Question about GE Dryers
My gas dryer lights but does not stay lit during the cycle
  • mphillpm2 Nov 29, 2008
    I have the same problem. I think my blower motor is surging. What should I try next?
  • 943 Answers
HI thanks for your question. the first thing to do is clean out all the venting. from dryer to the outside.try that, it could solve your problem . if not ask for me, and we try something else. like the coils on the gas valve. thanks the appliance doc. please rate my answer. thanks
Posted on Oct 08, 2008
Gas dryer wont stay lit
I'm assuming it "starts" to heat but then cuts off. Usually after the first minute of running you can open dryer door and feel heat but after awhile it doesn't heat.
1st, most common problem on a gas dryer not heating is "airflow" . They will "short-cycle" if there isn't near perfect airflow. Turn dryer on and go to outside exhaust vent. It should blow about as hard as you can blow into your hand. If any doubt disconnect dryer vent line from wall and let blow into your laundry room for one cycle and see if it is now working correctly. If it does work correctly when vent line is disconnected at wall you KNOW there is blockage somewhere in your vent line.
2nd, most common problem are gas coils. Easy to replace. 99% of all gas coils are the same so here is the part# (WE04X10020) (write it down.
Below is link where you can purchase appliance parts. Thanks for reading!
Appliance Parts
Feb 07, 2015 | Dryers
I have a Kenmore he4t. It warms up initially, but won't stay warm to dry. I have vacuumed out the interior of the dryer (after taking the panels off, there was a lot of lint inside). I ran it with the...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
Oct 30, 2010 | Dryers
My lg tromm DLG69885 gas dryer is not heating; otherwise it works fine. Dry light flashes cooling light stays on solid
I am using LG Tromm DLE2514 washer dryer. It 's running but didn't dried the clothes. I clean it's lint but still it's not working. The one thing i notice now is it's drying light is blinking and cooling light is turn on all the time during the cycle. So what's the problem with my dryer?
May 20, 2010 | LG DLG5932W Gas Dryer
Maytag LDG7400 gas dryer does not stay lit long enough to heat the drum. Can see flame turn on for about 10 seconds then back off for 20 to 30 seconds. Continues cycle of on and off until end of time....
Light sensors detect when burners are lit. If they become blocked with lint, dust, etc., they will not detect the flame and, for safety purposes, automatically shut off the gas flow.
Dust and lint are a dryer's worst enemy. Be sure that all sensing devices (particularly optical sensors) are clear of dust and lint so that light can pass unobstructed into the lens.
If they sensors are all clean, they might be defective. Something is erroneously telling your dryer's control that the burners are not lit and thus the gas supply is shut down.
Jan 01, 2010 | Maytag Dryers
Have a Maytag gas dryer, model#:LDG7314AAE, flame wont stay lit.
Clean/repair your dryer vent. The flame when it exits the funnel should not touch or just barely touch the funnel end. This indicates good airflow. A good test for the clogged/damaged vent is to disconnect the vent hose from the dryer and run it as is. If the flame stays - clean vent. If not - clean air path inside the dryer
Nov 17, 2009 | Refrigerators
My dryer doesn't stay lit
This could be a operating thermostat/thermister if it comes back on again and continues that cycle. If it stays off a long time then it could be the coils on the gas valve. Eric
Sep 14, 2009 | Whirlpool Dryers
I have a Kenmore gas dryer, model 80. The burner ignites but turns off fairly early during the cycle. It gets warm for a few minutes, but ends up not drying anything. I am trying to narrow down which parts...
Make sure the lint filter and the exhaust duct are clear all the way to the outside vent. If the gas cycles once and then does not light again the thermostat may be defective. If the gas lights but then goes off when the ignitor stops glowing then the secondary coil on the gas valve is bad. (This ignition cycle may continue to go on and off but the gas will not be lit enough to provide enough heat for drying.) The coil assembly can be replaced.
Aug 12, 2009 | Dryers
Wet clothes after full cycle
Check to see if lint filter is clean.  Also look through the holes inside at the back of the drum to see if there is lint clogging them.  Use a strong shop vac to clean them out if necessary.  The gas flame will normally go on and off during the cycle under the control of the thermostat so that does not sound like the problem unless it fails to come on again when the temperature cools down.  Check to see if air is coming out of the vent outside.  If not, then the blower wheel may be broken.  You will probably have to remove the motor to replace the blower wheel.  I have done it twice on my 34 year old dryer.
May 19, 2009 | Dryers
Maytag Gas Dryer won't stay lit
Mostly the Booster & Holding Coil, Their part number is 3-06106
Oct 08, 2007 | Dryers
Dryers Logo
60 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
