Question about Lands Phones
Hello, I don't have a problem as of yet; but I'm asking for advice prior to use. I bought 2 DVD 1000 videophones. I downloaded the manual & have been reading it for 2 days now. In the back of the device is a jack for a microphone. I would like to get some recommendations (from tech support) before I go out & spend good money on something that just won't work. Thank you for your time & trouble. Respectfully, HowardJ
  • hljones1 Oct 08, 2008
    Hi again. this keyboard has still got a slight problem with spelling.. The item is a DVC 1000 videophone. I must have hit the d by mistake.Thanks again. HowardJ
  • hljones1 Oct 09, 2008
    Yes,
    Very helpful... even included examples in the answer.
    HowardJ
    Brigadier General:
  • 6,966 Answers
Appreciate the confirmation that it is a D-Link DVC-1000 i2eye Broadband Video Phone.
Your concern:
  • The pink microphone jack is for an optional external microphone. Optional because there is already a built-in mic.
  • Additionally, if you use the handset/phone, both the optional external and the built-ins are muted.
  • Either the built-in or the external are only used when the device is set to SpeakerPhone mode.
  • An external microphone would perform better (than the built-in) since its direction can be adjusted, could be moved away from the DVC-1000 or speaker to reduce feedback (limit is length of mic cable/cord), high end external mic have better sound quality and sensitivity.
  • Examples are here, here, here, or here. Pls make sure that they are not USB ported.
  • There are even lapel type or wireless.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Oct 09, 2008
    Scholar:
  • 116 Answers
Yes.there is a audio input for micro phone in the device.
please read this.
Product Description D-Link DVC 1000 i2Eye VideoPhone - video conferencing kit Device Type Video conferencing kit Dimensions (WxDxH) 20.5 cm x 15.4 cm x 3.8 cm Weight 0.4 kg Max Transfer Rate 512 Kbps Digital Signaling Protocol H.323 Data Compression Protocol G.711, H.263, G.723 Video Input Digital video camera Audio Input Microphone Input Device Remote control ( wireless ) Modem Modem (digital) Networking Network adapter - Ethernet, Fast Ethernet Manufacturer Warranty 1 year warranty
Posted on Oct 08, 2008
  • 2 more comments
  • mastermind10 Oct 09, 2008
    Connect a telephone line and TV to the D-Link i2eye DVC-1000, plug in a standard Ethernet network cable that is connected to your broadband Internet connection, and you are ready to conduct real-time videophone calls
    Benefits:
    • Make outgoing calls using Direct IP address entry with an on-screen keyboard, Speed Dial list or the built-in directory.
    • Answer calls with the remote control or telephone.
    • Built-in caller ID lets you know who is calling, with privacy via Video/Audio Mute and the Do Not Disturb mode.
    • Connection ports for an external microphone, phone cord, audio and video cords and Ethernet RJ-45 port.
    • Features a half-duplex speakerphone.
    Features:
    • Turns any TV into a broadband videophone.
    • No PC required.
    • Up to 30 frames per second for smooth video.
    • Works with phone signalers for flashing lamp notification.
    Bring family, friends and colleagues closer with videophone calls. Both D-Link i2eye models (DVC-1000 and DVC-1100) are stand-alone devices - no computer required! This is an ideal solution for homes or small businesses for keeping in touch, conducting meetings and more.
    Consumers who are Deaf can make videophone calls by calling the Video Relay Service to use a VRS interpreter, or by calling another user directly. Any phone signaler may be used with a videophone to flash a lamp for visual notification of incoming videophone calls. With a phone signaler that transmits to remote receivers, you can be notified not just in one room, but in other rooms where the receiver is connected to a lamp or strobe light.
    Connecting the DVC-1000 Videophone:
    • Place the D-Link DVC-1000 videophone directly on top of a television. To obtain the best viewing experience, the videophone should be 5-10 feet away from the intended subject.
    • Attached the supplied white and yellow audio/video cable to the DVC-1000 and to the matching audio/video jacks on the television or VCR.
    • Attach the supplied Ethernet cable to the Ethernet port on the videophone and to the cable or DSL modem or ethernet network device (hub, switch or router).
    • Attaching a telephone is optional, but recommended for optimal sound quality when videoconferencing. Attach a standard telephone cable to the telephone and directly to the DVC-1000. Do NOT attach the telephone to a wall telephone outlet.
    • Plug the supplied AC power cable into an AC outlet and then connect the other end to the videophone.
    • Attaching an external microphone is optional, but recommended for optimal sound for a group videoconference.
    [Click for user manual]
    [Click for quick start guide]
    The DVC-1000 is meant to be used in conjunction with a TV, and placed on top like a set-top unit. It connects to a TV or other device using standard RCA cables, which are included. It is about the size of a hard cover book, and not heavy at all. At the heart of the unit is a camera that supports a resolution of up to 352x288 at 30fps, though this figure may vary according to available bandwidth and so forth.
