Question about Amana Washing Machines
Washer fills with water, but does not agitate. Just hums
  • 750 Answers
Hello cordellhatch
Welcome to Fixya.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
* The lid switch may be defective. If it is, the washing machine doesn't spin.
The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
* The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small,
relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
* A belt may be broken. Many washing machines have one or two belts.
If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
* The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed.
As the clutch wears out, it may prevent the unit from spinning well or at all.
If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified
appliance repair technician.
* The drive motor may be defective. Many washer brands use a reversing motor.
For agitation the motor runs in one direction, for spinning and draining, the other.
It's possible for a motor to burn out in one direction and continue to operate in the other.
If this happens, you need to replace the entire motor.
* The transmission may not be shifting properly. Older washers produced by Whirlpool®
have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective,
the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem,
you may want to hire a qualified appliance repair technician to repair it.
* The spin bearing or basket drive may be worn or seized.
These components allow the inner tub to spin freely inside the outer tub. When this is the problem,
you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety,
washing machines are made so that they spin only with the lid closed.
The lid switch prevents the spinning action when the lid is up."
Posted on Oct 09, 2008
It wont complete cycle and empty the water just hums for a while and then turns its self off
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Jan 17, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
WASHER HUMMS BUT DOESN'T AGITATE
this sound i think come from motor so since there is no rotation the belt need to fit again or replaced by agood one,
g b y
Jul 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer does not agitate
Push down on lid to activate door switch.
May 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Will not agitate
Replace the direct drive coupling. Directions are in the attached video.
Apr 03, 2009 | Whirlpool Estate TAWS750PQ 27-Inch Washer
WHDSR315DDWW, Fills then just sits there and hums.
Push down on the agitator. You may have to hold the activating button in with the lid up so you can do this. Press down firmly on the agitator and it should start rotating. If it does, you need to have it replaced. If it doesn't, then let the store know and they should take care of it. You should not put any money into since it is new. Anything you do from this point will cost you some money to fix.
Feb 06, 2009 | GE WBSR3140DW Top Load Washer
Will fill water but agitator wont run.
Thats very agitating.There is a motor that runs the agitater,its either going out or you have lost the drive,a little spendy to have fixed.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Its fills with water but then sits & hums - dont agitate,drain
It sounds like the controller/timer is bad. If this is an old dial timer type control, can you turn the control and cause the washer to drain? If so, replace the timer control.
If it's an electronic control, then look for a failed sensor as it's very unlikely to be the control.
Jan 15, 2009 | Roper RAX4233PQ Top Load Washer
Model numer RAS6233RQ0...only get humming sound, and nothing else
yes i have a roper ras6233kg top load washer. I have not had any problem with it until about Two weeks ago, it over filled and it would only make a hummuing sound. Now it has dried out and have been working beautifully. Then Three days ago it stopped agitating,will not spin only making a loud humming noise. I guess its time to get another one.
Jul 24, 2008 | Roper RAS6233KQ Top Load Washer
Washing Machines Logo
87 people viewed this question
Top Amana Washing Machines Experts
Dan Webster
Dan Webster
Charles T Nevin
Charles T Nevin
Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
