GE Washer does not reach full spin speed...stops abruptly
Hi...thanks for your suggestion regarding my GE washer spin cycle problem, however the problem happens without any water in the tub.
I just tried it again and I noticed a "burning" odor coming from the motor. My gut is telling me the motor is shot...any thoughts?
  • jodijoec Oct 09, 2008
    Yes, the motor seems to run fine intially, but then stops before the spin gets to the higher speed. When the motor stops, the pump continues to run. As for the belt, it looks good. What should I do to check the clutch? What are signs of a bad clutch?
  • jodijoec Oct 10, 2008
    I replaced the motor/clutch assembly today and all is working well. Thanks again for the help.
  • 943 Answers
The motor does run right. the belt could be worn. or the clutch at the bottom of the motor check that.
Posted on Oct 09, 2008
  • john gagnon
    john gagnon Oct 09, 2008
    if the clutch is worn thats what it does. remove the motor anc look at the clutch you will see its worn.
My maytag neptune mah3000aww spins slowly then reverses, then spins slowly. will not reach regular spinning speed. What is the problem?
it could be a balance problem. Most machines are programmed to abort fast spin if the drum is unbalanced. This can be caused by too much in there, or possible the contents have clumped together somehow. Try a spin cycle only with an empty machine and see if it reaches full spin
Feb 18, 2015 | Maytag Neptune Washer Door Mah3000aww
Washer does not spin out the clothes to dry
Hi There
I found this for to read to help you on your problem hope this helps.Let me know how it goes.
If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Thank you for writing to fix ya.
Best Regards Richard
Dec 29, 2009 | Washing Machines
Washer stopping abruptly at end of spin cycle.
Hi, it sounds like maybe some dust has gotten in the basket drive pads causing it to stick. Has it been happening long? Sometimes it will work its way out. Try turning the tub with your hand clockwise. You can also put a heavy load in the washer (wet) and let it get to a high spin. Then open the lid and see if it starts stopping slower.
If this doesn't clear its self up, you will need to change the basketdrive.
Please let me know if this has helpped.
Thanks
Vic
May 17, 2009 | Kenmore 15864/15862 Top Load Washer
HI thanks for your question. the G E washer has to get rid of all the water before it starts to spin. check to see if you have a good water flow on pump out. if not clean the pump . thanks the appliance doc. please rate my answer. thanks
Oct 08, 2008 | GE Washing Machines
Beach towels sopping wet after machine done spinning
The washer will not proceed into high speed spin with just two large beach towels in the basket. The washer is detecting a out of balance condition, and remains in low speed spin. Solution? Try adding more items into the basket. With only two towels, there is not enough mass to balance the washer. With more clothing or towels, there is more items for the machine to balance, and reach full speed spin.
The only other thing that could cause this, would be if the water in the tub is not completely draining in the time allowed. This washe does not have a cleanout, and checking for an obtruction in the pump is difficult. I would go with the more clothes first, then see.
Sep 25, 2008 | GE WSXH208A Front Load Washer
Washer turns slow loaded or not
front load machines will normaly spin slow on first part of spin cycle this helps distribute load evenly before hi speed spin also if load is extermely off balance ..a large towel with load of light fabrics will never spin to full speed due to off balance produced by wet towel hi speed spin is normaly acheived in last 3-4 min of spin cycle
May 11, 2008 | GE WBVH6240F Front Load Washer
GE washer, does not spin
You probably broke the 4 black snubber straps on the top of the tub lid and it is cousing your washer to always be off balance and not reach a full speed spin
Oct 30, 2007 | GE WBSR3140DW Top Load Washer
Front load washer
Only possibilty is that the is still a blockage in the filter area, sump hose or you are using the delicate spin programme. Regards Advisor
Sep 01, 2007 | GE WBVH6240F Front Load Washer
Washer stops after wash cycle
the timer is bad you could try cleaning the points by taking it apart very hard to do though
Aug 27, 2007 | Kenmore 23822 Top Load Washer
Washer will not spin
Could be a bad clutch or transmission. I would either call a tech or get a new washer (these newer GE models don't seem to be very reliable, go for a Whirlpool/Kenmore model next time). Here are breakdown diagrams for your washer: http://www.appliancepartspros.com/partsearch/model.aspx?model_id=230151 Hope this helps, APP Tech
Aug 07, 2006 | GE WJSR2070B Top Load Washer
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