    The unit does have a built in microphone for speakerphone mode, but it is advisable to use a microphone or telephone so that full-duplex mode will be enabled;
    when in speakerphone mode voice communication is only available in half-duplex mode, meaning that only one side can speak and be heard at any given time. When connecting a telephone for use as a handset to the DVC-1000, you won't be able to use the telephone to place regular phone calls; rather it can only be used with the videophone itself.
    You can connect the DVC-1000 to a computer, but you'll need some sort of capture device or card that supports RCA style inputs. But as the DVC-1000 was designed to be used with a TV, its preset focal distance is not ideal for use with a computer monitor. The focus can be adjusted somewhat, but clearly was not meant for large deviations. Additionally, the DVC-1000 is controlled by its remote control; almost all input is done via the remote. Some interesting specs are the ARM-9 processor; as this is a standalone device, the DVC-1000 must have the power necessary to compress and decompress video and audio properly. Additionally, D-Link has made the videophone firmware upgradeable, so any issues and new features may be addressed and added. The data rates refer to what the maximum send and receive rates of the DVC-1000 can be set to, and these figures must be set manually. As the DVC-1000 conforms to the video and audio standards relating to H.323, it'll work with many H.323 compliant clients out there.
    The DVC-1000 came nicely packaged as many of D-Link's products do, and was well protected. The videophone itself came with a rubber lens cap on, to protect the lens from dust and scratches, and it's a good idea to keep the lens cap in place when you're not using the device. The remote came with 2xAAA batteries; it's nice to see that you don't need to rush out and buy these little things to get this product working. The A/V cables and a CAT-5 cable for data were also included. The included Quick Install Guide and Manual were also up to par, each being full of screen shots and helpful pictures to guide you on your way. D-Link wanted the DVC-1000 to be an easy to use solution, and the starting point of this was their always-informative manuals. Overall, the DVC-1000 came in a complete package that left little to be desired, and it's nice to see D-Link put together a full package, rather than skimping on things to save a few cents per unit
    Being fairly small, the DVC-1000 will fit nicely on top of almost any TV, and because of its small size, low weight and gripping feet, it'll stay where you put it. The only minor placement problems you might run into are a result of the length of the RCA and power cables; the RCA audio/video cables are only about 1.5m long, and the AC adapter is only 1.8m. If the connections on your TV/VCR are quite a ways away, or the power bar is is not close by, these distances will not suffice. A remote is pretty much necessary for operation as if you're not using a telephone as a handset, all the input will be done via the remote. However, this results in just one more remote being added to the collection of remotes around your TV or entertainment center.
    The front of the unit shows the status of the DVC-1000 through a series of LEDs. The square LED to the immediate left of the lens shows the activity of a call - it'll be red when there's a call in progress. The remote sensor is to the right of the lens, and then comes the status LED and power LED. The status LED should only be on briefly when you power up the unit, otherwise it should be off unless the DVC-1000 is perhaps defective - useful as a quick diagnostic tool. As you can see from the side view, the DVC-1000 isn't bulky and hence won't look ugly on top of your TV. As with most consumer devices nowadays, the silver case is made of plastic.
    There is a focusing ring around the lens, as is the case with many cameras. It is really only for making minute adjustments, which is all you should need to do; the ring is quite tight and when you turn it counter-clockwise it appears to unscrew and suddenly get loose, and if you're dumb enough to keep loosening it (like I did), the lens eventually comes out. Tightening the lens helps focus on more distance objects, while counter-clockwise motion helps to focus in closer. You shouldn't have to make a lot of adjustments though, as by default the DVC-1000 will focus well if you're about 8-10ft or so away - which is about how far you need to be if you want to be in the camera's field of view properly. Though the lens assembly can tilt up or down quite a bit, it can't swivel from side to side, so you'll need to position the whole entire unit accordingly during setup. A nice addition was the sticker on the bottom that explained all of the camera's connections and status lights; this is the same diagram found in the quick setup guide. It's a bit redundant though, as D-Link pretty much labelled every connection itself nicely
    As the DVC-1000 is a standalone device that doesn't require a computer at all to use, a remote control is included, along with the batteries needed to operate it. It's pretty much a standard remote, not big at all at around 16cm in length. It's easy to hold, and the button placement with the Enter and arrow keys right where your thumb rests makes it easy to use as well. A number of buttons are in place to provide quick access to useful functions, such as the Enter button which brings up the on-screen keyboard for character input, and the cancel button, which backs you out of a menu quickly, removing the need to use the arrow keys to get to the cancel button on-screen.
    Using a phone also enables full-duplex audio; that is you will be able to talk and hear the other person at the same time. While using the speakerphone in the DVC-1000, audio is only half-duplex; you will only be able to talk or listen, but not do both at the same time. What is worse is that speakerphone automatically determines when the noise level is high enough to transmit; thus if you're in a loud room the speakerphone will always been transmitting audio, and because of the half-duplex impediment, you won't be able to hear the other side.
