Question about Ovens
Whirpool oven How do you change the oven sensor model #SB160PEXQO
  • SULLI45 Oct 09, 2008
    I guess i have to remove gas oven from wall
  • 943 Answers
HI the sensor can be replaced from the back and front. 1 screw holds it in the oven . remove back panel disconnect the sensor . thanks the appliance doc. please rate my answer. thanks
Posted on Oct 09, 2008
Fault code E4 F3
The F3 codes mean that the oven temperature sensor has a problem. In the case of the E4 error, it is an open circuit. (If the GR465XLS0 is a double oven model, it's the lower oven with the problem with the sensor.)
You need to replace the sensor. Unfortunately, I'm not sure that you have provided the correct model number. Most Whirlpool ovens have an extra character in the model number. If your model is the GR465LXLS0, the temperature sensor will cost ~$65. One source is http://www.appliancepartspros.com/Appliance-Parts/whirlpool-oven-sensor-assembly-item-number-ap4326911.aspx .
I hope this helps.
Sep 07, 2012 | Whirlpool Ovens
Hi my whirpool oven is stating F 03 what do i have to do? Thanks
Usually the F-03 error code means you have a bad oven tempreture sensor. To test the tempreture sensor you would use a multimeter set to ohms. At room tempreture the sensor should read between 1000-1100 ohms any less then this and you would replace the oven tempreture sensor in the unit. If you have any further questions message me back. Please also remember when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future. Thanks
Rick
p.s I also looked afterwards in your service manual and the F-03 error code does refer to the oven tempreture sensor
Sep 13, 2011 | Whirlpool RBS275PD Electric Single Oven
Whirpool akz 431/01 chyba F 02
Hello & Welcome to FixYa
F2 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Apr 10, 2011 | Ovens
Where is the model number on my whirpool accubake oven
Look on the inside of the oven door.
Jan 29, 2011 | Ovens
E0 F3 Is the error code we're getting with our Whirpool Oven Accubake Gold? The oven is stopping mid bake and giving us this error code.
You should check the sensor for 1100 ohms at around 75F If shorted to frame or open then that is your problem.
Dec 17, 2010 | Whirlpool Ovens
Just bought a used whirpool accubake sc 465, keep getting E0-f3 error code, any ideas for a good fix?
Hello- The F3 error code indicates an open circuit in the temperature sensor. Pull back cover to access sensor wires.  At room temp the resistance should be 1000-1100ohms. If open, replace sensor. This should solve the problem. Let me know if this info helps- have more if needed. Thanks- Ed
Mar 13, 2010 | Whirlpool RBS305PDS Electric Single Oven
I have a Whirpool gas range. Everytimme I hit bake and start the oven starts to heat up. After about 20 seconds it shuts off. I got error code E303 so I replaced the oven temp sensor but that didnt fix the...
The flame sensor is bad. Go to repair clinic. com and put in the model and it will pullup the parts for your oven. Buy the flame sensor. It has to 'see' the gas flame to remain open from the gas valve.
Nov 06, 2009 | Ovens
I have whirpool oven GBS 307PRS00 after selfcleaning won't heat back up is this the fuse and can i replace it myself?
It was the TOD a little sensor in the back of the oven, it happened because when you self clean the temperature goes up to 1000 degrees. never self clean over 2 hours and only do it as
little as possible.
Oct 30, 2009 | Whirlpool GBS307PRS Stainless Steel...
Whirpool Oven Model # rb260fxyq f4 error code on display panel
Oven temperature sensor (RTD) shorted
Replace Oven temperature sensor (RTD)
Jul 06, 2009 | Ovens
Oven Stops Heating
try it on broil and let me know what it does i dont think its a sensor as they check their selves and set a code most of the time
Feb 15, 2008 | Ovens
Ovens Logo
113 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you an Oven Expert? Answer questions, earn points and help others
