PC and those that are located in the expansion card slots may cause communication issues if used for printing. You should always try to use the USB slot that is located near your peripheral slots, i.e., your mouse, keyboard, parallel and serial ports.
Multiple PCs:
The printer cannot be connected to multiple PCs at the same time. This includes, but is not limited to, using both the USB and parallel ports of the printer and the use of switchboxes. The system board on the printer will get confused at multiple requests for status, even if one computer is off and the other is on.
Docking Stations:
If you are using a docking station, try using the printer with a different, standard computer with parallel equipment as a test. You may want to contact the manufacturer of your other device for information on the correct functioning of a pass-through device. If the printer does not function correctly when directly hooked to a computer, the hardware may be at fault and the printer will need to be run through the self-test.
Converters/Adapters:
Lexmark printers do not support USB/parallel adapters and will probably not work. Nor will any USB/Parallel constructed cables. Our printers require either an IEEE 1284 bi-directional parallel cable, or a USB v.1.0 or 2.0 A/B style cable. Some printers can only use the parallel cable, some can use only the USB, and some can use either one. However, Lexmark cannot support printers hooked up to computers with a cable that attempts to cross between parallel and USB platforms, as this will cause communication issues.
Software Interference:
A piece of software may be interfering with the printer's communication ability, or your computer may be experiencing a system resource problem. We can try to alleviate these issues by putting your computer into Selective Startup mode. This will prevent any software applications other than Windows from loading when the system starts. To do this:
1. Click Start, Run.
2. Type MSCONFIG on the Open line, then click OK.
3. When the System Configuration Utility opens, place the marker dot beside Selective Startup. Below that, deselect Load Startup Group Items. Then click Apply and OK. You will be prompted to restart the system.
4. When your system restarts, only the Windows operating system should be running. You should not see any icons in the lower right-hand corner of the screen, beside the clock.
5. Try your action again. If it works, the source of the problem was one (or more) of the applications that were loaded into memory.
6. You can return your system to its original configuration by clicking Start, Run, typing MSCONFIG and clicking OK. This time, select Normal Startup, click Apply and OK, and restart the computer.
SOURCE: lexmark x5495
Lexmark advertises the cartridges supplied with this printer as cart. #28 and #29. They claim these are nonrefillable. The refillable cartridges are #28a,29a, 34 and 35, the last two being the high yield carts. Make sure you have one of these.
SOURCE: RESETING INK LEVELS???
We recently purchased and installed an HP Compaq presario, and now we don't get the printing display in the lower right corner that would indicate the task in progress with page of page, number of pages and...ink levels. Also we can't cancel a project in 'mid-print' without turning the printer off and on again/
For Windows OS:
1. Go to Control Panel.
2. Open Printers and
Faxes.
3. Right-click on Lexmark
3600-4600 Series print object and click on Properties.
4. In the Lexmark 3600-4600 Series Properties window, go to Advanced tab. Click on Printing Defaults.
5. In the Lexmark 3600-4600 Series Printing Preferences window, under Ink Use, select Print
using black ink only. Click OK.
6. Click OK button in the
Lexmark 3600-4600 Series Properties window to save the changes.
Your printer will print in
black and white draft mode the next time you send a print job to the printer.
For Mac OS:
1. With the file (you wish
to print) open, go to Print. A window will pop up.
2. Select the Lexmark
printer.
3. Expand the arrow
pointing down beside printer name if you're not able to see other options for
printing. Look for Quality and Media.
4. Under Paper tab, select Print in Black
and White.
5. Save this as your
default print setting. Click Presets option and choose Save as. You can
personalize the name for this default print setting (e.g. Black and White Draft
or My Setting).
Select this Preset name
every time you print your files/documents.
