Question about Gevalia CM-500 12 Cup Coffee Maker
COFFEE BASKET THE LITTLE SPRING ON THE BASKET IS BROKEN, WHERE CAN I BUY ONE.
I DID NOT SOLVE THIS PROBLEM, BUT I AM NOT INTERESTED IN PAYING NO ONE TO FIND OUT WHERE TO BUY THE ITEM I NEED. THANKS BUT NO THANKS.
Posted on Oct 10, 2008
Have a Mr Coffee model #BVMC-PSTX91. The filter basket has a spring loaded release that has fallen off - how do I put back on? cannot figure out how to put the spring and extra plastic piece on?
without seeing it (a picture) that is a difficult question to respond to. it may have possibly broken or a piece of plastic needed to keep it in place broke - or the spring is defective. suggest get a new basket. (or go to the store, or find a neighbor with a similar model - and look at his basket, take a pic of the spring mechanism with your cellphone and go home to fix your own.)
regards,
Jan 27, 2017 | Coffee Makers & Espresso Machines
I have a 55 cup Farberware Urn. Pot will perc coffee sometimes & sometimes not. Problem exists since new, & have replaced both thermos. Water gets very hot, but not as Coffee. Sounds like...
Hi. The spring slips onto the stem just under the coffee basket, it holds the stem with pressure so the perked coffee go up the stem onto the spreader, check repairshack.com Ron
Aug 15, 2010 | Faberware 12-55 Cup Coffee Urn
I have a krups coffemaker model 264A with a broken filter basket. Are these filters still available for purchase?
I have the same problem for the same Krups model 264A duo coffee maker. Does anyone know where I can buy a filter basket for this now-discontinued coffee maker?
Feb 15, 2010 | Krups Coffee Makers & Espresso Machines
The basket bottom spring-came aprt
it's broke. you didn't say what kind it is, but it's probably cheaper to by a coffee pot
Aug 06, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Rubber O came out & has been lost. I need to replace the rubber
Most well stocked hardware stores will have a box containing a huge assortment of rubber O-rings for sale at about 10 cents apiece. They come in varying thickness and diameters. If you're not sure, you might buy several to try and still not spend a dollar. The same part from the manufacturer will set you back ten dollars. I have no clue what your "plastic piece" may be, but if it's broken off you'll need to buy a new basket.
Dec 27, 2008 | Kenmore KBC12 Coffee Maker
Door spring came off filter basket door on Krups FME4 coffee mak
yhere should be a little post th spring goes on in the vack of the basket ...out in pkace hold untill in place
Dec 10, 2008 | Krups FME4 Coffee Maker
How do I put the spring back in that holds the door shut.
The replacement basket costs around $6.00 - don't fiddle with it, just a buy a replacement part from Cuisinart's website.
Nov 24, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Swing-out filter basket with pause and serve..not functioning properly
Something wrong with your little 'grab a cup' mechanism. There should be 2 hinged plastic pieces (one of which contains the 'nipple', and one spring. The spring is shaped like a squared off 'U', and is about 2 inches long. Check to make sure all these parts are there, and move freely.
Also, check the basket. It dovetails onto a swing arm, and could be misplaced. If the basket is not positioned properly, the pot will not push up on the mechanism to let the coffee out. Make sure the pot is able to be pushed fully onto the hotplate and trip the mechanism as well.
Jun 29, 2008 | Braun AromaDeluxe KF 580 Coffee Maker
Spring came out - where does it go?
That is from your dripp stop. If you can replace it it will be in the bottom of your filter holder. If not Please tkae out the valve on the bottom of this filter holder. You will have no dripp stop but it will work just fine.
Jun 01, 2008 | Krups Aroma Control 197 Coffee Maker
We bought a black&decker Spacemaker coffee maker last month and it has not worked properly but maybe a week. It seems to not want to flow correctly into the pot. We set it to come on and wake up to...
If the hole in the bottom of the basket isn't plugged, it sounds like the anti-drip feature isn't functioning properly. This is the series of levers that allow you to remove the pot while the coffee is perking without spraying liquid everywhere.
There is a vertical lever mounted at the back of the hollow where the pot goes, and the top end of that lever lines up with the spring-loaded lever that closes the bottom of the coffee basket. When the basket is in place without the pot, the bottom of the basket remains closed. When the pot is inserted it presses against the back lever and the series of contacts opens the valve covering the hole in the bottom of the basket, allowing the coffee to flow into the pot. If the sequence of contacts doesn't work the basket will overflow, and you get coffee and grounds everywhere.
Ensure all these parts align and are working properly. If there's a problem that can't be resolved, or parts are broken or missing, removing the spring-loaded lever from the basket will allow the coffee to flow into the pot. You will no longer be able to remove the pot while it is perking, but you'll have your morning coffee.
Apr 16, 2008 | Black & Decker SpaceMaker ODC150 Coffee...
Open Questions:
See all Gevalia CM-500 12 Cup Coffee Maker Questions
Coffee Makers & Espresso Machines Logo
152 people viewed this question
Top Gevalia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Andrew Taylor
Andrew Taylor
Are you a Gevalia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
