Question about Kenmore 53642 / 53644 Side by Side Refrigerator
Side by side kenmore refrigerator not cooling.Tampa FL.
I just moved to a new home and the refrigerator is not cooling. I unpluged and reconnect and the unit start cooling for about 24 Hrs to stop cooling again. There is a layer of ice on the back wall of the freezer all the time. Any advice? I am not sure about the model number.
thanks
Gus A
Tampa FL
  • geatampa Oct 09, 2008
    Thanks for your prompt response and help.
    gus
  • 943 Answers
HI thanks for your question. the problem you are having is that its not going into the defrost cycle. its not an expensive repair, probably $ 150. 00. unless you have the proper meter to check i would call a tech . but its more likely the defrost timer. or the defrost thermostat. thanks the appliance doc. please rate my answer. thanks.
Posted on Oct 09, 2008
Kenmore side by side - model - 253.54739304. we moved it from one house to another. it was working fine. now won't freeze or cool properly. like it is in defrost mode. compressor was not running...
if while moving it , you laid it on its side, it collected air in the lines, having it unplugged is a good idea, normally 24 hours is enough for the air to settle,, try it again after that time,
Jul 09, 2011 | Refrigerators
The refrigerator worked, but when unpluged and moved the compressor no longer runs. Is there a reset button on them?
no there is reset,but,the ptc overload relay plugged into the compressor is bad,purchase a new replacement ptc overload relay and plug in into the compressor and it will again cool properly
Apr 12, 2011 | Kenmore Side by Side Refrigerator
Unplugged Kenmore side by side to move and when plugged back in it has not cooled since in either side.
you may have a broken coolant line under the unit when you moved it.. get under there somehow and take a closer look,.,
Ck
Feb 13, 2011 | Refrigerators
My Kenmore side bt side isn't cooling. The
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} 98d4754.jpgIf this was a slow moving loss you should clean the cooling coil under the refrigerator. Remove the bottom snap in grille and vacuum out the dirt and dust from the coil and anything else you can reach. You may need to make an extension with paper towel tubes flattened a little and tape to get into the cramped spaces. I use a piece of clear plastic pipe stuck in the suction with a long angled split cut on the cleaning end. Maybe also move the fridge out, vacuum and clean the flooring area also. (And every 6 months)
Apr 16, 2010 | Kenmore 57029 Side by Side Refrigerator
Kenmore Coldspot Side by Side Model 51559101
Unplug the Ref for 15-20 min., plug it back in and listen for the compressor to start. You will need to be behind the Ref so you can tell if the compressor or the fan is running. It will help to take the cover off so you can see the compressor.
Compressor not running but you hear a clicking noise. The relay needs to be replaced.
Compressor runs but not cooling. Low on coolant
Feb 06, 2009 | Kenmore 53642 / 53644 Side by Side...
Not cooling but freezer works fine
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 24, 2009 | Kenmore 50522 / 50524 Side by Side...
Fridge not cooling
Hello.
The most common thing that happens while moving a frig is when moving it they put the dolly underneath the condenser fan housing and bend it into the fan causing the compressor to overheat before it has a chance to cool down everything. If this isn't the case then I will send you a list of things to check out. Let me know.
Dec 07, 2008 | Kenmore 56549 / 56542 / 56544 / 56546 Side...
Kenmore refrigerator not cooling and lights out
is the compressor hot? same as last job. unplug ref. clean the condenser coil, install new 3n1 start relay on compressor.
Nov 04, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore side by side not cooling after a move
go to the back of the fridge see if it has a white relay on the compressor that's the piece that plugs onto the compressor if it does un plug the unit take it off and shake it if it rattles and little black stuff falls out of it replace it with a three in one relay from an appliance repair parts store just follow the instructions on the part its easy don't worry about water in the ice maker it will fill when it starts cooling if it doesn't have the relay try turning it off for 24 hours to give the oil time to run back down to the compressor and advise me further
Mar 30, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Fridge not working
may i suggest you Purchase A premium repair Solution. @ $19.99 or £10.00 G.B.P
One of our technical assistants, will usually have the Answer to your Problem, within the hour.
Mike @ Compurepair.
Mar 02, 2008 | Kenmore 44109 / 44102 Side by Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
138 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
