Question about Lands Phones
DLINK i2eye DVC-1000 videophone
Hi again, could I use a speakerphone in the telco jack in the rear & still be able to pick up the handset for the private conferencing sessions. Sort of like "kill 2 birds with one stone" theory.
    Brigadier General:
  • 6,966 Answers
Appreciate the direct "Ask Me".
With reference to your concern "...XX...", to my knowledge, yes. Although the unit has its own built-in speakerphone, the telco jack at the rear can accommodate:
  • cordless phones;
  • external speakerphones;
  • phone recorder; and
  • regular landline phones.
Cheers.
Posted on Oct 09, 2008
Cannot hear caller
To be check handset speakerphone part or electronic part for that speakerphone. There is difference handset speakerphone and speaker.
Jan 26, 2018 | Panasonic Lands Phones
There is a function key "fwd/dnd" is keep flashing on My Panasonic kx-t7030x phone. How should I cancel for it?thanks!!!
The slow flashing indicates that your phone is currently set for Call Forwarding.
To cancel from this phone, pick up the handset (or use speakerphone), then press this key sequence: [FWD/DND], [0], [#].
The light should turn off, and you should hear a confirmation tone. Once you hear the dial tone again, hang up using the handset or speakerphone button.
Source: page 3-19 (79) of http://www.google.com/url?sa=t&rct=j&q=panasonic%20kx-t7030x&source=web&cd=2&ved=0CFoQFjAB&url=http%3A%2F%2Fpdf.textfiles.com%2Fmanuals%2FTELECOM-F-R%2FPanasonic%2520KX-TA624%2520Users%25203.pdf&ei=ycQCUdf0O5To9gTK_YDQAg&usg=AFQjCNEt0-JdZEhH0WCSSp6Sl7VOmARFbA&bvm=bv.41524429,d.eWU
Nov 04, 2012 | Lands Phones
How to block pornsite using router?
I found the best site to do this with is www.opendns.org
What you do is go there sign up they will give you two dns server address. you need to go into your router under DNS servers and put in there's then on there dashboard you select the level of protection trsut me this works!!!! I am currently using openDNS and it blocks allot of junk.
good luck and please do not shoot the meesenger and leave postive feedback and ratings.
Jun 11, 2010 | D-Link DVC-1000 I2EYE (DLINKDVC1000) Video...
My phone is stuck on speakerphone. When I pick up...
There are two things to check that you can fix. First, try replacing the handset (curly) cord. A broken wire in the cord can make this happen. If that's not it, watch the hookswitch. That's the plunger that goes down when you put the handset in the cradle, and pops back up when you lift the handset. If it's stuck down, you will only get speaker and no sound in/out of the handset.
May 21, 2010 | Nortel Norstar 16-Line PBX Speakerphone
How to reset factory default i2eye dvc-1000
Look at back or side of router you will find a small hole with a button marked reset, push this button in for a few seconds, with power OFF and this will return the router to "From the factory" settings IE: Blank
Feb 18, 2010 | D-Link DVC-1000 I2EYE (DLINKDVC1000) Video...
Why the phone is hook off? how to fix it?
My grandaghter has D-Link Videophone DVC-1000. She got it set up and tried to call me. l have VP ( Sorenson - l am deaf ) . l can see her but she can't see me
Jan 24, 2010 | D-Link DVC-1000 Video Conference
VoIP setup with 2 lines - Both lines pick up on outgoing calls
It does not matter that you have VoIP or traditional telco with the problem you are describing. I think you have a problem with the adaptor or a wire. Check the connectors and the plugs in the phone to see if anything is bent.
Oct 14, 2009 | RCA ViSYS 2-Line Speakerphone
Problem Obtain IP SCREEN BLOCKED, must restart unabled
My grandaughter has D-Link VP . She got it set up and tried to call me. L have VP ( Sorenson - l am deaf ). l can see her but she can't see me
Apr 21, 2009 | D-Link DVC-1000 I2EYE (DLINKDVC1000) Video...
Connecting VP calls to other devices
Evidently you are using the D-link service to receive calls. You will need to use the IP address of the VP100. D-link service is only compatible with D-link
Jan 12, 2007 | D-Link DVC-1000 I2EYE (DLINKDVC1000) Video...
Lands Phones Logo
98 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
