Question about SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive
SanDisk 2GB Micro Flash Drive
I have lost all my files on my 2GB micro flash drive. It is like they never existed. I can save new files but all of my other ones are now gone. Is there any way to try to retrieve them?
Well unfortunately your flash drive have a static shock, that may cause for a electricity variation in some PC, that is a fisic damage and your flash drive can't be repaired...sorry
but i recommend to you to buy other, because your flash drive have a serious fisic damage is very unussual in a SanDisk flash memory, but sometimes the variation of electricity cause the fisic damage
Posted on Oct 09, 2008
Sandisk ultra sdhc card won't record in my canon digital camera. i get a memory card error
All you have to do is
Step One
To save data, use EASEUS Data Recovery software (free version - 1GB of data recovery). how:
1. Download and install EASEUS Data Recovery
2. Insert micro SD
3. Open EASEUS Data Recovery, choose Complete Recovery - Next
4. Select the drive micro SD - Next
5. Save the data to the hard disk (max. 1GB)
6. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4, 5)
After all data is secure, do the process repair micro SD
Step Two
The first alternative - use the software HP Drive Key Boot Utility
Using the HP Drive Key Boot Utility, for Win XP
1. Download and install the software HP Drive Key Boot Utility
2. Then, double click the file cp006049.exe - select Install.
3. Insert micro SD
4. Then, open the program "HP Drive Key Boot Utility" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
5. Remove the micro SD from the USB port, then insert it again.
6. Quick format micro SD (FAT file system)
7. Restore all data, to the micro SD.
Using the HP Drive Key Boot Utility, for Win Vista or Seven
2. Then, double click the file cp006049.exe - select Extract
3. Insert micro SD
4. Then, double click file hpdkbu.exe - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
The second alternative - use software HDD Low Level Format Tool
1. Download and install HDD Low Level Format Tool
2. Insert micro SD
3. Open program HDD Low Level Format Tool, select micro SD - continue
4. Click S.M.A.R.T - click Get Smart Attributes
5. Click LOW LEVEL FORMAT - click Format this device
6. Wait until the process is complete - press OK
7. Remove the micro SD from the USB port, then insert it again.
8. Quick format micro SD (FAT file system)
9. Restore all data, to the micro SD.
I hope this information helps.
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
Remove write protection of my memory card
i have a my memory no four met of tha sho unable to fourmet write proteket
Oct 11, 2011 | SanDisk 2GB microSD Memory Card
Micro sd 2gb tidak bisa format
Hallo scorpio, semoga solusi ini membantu
If the micro SD format fails, do not you repeat the formatting process. Because it will exacerbate the damage to the micro SD. Follow the steps below. Good luck.
All you have to do is:
Step One:
2. Choose Complete Recovery - Next
3. Choose the drive micro SD - Next
4. Save the data to the hard disk (max. 1GB)
5. Because of your micro SD 2GB, repeat the process of recovery (repeat step 2, 3, 4)
After all data is secure, do the process of removing the micro SD password
Step Two:
3. If you are using Win XP, double click the file cp006049.exe - select Install.
4. If you are using Win Vista or Seven, double click the file cp006049.exe - select extrack.
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Finish.
6. Remove the micro SD from the USB port, then insert it again.
7. Quick format micro SD (FAT file system)
8. Restore all data, to the micro SD.
2. Select micro SD - Continue
3. Click S.M.A.R.T - click Get Smart Attributes
4. Click LOW LEVEL FORMAT - click Format this device
5. Wait until the process is complete - press OK
If the second solution does not work, it means your micro SD damaged firmware. Based on experience, one of the causes of damage to the firmware is, the formatting process is done repeatedly, but always failed.
I hope this information helps. Thank you for using FixYa!
I have a 2GB micro sd card,but when i check it into my cellphone,my memory card is error.What is the problem of my memory?
Step One:
Step Two:
Using the HP Drive Key Boot Utility, the first way
5. Then, open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - Create new or replace exiting configuration - Next - Hard drive - Next - Create new file system - Next - wait until the process is completed - Next - Create firmware flash package - Next - Finish.
Using the HP Drive Key Boot Utility, a second way
1. Open the program "HP Drive Key Boot Utility or hpdkbu.exe" - Next - select drive - Next - select Backup / Restore - click Restore - From filename, click Browse - Look In. Find the file initrd.img
2. If you are using Win XP, the location of the file in C: \ Program Files \ Compaq \ hpdkbu \ flash \ initrd.img - Next
3. If you are using Win Vista or Seven, the location of the file in the folder where you extract the files cp006049.exe. After the file is found, press Next
4. This process, will take a very long time, so you wait. This way you do for a capacity of 2GB. This involves when, the first way did not work. If the process runs smoothly, the chances of success, but if the process is running very slow, the possibility of failure and immediately stop the process. If you are unsure, or afraid to make mistakes, you should not do it this way.
5. After the process is complete, remove the micro SD card from the USB port, then insert it again.
Oct 07, 2011 | SanDisk 2GB microSD Memory Card
I lost the directions for using a micro mini
Find a USB-port on your computer.
Insert the flash-drive into the USB port.
Windows will report "found new hardware", and will assign a "drive-letter" (e.g., 'A:' is your diskette drive, 'C:' is your disk-drive, 'D:' is your CD-ROM device) to the device.
Then, use "Windows Explorer" to drag-and-drop files onto the new drive-letter (probably 'E:').
Nov 13, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Can't create new folder on memory stick
Sometimes these things get confused. try moving everything to a folder on your machine then, use the SanDisk tool to format the flash drive and move everything back.
Sep 08, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I'v inserted my flash drive on other computer and try to save some files, after saving i inserted it to my computer and scanned it. wen i was removing the virus, dialog box told me that it cannot delete...
There is a free program called unlocker which will allow you to delete,move or whatever you want with a file. this program will even delete protected system files. you can find it here http://ccollomb.free.fr/unlocker/
Mar 28, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
Get 'file permission error' when I try to save in Word.
This error means you dont have suffecient priviledges to save. It sounds like you need to be logged into an Administrator account. If you are, Right click the icon for the flash drive, And click Run As Administrator
Jan 05, 2009 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
2 GB flash drive.. Message says there is not enough room on drive to copy files, but as far as I can tell, the drive is actually all but empty, everything deleted. Is this have something to do with...
look what are you saving that file is bigger then 2gb?
you try zib file that try may be it work but keep in mind look size of file you are tring to save flash drive
Aug 14, 2008 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard Drive Logo
108 people viewed this question
Top SanDisk Computers & Internet Experts
Arora Singh
Arora Singh
Sandy Moore
Sandy Moore
Are you a SanDisk Computer and Internet Expert? Answer questions, earn points and help others
