Question about RCA RTD120 System
Won't work with my tv
Disc will work, but tv can't access rtd120 audio without a dvd operating. Do I need an RCA tv like it says in the manual.
    Master:
  • 505 Answers
You need to connect a Audio video cable (Red/White/Yelloe) from the TV out on you TV set to the approriate input in your DVD player
Posted on Oct 09, 2008
I am trying to hook up a Memorex DVD player (MVD 2022), and I am not getting it to work. I need to see how to connect the cords or what cords I need. I can't seem to find how to download a manual.
Connect a yellow RCA cable from the yellow video jack on the DVD player to the yellow video input jack on the TV. This will give you the picture. For sound, connect a white RCA cable from the white audio jack on the DVD player to the white audio input jack on the TV. This will give you sound. Use the TV remote to select the input you connected the DVD player to, just press INPUT SELECT or VIDEO or the like until you see the DVD player's output.
Power on the TV and the DVD player. Place a DVD in the disc tray of the player and press PLAY.
If your TV has only a RF coax input, then you will need to buy an RF Modulator.
Mar 15, 2011 | Televison & Video
Get RCA DVD Player to work.
ok on dvd player u wann use hdmi cable direct to tv ok then select input hdmi on tv remote to see picture
Feb 02, 2008 | Thomson Lyra PDP2860 Digital Media Player
Can i run my cable box thru the rtd 120 to my tv to get cable
Why bother?
Generally speaking, I'd run the best Cable Box audio to the RTD and the best Cable Box video directly to the TV if you don't want to risk problems inherent with extra unnecessary (and expensive) video cabling.
http://www.retrevo.com/support/RCA-RTD120-Home-Theater-Systems-manual/id/402ag609/t/2/
The RTD120 has no digital audio inputs so you're limited to RCA-type analog TV audio. Bummer.
Feb 13, 2011 | RCA RTD120 System
I was wanting to know what kind of burned dvds it will play
it plays with no problem : CDR,CDRW,DVD+/-R,DVD+/-RW,Audio mpe 3,Compact Disk Audio(CDDA),Video Compact Disk(VCD),DVD Audio,Dolby digital track,JPEG pictures
Jan 09, 2011 | RCA RTD120 System
Remote doesn't work rca model #F32648,i can't access the input function. The onscreen menu doesn't show it or I cannot find it. Problem is without it I can not use the DVD player.
This isn't a solution but I am unable to acccess the input either. My tv is hooked to a dvd,vcr and direct tv satellite with a dvr. I watched a movie on the dvd and the tv won;t allow me to switch the input back to satellite tv.
Apr 10, 2009 | RCA F32648 32" TV
How to connect blue ray disc player to rca rear projection tv
Unfortunately, there are a couple potential problems. First of all, if you RCA rear projection tv is fairly old and is not a High Definition tv, you may not have an hdmi, dvi, or component connector cables inputs. Without these, you are left connecting your blu-ray only by the standard yellow (video), along with the audio (red and white) rca cables... either way, the High Definition portion of the blu-ray won't work with a non-High Definition tv. It may be time to buy an HD capable tv to use your blu-ray effectively...
Dec 29, 2008 | Televison & Video
User Manual
Why did you disconnect the chat session?
Anyways here are the detailed instructions for connecting a DVD recorder to a TV
  1. The first step to connecting a DVD Recorder to your TV is to determine what type of connection you want to make between the TV source (Cable, Satellite, Antenna), the DVD Recorder and the TV. This is usually determined by the outputs and inputs available on the DVD Recorder and the TV.
  2. If you have an older TV that only accepts RF (Coaxial) input, then you would connect the RF output (a coaxial cable) from your TV source (in my case a Cable Box) to the RF input on the DVD Recorder. Then connect the RF output from the DVD Recorder to the RF input on the TV. This is the most basic (and lowest quality) option for connecting a DVD Recorder to any TV.
  3. If you want to use higher quality cables, then you may want to connect the TV Source (Cable and Satellite only, not Antenna) to the DVD Recorder using Composite, S-Video or Component video and audio cables.
  4. To use composite cables (also known as RCA, the yellow plug is video, the red and white plugs, audio): Plug in the composite cables to the RCA outputs on the back of your TV source and then plug in the composite cables to the RCA inputs of the DVD Recorder. Then connect the RCA outputs from the DVD Recorder to RCA inputs on the TV.
  5. To use S-Video and RCA audio cables: Plug in the S-Video cable to the S-Video output of the TV source. Plug in the S-Video cable to the S-Video input on the DVD Recorder. Next, connect the RCA audio cable to the output on the TV source and the input on the DVD Recorder. Finally, connect the S-Video cable and the RCA audio cable to the output on the DVD Recorder and the input on the TV.
  6. To use Component Video cables and RCA audio cables: Connect the Component Video cable and the red and white RCA audio cables to the outputs on the TV source and the inputs on the DVD Recorder. Next, connect the Component Video cable and RCA audio cable to the outputs on the DVD Recorder and the inputs on the TV.
  7. Now that the TV source (either Cable, Satellite or Antenna), the DVD Recorder and the TV are all connected, you need to configure everything to make sure that TV is coming through the DVD Recorder, for recording and viewing.
  8. Turn on the Cable Box or Satellite Receiver, TV and DVD Recorder.
  9. If you connected everything using the RF connections then the TV should be passing through the DVD Recorder and displaying Television on the TV screen. To record in this mode, you would need to tune to either channel 3 or 4 on the TV and then use the DVD Recorder TV Tuner to change channels and record.
  10. If you made connections using either Composite, S-Video or Component cables, then to view or record TV, two adjustments need to be made. First, the DVD Recorder needs to be tuned to the appropriate input, typically L1 or L3 for rear inputs and L2 for front inputs. Second, the TV also must be tuned to the proper input, on a TV usually Video 1 or Video 2.
  11. If you have a Dolby Digital 5.1 Surround Sound A/V Receiver you can connect either a Digital Optical Audio cable or Coaxial Digital Audio cable from the DVD Recorder to the receiver to listen to audio through the receiver.
Sep 27, 2008 | Televison & Video
PLAYER DOES NOT READ
thanks i am going to purchase a new one..
Jul 04, 2008 | RCA RTD120 System
Setting up the surround sound
Make sure the TV is 'looking' at the right input. If your system is connected to A/V input 1, then make sure the TV is set to that input. If everything is ok there, pressing MENU should bring it up. It's easiest if there is nothing in the DVD player.
You can also download the manual from RCA's site. CLick the link below to get it.
http://support.rca.com/main.html?pagetypeid=6&topicid=307&selectedmodel=RTD120&navtypeid=2&selectedFamily=video&prevPageIndex=2
Hope this helps, and please rate my advice, good OR bad.
Good luck!!
Feb 04, 2008 | RCA RTD120 System
RCA RTD120 System Logo
142 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