    The back of the unit sports all of the connections. A *******/off switch is followed by the RJ-45 connector, a mic input, an RJ-11 phone jack for use with a telephone as a handset, and the RCA connectors for attachment to your TV. The Ethernet connection has the small status and activity LEDs as any normal jack should have, and as mentioned before, the interface sports only a 10Mbps connection; this shouldn't matter as the necessary data rate for the DVC-1000 is far below this.
    However the most interesting connection on the back is the phone jack, which allows you to hook up a regular telephone. I was initially confused at this, but it's pretty simple. A phone connected to the DVC-1000 will *not* be able to make regular phone calls as it's not connected to a phone line any more, but instead the phone's handset will be used as an input/output device for the DVC-1000. Basically, this transforms the DVC-1000 into a true videophone that operates in the same way as a regular phone. When you want to make a call, you simply take the phone off its hook (or press "Talk" if you've connected a cordless phone), and the DVC-1000 will detect that the phone is engaged; it will then prompt you to dial a number or select a speed-dial entry - you can do both just by using the keypad on the phone's handset. Similarly, when someone calls you, picking up the phone will answer the call. This feature indicates D-Link was very much aiming to make the DVC-1000 easy to use for everyone - by making the basic operation as similar to a phone as possible, this has ensured that almost everyone should be able to use it easily
    for any picture details check out this link by clicking it
    http://www.virtual-hideout.net/reviews/d...
    please rate the solution if this helps you.
    still require any further help feel free for further queries.
    thanks.
    Genius:
  • 1,847 Answers
May i have model no of the phone and is this a voip phone?
I need to download manual for Toshiba DVD Player SDK 1000
http://www.retrevo.com/s/Toshiba-SD-K1000-DVD-Players-review-manual/id/23665bh443/t/1-2/
If you cannot get that link to work in your browser, send me an email to LBrown18062@hotmail.com. I will send you the manual.
Jan 31, 2012 | Televison & Video
I need a CyberHome CH-DVD 300 Manual not with a .jsp suffex.
I don't blame you - you are after a user manual - preferably a .pdf - that you can download and open later, and which is in a readable format - here is one possible location you can get a free pdf from:
http://www.retrevo.com/support/CyberHome-CH-DVD-300-DVD-Players-manual/id/534bh842/t/2/
(it may ask you for email address (no registration/sign up/password/paid subscription required) and to type some numbers in a box before you can download - just for security)
It is an Adobe Reader file (.pdf). I trust this might help you a bit.
Apr 21, 2011 | Cyberhome CH-DVD 300 DVD Player
Why the phone is hook off? how to fix it?
My grandaghter has D-Link Videophone DVC-1000. She got it set up and tried to call me. l have VP ( Sorenson - l am deaf ) . l can see her but she can't see me
Jan 24, 2010 | D-Link DVC-1000 Video Conference
I would like to install a Lexmark C83 on a different windows computer. I found the printer driver but would like the user guide. where can i get a download?
Go to, www.lexmark.com "Publications". Search for your printer model under the manuals.
Do not be surprised if the manuals do not list Vista as a supported, they were printed prior to the release of Vista.
Don
Nov 02, 2009 | Lexmark C533DN InkJet Printer
Ran it at 1@ now it has low power
Hello if your amp is the one above in the picture, MTX-1501D then your amp is not 1 ohm stable. Your amp is rated at 500 watts x 1 at 4 ohms and 1000 watts x 1 at 2 ohms. The amp has a safety circuit that if it senses to low of a load, ohms, it will only put out half it's power to protect the amp from shorting out. Read the manual. You can download it at retrevo.com or just google it and a manual download site will be in the search list. Hope this hels, Good luck.
Aug 21, 2009 | MTX Thunder 1501D Car Audio Amplifier
DLINK i2eye DVC-1000 videophone
Appreciate the direct "Ask Me".
With reference to your concern "...XX...", to my knowledge, yes. Although the unit has its own built-in speakerphone, the telco jack at the rear can accommodate:
  • cordless phones;
  • external speakerphones;
  • phone recorder; and
  • regular landline phones.
Cheers.
Oct 09, 2008 | Lands Phones
DRW-1000 Sanyo DVD/VCR combo
go to web site http://www.retrevo.com/s/Sanyo-DRW-1000-DVD-Players-review-manual/id/311dj889/t/1-2/ when it opens, click on download the manual (it's a PDF) I copy/pasted to my computer files. It's about 60 pages worth...............Hope it helps.
Aug 31, 2007 | Sanyo DRW-1000 DVD Recorder/VCR
Sony DCR DVD602E
Found this website with lots of frequently asked questions re DCR-DVD602E. Might help.
http://www.sony-asia.com/support/faq/10878/productcategory/cam+hd+avchd+dvd/modelfirst?site=hp_en_AP_i
Aug 10, 2007 | Sony DCR-DVD602E DVD Camcorder
Discs
Hello, please try to clean the laser unit (OPU). You can use special (wet) cleaning disc obtainable at the market or ask the pro to do it for you. If you need more info please advice.
May 02, 2007 | Sony RDR-GX7 DVD Recorder
Lands Phones Logo
213 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
