Question about Kenmore Elite 45986 Front Load Washer
Kenmore HE2 #1104751. Overflows as it is just beginning to fill with water
The machine leaks water from the dispenser unit as it is trying to fill the machine with water. it is like it is plugged up, but if a small bit of water is left it will drain into the machine, I have turned the water pressure down, but it still overflows. HELP
  • graphicbreak Dec 21, 2008
    I have the same problem with our 1yr 4 month old washer. The only help from Sears was to send a tech out for $65, then pay for parts and labor. I will never buy anything from Sears again.
  • pajamas123 Feb 28, 2009
    overflows as it is just beginning to fill with water at dispenser. then it slowly drains.
    Genius:
  • 1,028 Answers
Ck inlet just inside door upper left could be blockage in line from dispenser into tub especially if you have been using dry detergent remove detergent drawer and ck for blockage from that end too
Posted on Oct 09, 2008
It was a bottle cap blocking the hose under dispenser loosen one Allen screw on left side of control panel take three screws out of bottom panel then four screws out of main front panel leave door in tack it's heavy have someone hold it for you kee
Posted on May 02, 2012
  • ckl1939 May 02, 2012
    Kkeekeep door in tack it's hard to put main gasket back on if you don't hold it fairly close why you disconnect hose with pliers
Soap dispenser overflows with water
Need to know how old machine is etc. dispenser could be clogged.
May 19, 2010 | Kenmore Elite 45986 Front Load Washer
Fabric Softener Dispenser Overflowing
Sounds like you have a blockage check/ clean remove dispenser to do
Apr 06, 2010 | Kenmore Oasis HE 27082 Top Load Washer
Tank overflows. wont stop filling with water and spills onto floor.
unplug unit, if water still comes in than you have a bad water inlet switch.if not than you nead to check the line from the wwater level switch to the outer tube.if there are no leaks than you have a bad water level switch.
Dec 25, 2009 | Kenmore Washing Machines
Hello sir,i have a kenmore series 90 washer & dryer.this specific machine has top dispensing detergent/bleach&softner.when it becomes time for the softner to be dispensed on the re-fill the machine...
PLease check the hose that goes from the INLET VALVE to the dispensing system cup on your washer. This hose probably has a hole or the plastic dispensor is cracked and therefore leaking.
The inlet valve is working and when the time comes the water goes to the dispensing cup, so the system is working it is just the hose, dispensing cup or both.
Nov 19, 2009 | Kenmore Washing Machines
Kenmore 665.16039403 leaks water when filling
It is coming from the fill tube. You can pull the unit out or use a mirror to look up underneath. It might have come off or got a hole chewed in it.
Eric
Sep 25, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore top load washer 110-24642300 is leaking when it fills
tip the unit back and lean against the wall so you can look under it you will see the pump it is plastic. more than likley this is your problem. let me know if you need more assistance
Feb 24, 2009 | Kenmore 22642 Top Load Washer
Unfortunately - some repairs are expensive (labor wise) and not financially sound to repair.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 02, 2009 | Kenmore HE2 Plus Front Load Washer
Our Washer is overflowing through the dispenser drawer
water out of the soap drawer could be a multitude of things, start with removing the drawer and checking for blockage in the pipe from the drawer to the drum, next try turning down the water pressure a little sometimes that can help, or has the machine filled up totally till it overflows, that is a blocked pressure switch pipe, start with looking for the blockage first, work with safety unplug if removing lid etc. rate me if i have helped, thank you
Sep 16, 2007 | Maytag Neptune MAH9700 Front Load Washer
He2 leaking from detergent dispensor
Plug off the wall, etc. Remove the rear cover. There is a thin tube coming from the control panel area to the base where the water exits, this should not be blocked, remove from top and blow to check, refit. Next clean out your outlet filter, it could be clogged, refit. This tube controls the water level. Another thing that could be the problem: Try to take the top of the machine off; there are three tubes coming into the dispenser box, these may hv come loose or something. Connect well.
Sep 12, 2007 | Kenmore 46462 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
295 people viewed this question
Sal De GO PATS
fordexpert
Ed Mac
