Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Overhead garage door
One side of the door is closing all the way, the other side is about 2 inches from closing all the way. What do i need to do to ensure both sides close all the way?
I could not find the product on the product list but it is a steelcraft garage door.
  • 118 Answers
You have a problem with the cables. One of the cables might be broke or off the drum
Posted on Jan 27, 2009
I have an overhead garage door Legacy 496cb/d that stopped 3/4 of the way in the down motion. It now will not open or close and only clicks. The lights work and power is on.
If this picture at the link shown looks like yours, the red and white cord with the red plastic piece needs to be pulled to disconnect the automatic door opening chain.
http://www.aypapaquerico.info/overhead-door-legacy/overhead-door-legacy-large-size-of-garage-and-modern-overhead-garage-replacement-with-legacy-opener-overhead-door-legacy-496cd-b-manual/
Then, pushing the garage door fully open should move the mechanism back to connect in the ceiling. Then the remote control may work. If not, seek a repair service.
Mar 18, 2018 | Building Materials
I have the 3/4 Whisper Drive Plus. It will open about 3-5 inches then close and open 3-5 in and stay that way. Springs look OK and i pulled rip cord and was able to open an close manually. Help
It could be as simple as a drive motor force adjustment...
(you will have to get out the instruction manual)
Most likely your balance spring... one has failed
look over your springs very carefully... if one has shattered your counter-weigh is only lifting HALF the weight of your door.
Most garage doors need to be fairly NEUTRALLY BALANCED for the best, longest and reliable use.
Routine lubrication of the springs can add decades of useful life to your springs... CHATTERING Springs make a lot of noise and will soon shatter (break).
Sears makes house calls...
but they try to sell openers... you don't need.
https://www.bing.com/search?q=overhead%20garage%20door%20service&qs=n&form=QBRE&pq=overhead%20garage%20door%20service&sc=8-28&sp=-1&sk=&cvid=10E42AB45BFC41CC8E82D92DA893AB36 Sears Online In Store Shopping Appliances Clothing More
Oct 13, 2016 | Chamberlain 3/4-HP Whisper Drive Plus...
When I go to open the garage door the door only raises 18 inches & stops. I press the remote again & it closes. I sometimes have to open/close the door 10 times before it opens fully.
Is the main spring at the top of your door broken or has it unwound so there is too much pressure when trying to raise the door up. Check that out also check and see if you unlock the door with the rope that's on the overhead connection where the opener looks on the door See if the door will open if you try to open by hand. If its hard to push up either the spring is bad or you are seized some place.
Jul 20, 2016 | Building Materials
Garage door will not close
Make sure nothing is blocking the sensors on the floor at each side of the door.
Aug 23, 2013 | Building Materials
Garage door not closing on final closing position
Locate the limit switch on overhead rail.
This will be little piece of metal that hangs down and has 2 wires attached. No risk of shock.
Loosen the screw holding limit switch and slide bit more toward garage door opening to adjust final door position.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Aug 20, 2013 | Electrical Supplies
We have an Overhead garage door. It has started
A bad circuit board or capasitor will cause this, mostly its the circuitboard. Depending on the age replace it with a Chamberlain/Sears opener or they make a model called LIFTMASTER you can only get this thru a garage door company.
May 19, 2010 | General Electric GE 13-438 Overhead Garage...
Craftsman 1/2 HP garage opener opens only 6 inches
Remove the cover and check the drive gear. It is white nylon and is just in front of the motor. It may be stripped. Take a close look at those door springs. They can sometime appear to be okay when one is broken.
Oct 10, 2009 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
90 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
