Question about Whirlpool Washing Machines
Washer shaking/vibrate vigurously - Whirlpool Washing Machines
    Filmmaker:
    Uploaded 5 video answers.
  • 41 Answers
The problem with washing machine when they spin to dry your clothes. the clothes are not distributed equaly at the sides of your machine. if your machine vibrate vigurously again all you have to do is pause your machine to open it safely and you will see most of your clothes are located at one side. try to minimize their number by distributing some of your clothes to the other side of your machine and start your machine.
i hope i was able to help you!
Posted on Oct 09, 2008
Loud vibrating washer
What is the model number of the unit?
Mar 03, 2014 | Kenmore HE2 Plus Front Load Washer
Washer shakes terribly in spin cycle
Does the floor or the walls shake? If they do you have to beef up the flooring under your washer, with blocks between the floor joists, piers, or sistering of the joists. If there is no shaking of the floor or walls, and your washer is solid on the ground, leveled and not rocking, then it is your washer. Lg has problems with too much vibration in their washers. Check to make sure that your lint filter/coin catcher is clean. Open the door in the bottom front, put a towel down to catch the water, Unplug the washer, and unscrew the large plastic screw that is the filter for your washer. If this has debris in it clean it out completely. Look in the hoses also, if your water drain is restricted by lint or coins or other debris, the washer has clothes in it that are wetter and heavier than they should be, and this will cause sever vibration. Good Luck, Appliance Specialists
Jan 26, 2010 | LG WM-2277HW Front Load Washer
An extreme vibration in spin cycle. It makes the
Because front load washers are VERY HEAVY, they shake if you have a wooden floor. If your front loader sits on concrete and it still shakes, then you have to make sure all is balanced. If it still shakes, then inside the system there are shock absorbers that need to be checked.
Nov 12, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Our front load washer vibrates so much durning the spin cycle it actually knocks the dryer off the top of it. It will also vibrate across the floor unless 2 people are holding it down. We have tried the...
make sure that the nut on the leg is tihgtend down. check level lower on wash machine if all else fails buy shake away pads follow the install directions and see if that helps. i love my shake aways my floor doesnt vibrate any more.
Jul 09, 2009 | General Electric WSSH300G Front Load...
Terrible vibration on washer
make sure your locknuts on your pedestal are tightened all the way up
Apr 15, 2009 | Maytag MAH8700AWM Neptune Front Load...
VIBRATION
It should have should leveling legs under it. Screw upwards all the legs. Means your washer is now at its lowest level. Shake the washer with both your hands. Adjust the leg where the shake is, upwards or downwards to stop the shake. When the shake is totally removed, lock the legs with the check nut above the leg; meaning there 2 nuts, one above the leg & one under. You most probably have to check out your corner of the machine, where the problem lies. It is important that you lock the nuts or the problem will recur.
Apr 01, 2009 | Maytag Washing Machines
Washer is shaking violently when it is time for the spin cycle
Hi you must make sure its level in all directions. ie front to back and side to side. Alos dont overload it. If its on a wooden floor it will vibrate. A concrete floor is the best
Feb 15, 2009 | Washing Machines
Remove the shipping bolts from the back of the washer. Please see the instruction manual for more information, but there is severe vibration if you don't remove them. It seems a lot of people overlook this step.
Dec 27, 2008 | LG WM2688HWM TROMM SteamWasher
Front loader vibrates and moves
You shd check the front legs - they shd be a maximum screwed up, that is the machine shd be tilting forwards. Then you adjust acccording to your floor level. The machine should not shake a bit when off, & you try to shake it with both your hands.
A little vibration is normal when the spin starts. Don't forget to rate me nice............
May 24, 2008 | Kenmore 46462 Front Load Washer
Washing Machines Logo
179 people viewed this question
Dan Webster
Dan Webster
Sal De
